MIKE13/2.5M/SMAM/S/S/17 数据手册
Miniature magnetic mount active GPS
antenna with 2.5m cable and SMA male
connector
Features
Very small footprint
27.6 x 21 x 13.9mm
GPS (1575.42MHz) - GLONASS version available
3.0 to 5.0v operation
11mA max current consumption
The Mike 13 GPS antenna is one of the smallest active GPS / GLONASS antennas available in a
magetic mount style. The Mike 13 can also be used as an adhesive mount antenna using a double
sided adhesive pad. The Mike 13 has a typical LNA gain of 26dB (without cable) and can operate in
temperature range of -40˚C to + 85˚C and is completely waterproof.
Electrical characteristics - dielectric antenna:
Centre frequency: 1575.42MHz +/- 3MHz
Bandwidth: +/- 5MHz
VSWR: 1.5:1
Peak gain: 1dBi based on a 7 x 7cm ground plane
Gain coverage: -4dBic at -90˚ < 0 < +90˚ (over 75% Volume)
Electrical characteristics - LNA / filter:
LNA gain (without cable): 26dB typ
Noise figure: 1.5dB
Filter out Band attenuation (f0=1575.42MHz)
o 7dB min f0+/- 20MHz
o 20dB min f0+/- 50MHz
o 30dB min f0+/- 100MHz
VSWR:
MIKE13/2.5M/SMAM/S/S/17 价格&库存
很抱歉,暂时无法提供与“MIKE13/2.5M/SMAM/S/S/17”相匹配的价格&库存,您可以联系我们找货
