CXHP2R7405R-TWV
CXHP2R7405R-TWV
    CDA(智烽微)
    径向,Can
    4 F (EDLC) 超级电容器 2.7 V 径向,Can 90 毫欧 @ 1kHz
CXHP2R7405R-TWV 数据手册
CXHP(2.7V)Series www.cda-cap.com FEATURES ● Low leakage current, long life ● High power,high energy density ● Small size and low-resistance ● Long cycle life,maintenance-free ● RoHS Directive Compliant APPLICATIONS ● Consumer electronics,Ride thru power support,Back up power,Stand alone or augment existing,energy/power source. OPERATING TEMPERATURE RANGE ● -40℃ to +65℃ @2.7V ● -40℃ to +85℃ @2.3V GENERAL SPECIFICATIONS Item Performance Operating temperature -40°C to +70°C Capacitance range 0.2F to 120F Capacitance tolerance -0%to+100%;-20%to+20%:-20%to+50% Rated voltage 2.7 V Surge voltage 2.85 V Temperature characteristics Capacitance change: Within ±30% of initial measured value at +25°C Internal resistance: Within ±200% of initial measured value at +25°C High temperature load time After 70°C 1500 hours (at2.7V): Capacitance change: ±30% of initial rated value Internal resistance: Within 2 times of initial specified value Projected cycle life (From rated voltage to 1/2 rated voltage at 25°C) After 500,000 cycles: Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Humidity characteristic Vibration resistance Shelf life Relative humidity: 90%~95% /Duration of testing:240 hrs /Temperature:40±2°C Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value Amplitude:1.5mm /Frequency:10~55Hz /Duration of testing:6 hrs Capacitance change: Within ±30 % of initial rated value Internal resistance: Within 2 times of initial specified value After 2 years at 25°C without load, the capacitor shall meet the specified endurance limits. No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-11-02 CXHP(2.7V)Series www.cda-cap.com DIMENSIONS RADIAL LEAD TYPE Size(mm) RADIAL BENT LEAD TYPE ФD P Фd 4 1.5 0.5 5 2.0 0.5 6.3 2.5 0.6 8 3.5 0.6 10 5.0 0.6 12.5 5.0 0.6 16 7.5 0.8 18 7.5 0.8 3.0 ±0.5mm Style B(mm) A1 4.0 C1 2.0 STANDARD PRODUCTS Part Number Working Rated Voltage Cap. (V DC) (F) Dimensions (mm) D*L Max.ESR Maximum Maximum Maximum Power Maximum Energy Leakage Peak Endurance Density Energy Density ESRAC ESRDC (72hrs/mA) Current(A) Current(A) (W/Kg) (W.h) (Wh/kg) (1kHz/mΩ) (mΩ) Radial Lead(Miniaturized) 0.09 1000 1820 0.001 0.17 833.1 0.0002 0.38 0.10 700 1200 0.002 0.19 1135.6 0.0002 0.34 0.11 700 1200 0.002 0.19 1249.7 0.0003 0.38 0.15 600 1000 0.002 0.40 1055.1 0.0003 0.87 0.15 600 1000 0.003 0.45 1077.3 0.0005 1.02 240 1600 0.006 0.52 0.14 1003 0.0005 1.86 0.16 700 1200 0.003 0.45 1093.5 0.0006 1.42 0.18 550 900 0.003 0.54 1023.2 0.0010 1.78 300 1500 0.006 0.54 0.16 1377.6 0.0012 1.92 0.18 200 400 0.003 0.66 3645 0.0012 1.62 0.33 200 400 0.006 1.16 2499.4 0.0012 2.17 CXHP2R7224R-TW CXHP2R7224R-TWX CXHP2R7304R-TW CXHP2R7354R-TW CXHP2R7504R-TWX CXHP2R7504R- TW CXHP2R7604R-TW CXHP2R7105R-TWV CXHP2R7105R-TWX CXHP2R7125R-TWX CXHP2R7125R-TW 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 0.22 0.22 0.3 0.35 0.5 0.5 0.6 1 1 1.2 1.2 4x10 5x10 4x10 5x10 5x12 6.3x12 4x22 4x25 6.3x12 6.3x11 5x22 CXHP2R7335R-TWX 2.7 3.3 6.3x22 90 180 0.010 2.44 0.53 3332.6 0.0033 3.18 CXHP2R7405R-TWV 2.7 4 6.3x25 90 130 0.010 2.44 0.53 3332.6 0.0040 3.18 No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-11-02 CXHP(2.7V)Series Part Number CXHP2R7105R- TW CXHP2R7205R- TW CXHP2R7205R- TWQ CXHP2R7255R- TW CXHP2R7305R- TWX CXHP2R7305R- TW CXHP2R7335R- TW CXHP2R7405R- TW CXHP2R7475R- TW CXHP2R7505R-TWX CXHP2R7505R- TW CXHP2R7605R- TW CXHP2R7705R- TW CXHP2R7705R- TWX CXHP2R7805R- TW CXHP2R7805R- TWX CXHP2R7106R- TW CXHP2R7106R- TWQ CXHP2R7106R-TWX CXHP2R7126R- TW CXHP2R7156R- TW CXHP2R7156R- TWX CXHP2R7186R- TW CXHP2R7206R- TW CXHP2R7206R- TWQ CXHP2R7256R- TW CXHP2R7306R- TW CXHP2R7306R- TWX CXHP2R7356R-TWX CXHP2R7356R-TW CXHP2R7406R-TWX CXHP2R7506R- TW CXHP2R7506R- TWQ CXHP2R7506R- TWX CXHP2R7606R- TW CXHP2R7107R-TWV CXHP2R7127R- TWV Working Rated Voltage Cap. (V DC) (F) 