XL2ED8K5OI-111YXC-24.576M 数据手册
CRYSTAL UNIT
YSX321SL
Applications
Features
‧SmartWearable
‧Dimensions:3.20 x 2.50 x 0.70 mm.
‧High precision and high frequency stability.
IOT Communication.
‧Standard Frequency: 8 to 64MHz
‧Extremely good for reducing EMI effect.
Specifications
8 to 64 MHz
Standard Frequency
Vibration Mode
AT Fundamental
10pF, 20pF, or specify
Load Capacitance
±10ppm, ±20ppm, or specify
Frequency Tolerance (at 25 ℃ )
Frequency Versus Temperature Characteristics
±20ppm, or specify
Operating Temperature
-20~+70℃,-40~+85℃,or specify
-55~+125℃ or specify
Storage Temperature
Shunt Capacitance
7 pF Max.
Level of Drive
1~200μWMax. (100uW typical)
Aging (at 25 ℃)
±3ppm/year Max.
Equivalent Series Resistance(ESR)
Fundamental
8 ~ 11.2892MHz
12 ~ 16 MHz
17 ~ 64 MHz
150 Ω Max.
80 Ω Max.
50 Ω Max.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
3.20±0.1
Marking
To p Vi e w
3
1
2
GND
2
To p Vi e w C ry st a l Co nn e ct ion
0. 7 ± 0 . 1
1
4
GND
2.50±0.1
3
4
S id e V i ew
1 .4
0 .8
1 .4
1.2
1
0. 7
1. 2 0 . 5 1 . 2
2
4
Bo t t o m Vi e w
3
To p Vi e w S ug g e ste d L ay o ut
U nits: mm
www.yxcxtal.com
CRYSTAL UNIT
YSX321SL
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
SMD-3225
180±2.0
8.0±0.3
3.50±0.1
2.50±0.1
4.0±0.1
1.40±0.1
61.0±1.0
8.0±1.0
3000 pcs per reel
www.yxcxtal.com
XL2ED8K5OI-111YXC-24.576M 价格&库存
很抱歉,暂时无法提供与“XL2ED8K5OI-111YXC-24.576M”相匹配的价格&库存,您可以联系我们找货
