QUARTZ-COMPACT-11-UMTS(EU) + ACC
    SIRETTA
    3G UMTS 路由器 LAN
QUARTZ-COMPACT-11-UMTS(EU) + ACC 数据手册
MICA-COMPACT-UMTS (EU) 3G Single LAN Ultra Compact Industrial Router Key Features • • • • • • • • • European 3G / UMTS bands High speed data via UMTS network Strong resistance to electromagnetic interference Built-in watch dog, multi-link detection Ultra Compact Industrial Design Excellent temperature endurance VPN: PPTP, L2TP, GRE, IPSec 1 x LAN, 1 x Serial port Optional GPS General Description Siretta’s MICA-COMPACT 3G/ UMTS router is an ultra compact, high speed industrial router designed for transferring large amounts of data via the cellular network. The MICA-COMPACT 3G/UMTS’s fast data transfer capability reaches up to 21Mbps download and up to 5.76Mbps upload speed. It also has fallback to 2.5G communication should 3G/ UMTS be unavailable. It is well suited for IoT/mobile broadband applications, offering reliable, secure wireless connectivity. The MICA-COMPACT 3G/UMTS router is of a robust design, coming in a ultra compact sized, metal enclosure, making it ideal for deployment in industrial embedded applications where space is at a premium. Cellular coverage is designed to match European frequencies. The MICA-COMPACT software means VPN security is supported, allowing the router to be used in commercial as well Registered in England No. 08405712 VAT Registration No. GB163 04 0349 Additional Features as industrial applications. The MICA-COMPACT 3G/UMTS router meets many of the needs for management of remote communication, and therefore has applications in security, digital signage, CCTV, vending, street furniture, traffic control, telemetry, parking systems & environmental monitoring. The MICA-COMPACT router comes equipped with a single SIM slot, single 10/100 ethernet LAN port and a serial port, which can be swopped out for optional GPS at point of ordering(note MOQ applies). Setting up the MICA-COMPACT router is quick and easy - simply insert your SIM card and connect the antennas. Power up the router. Connect to the internet by entering the correct APN settings in the web setting interface. The router will then connect and provide high speed 3G mobile broadband internet. Note: this unit does not have Wifi functionality. »» Supports DHCP server »» Supports DNS proxy and Dynamic DNS (DNSS) »» Supports timing operation »» Supports LED status indication »» Supports APN and VDPN wireless private network access »» Local and remote management »» SNMP network management, NTP support »» Supports Serial to IP data transfer »» LCP/ICMP/flow/heartbeat check Siretta Ltd Basingstoke Road Spencers Wood Reading Berkshire RG7 1PW sales fax email web +44(0)118 976 9000 +44(0)118 976 9020 sales@siretta.com www.siretta.com Rev 1.1 MICA-COMPACT-UMTS (EU) 3G Single LAN Ultra Compact Industrial Router General Features Router Settings »» Route Protocol UMTS (European): 900MHz, 2100MHz Interfaces »» »» »» »» 1× RS-232 console port(option to swap for GPS- MOQ applies) 2× SMA-K antenna interface 1× Standard SIM/R-UIM interface 1× Standard DC power interface »» »» Static route RIPv2/OSPF dynamic route Device Management »» »» »» »» Local or remote web browser (IE v8 or above) CLI/Telnet command M2M management platform (optional) SSH management (optional) Firewall and Filter Environmental »» Dimensions: 78.5mm x 59mm x 23.5mm (without antenna) »» »» »» »» Weight: 150g (without antenna) LED Instruction »» Operating Temperature Range: -30 to +70 deg C »» Storage Temperature Range: -40 to +85 deg C »» Relative Humidity:
QUARTZ-COMPACT-11-UMTS(EU) + ACC 价格&库存
很抱歉,暂时无法提供与“QUARTZ-COMPACT-11-UMTS(EU) + ACC”相匹配的价格&库存,您可以联系我们找货