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 2.7 1 2 2 2.5 3 3 3.3 4 4.7 5 5 6 7 7 8 8 10 10 10 12 15 15 18 20 20 25 30 30 35 35 40 50 50 50 60 100 120 Dimensions (mm) DxL 8x12 8x12 8x20 8x16 8x16 8x20 8x20 10x20 10x20 8x25 10x20 10x20 10x20 8x25 10x25 12.5x20 10x25 10x30 12.5x20 12.5x20 12.5x26 12.5x20 12.5x26 12.5x26 12.5x30 16x25 16x30 16x25 16x30 16x35 12.5x46 18x40 12.5x50 18x35 18x40 18x60 18x60 www.cda-cap.com Max.ESR Maximum Maximum Maximum Power Maximum Energy Leakage Peak Endurance Density Energy Density ESRAC ESRDC (72hrs/mA) Current(A) Current(A) (W/Kg) (W.h) (Wh/kg) (1kHz/mΩ) (mΩ) Radial Lead 160 240 0.006 1.09 0.47 4050 0.0010 1.13 100 280 0.010 1.73 0.49 2924 0.0020 1.90 100 120 0.012 2.15 0.55 2924 0.0020 2.15 130 180 0.025 2.27 0.59 4115 0.0025 2.32 130 195 0.012 2.56 0.59 4116 0.0030 2.79 100 120 0.012 2.79 0.65 4486 0.0030 2.34 100 150 0.012 2.98 0.74 4486 0.0033 2.57 70 170 0.015 3.65 0.79 2339 0.0040 2.40 72 170 0.017 3.60 0.75 2340 0.0047 2.50 90 135 0.015 4.03 0.87 3857 0.0051 3.01 75 113 0.015 4.32 0.97 3535 0.0051 2.30 75 113 0.020 5.20 0.97 3518 0.0061 2.77 75 113 0.020 5.29 0.97 3535 0.0071 3.22 90 135 0.015 4.86 0.87 3600 0.0071 3.94 60 150 0.020 4.61 0.93 2303 0.0081 2.80 60 150 0.020 7.58 1.35 3557 0.0081 2.94 65 98 0.030 6.84 1.15 3451 0.0101 3.89 50 75 0.030 7.71 1.43 3800 0.0101 3.30 45 68 0.030 8.06 1.42 3757 0.0101 2.94 50 75 0.036 8.53 1.35 3381 0.0122 3.52 40 60 0.050 10.66 1.80 3359 0.0152 3.50 45 68 0.040 10.06 1.42 3550 0.0152 4.16 40 60 0.055 12.27 1.66 3645 0.0183 5.06 30 60 0.060 13.50 2.70 2692 0.0203 3.10 35 53 0.055 13.17 1.93 3920 0.0203 4.76 27 50 0.060 15.00 2.09 2419 0.0253 3.50 20 40 0.070 18.41 2.53 2664 0.0304 3.70 25 38 0.072 19.06 2.41 3049 0.0304 3.97 22 33 0.080 21.93 2.79 3194 0.0354 4.27 19 42 0.086 23.86 3.24 3220 0.0354 3.65 20 45 0.080 23.68 3.01 3694 0.0405 5.47 16 24 0.105 30.68 3.96 2848 0.0506 3.96 18 35 0.105 28.72 3.40 3640 0.0506 5.69 18 27 0.110 30.92 3.52 2700 0.0506 5.06 15 23 0.150 34.47 4.09 2880 0.0608 4.28 13 20 0.240 45.76 5.30 2136 0.1013 4.82 13 20 0.280 48.50 5.30 2039 0.1215 5.52 *with appropriate voltage derating operating temperature can be extended to 85°C No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-11-02 CXHP(2.7V)Series www.cda-cap.com QUALITY AND RELIABILITY No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-11-02 CXHP(2.7V)Series www.cda-cap.com LIFE TIME AND TEMPERATURE PERFORMANCE The life of a Super Capacitor is impacted by a combination of operating voltage and the operating temperature according to the following equation : LS = LR × 2X × 2Y Which is X=(Tm-Ta)/10 Y= (Vr-Va)/0.2 Ls = Expected life of the super capacitor in the application LR = Load life rating of the super capacitor Tm = Max temperature rating of the super capacitor Ta = Ambient temperature of the application Vr = Rated voltage of the super capacitor Va = Maximum applied voltage on the super capacitor in the application No. 4, Jifeng Road, Wufeng District, Taichung City, Taiwan. TEL:+86-852-51245795 www.cda-cap.com E-MAIL: zfw@cda-cap.tw Specifications are subject to change without notice.Should a safety or technical concern arise regarding the product, please be sure to contact our sales offices or agents immediately. Spec. Date:2022-11-02 CXHP(2.7V)Series www.cda-cap.com SAFETY RECOMMENDATIONS WARNINGS REGULATORY • To Avoid Short Circuit, after usage or test, SuperCapacitor voltage needs to discharge to ≤ 0.1V • Do not Apply Overvoltage, Reverse Charge, Burn or Heat Higher than 150°C, explosion-proof valve may break open • Do not Press, Damage or disassemble the SuperCapacitors, housing could heat to high temperature causing Burns • If you observe Overheating or Burning Smell from the capacitor disconnect Power immediately, and do not touch • MSDS • RoHS Compliant • Reach Compliant TRANSPORTATION Not subjected to US DOT or IATA regulations UN3499,
CXHP2R7405R-TWV 价格&库存
很抱歉,暂时无法提供与“CXHP2R7405R-TWV”相匹配的价格&库存,您可以联系我们找货
