UT0 - Bantam
Metal circular
connector
(Suitable for EMC requirements)
Description
“UT0” Bantam industrial circular connectors
are a range of multiway connectors available
in 8 shell sizes and 8 insert arrangements
all intermateable, interchangeable and
intermountable with the Trim-Trio “UTG” ,
“UTGS” and “UTP industrial connector
families.
“UT0” is equipped with identical shells
from military connectors complying to
MIL-C-26482 spec.
Strong and rugged built to resist every
environmental and mechanical requirement
for indoor and outdoor applications.
In combination with the shielded backshell ,
“UT0” offers the perfect solution to EMC
requirements.
Features and benefits
Performance characteristics
Construction
• Suitable for EMC requirements.
• Shielded backshell is independent of the
cable diameter and its shielding.
• Available in 8 shell sizes and 8 insert
arrangements.
• Available in plug and receptacle version for
both male and female contacts.
• Shells and accessories are made from tin
plated corrosion resistant Aluminium.
• Plastic inserts with flammability rating:
UL94-V0.
• Alu. bayonet ring:
- Metal wave spring loaded.
- Locks with audible positive “click”
- Assures 500 matings and unmatings
Operating
temperature:
Insulation
resistance:
Test potential:
Durability:
Vibration
resistance:
Thermal
shock:
Corrosion:
Shells and accessories: Alumimium alloy
Coupling ring: Aluminium alloy
Tri-lock pins: Stainless steel
Coupling spring: Spring steel
Insert: Glass-filled thermoplast UL94-V0
Finish: Bright tin (standard)
How to order
5000 MΩ min.
2000 VAC
500 matings and unmatings.
Per MIL-STD202
method 204
Per MIL-STD202
method 207
Salt spray per MIL-STD 202
method 101
Shielding effectiveness: 95 dB at 1 Mhz
(see shielded connectors section)
Degree of protection per DIN 40050:
IP65 in mated condition. “H” version used
with UTG-PG cable clamp
UT0
UT0
Body variation:
-55°C to +125°C
14
14
12
12
P
S
0 : Wall mounting receptacle
6 : Cable plug
1 : Free hanging receptacle
7 : Bulk head receptacle for rear panel mounting
Shell size:
Insert arrangement:
Type of contacts: P : Pin contacts
S : Socket contacts
Insert polarisation: No letter : Standard version
Application:
H : Water protected version (only receptacle)
Design variation:
Others : Special versions
Plating:
T : Bright tin (Standard version)
Packing:
No letter: Standard version: Each connector individualy packed in plastic bag
B: Bulk packing per qty of 100 pcs
12
Contact accommodation
• “UT0” connectors accept Trim-Trio crimptype removable snap-lock contacts (see
contacts section)
• Contacts to be ordered seperately.
H
T
B
B
UT0 - Bantam
UTO
Cable plug for pin contacts (UT06- - - -PT)
Part number
Shell
size
UT06104PT
UT06128PT
UT061412PT
UT061619PT
UT061823PT
UT062028PT
UT062235PT
UT062448PT
10
12
14
16
18
24
ØA
±0.2
21.6
24.8
28.0
31.2
34.3
37.5
40.7
43.9
B max.
31.8
ØC
±0.15
10.2
13.4
16.7
19.7
21.7
24.9
28.1
31.2
ØD
±0.15
12.3
15.1
18.3
21.5
24.0
27.2
30.4
33.5
E
±0.2
19.1
For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT061412PTB
Cable plug for socket contacts (UT06- - - -ST)
Part number
Shell
size
UT06104ST
UT06128ST
UT061412ST
UT061619ST
UT061823ST
UT062028ST
UT062235ST
UT062448ST
10
12
14
16
18
24
ØA
±0.2
21.6
24.8
28.0
31.2
34.3
37.5
40.7
43.9
B max.
31.8
24.9
26.2
ØC
±0.15
10.2
13.4
16.7
19.7
21.7
24.9
28.1
31.2
ØD
±0.15
12.3
15.1
18.3
21.5
24.0
27.2
30.4
33.5
E
±0.2
19.1
For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT061412STB
13
UT0 - Bantam
Wall mounting receptacle for pin contacts (UT00- - - -PT)
Part number
UT00104PT
UT00128PT
UT001412PT
UT001619PT
UT001823PT
UT002028PT
UT002235PT
UT002448PT
Shell
size
10
12
14
16
18
24
A
max.
B
C
ØD
E
F
ØG
ØH
ØJ
±0.25
±0.2
±0.15
±0.25
•0.25
±0.1
±0.1
±0.1
15.0
19.0
22.2
25.3
28.5
31.7
34.9
38.0
18.3
20.6
23.0
24.6
26.9
29.4
31.8
34.9
23.8
26.2
28.6
31.0
33.3
36.5
39.7
42.9
3.9
17.3
21.8
25.0
28.1
31.3
34.5
37.7
40.9
15.1
18.2
21.4
24.6
27.8
30.9
34.1
37.3
1.6
31.7
11.3
14.5
33.3
2.4
15.3
3.2
For waterprotected version add “H” behind “P” e.g. UT001412PHT
For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT001412PTB
Wall mounting receptacle for socket contacts (UT00- - - -ST)
Part number
Shell
size
A
max.
B
C
ØD
E
F
ØG
ØH
ØJ
±0.25
±0.2
±0.15
±0.25
•0.25
±0.1
±0.1
±0.1
15.0
19.0
22.2
25.3
28.5
31.7
34.9
38.0
18.3
20.6
23.0
24.6
26.9
29.4
31.8
34.9
23.8
26.2
28.6
31.0
33.3
36.5
39.7
42.9
17.3
21.8
25.0
28.1
31.3
34.5
37.7
40.9
15.1
18.2
21.4
24.6
27.8
30.9
34.1
37.3
UT00104ST
10
UT00128ST
12
1.6
UT001412ST
14
24.3
11.3
UT001619ST
16
UT001823ST
18
UT002028ST
UT002235ST
22
25.9
2.4
UT002448ST
24
15.3
For waterprotected version add “H” behind “P” e.g. UT001412SHT
For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT001412STB
14
3.2
3.9
UT0 - Bantam
UTO
Free hanging receptacle for pin contacts (UT01- - - -PT) - suitable for cable to cable applications
Part number
Shell
size
UT01104PT
UT01128PT
UT011412PT
UT011619PT
UT011823PT
UT012028PT
UT012235PT
UT012448PT
10
12
14
16
18
24
A
max.
B
±0.25
31.7
1.6
33.3
2.4
C
±0.2
11.3
14.5
15.3
ØD
±0.15
14.9
19.0
22.2
25.3
28.5
31.7
34.9
38.0
ØE
max.
24.1
26.4
28.8
31.2
33.6
36.8
39.9
43.1
For waterprotected version add “H” behind “P” e.g. UT011412PHT
For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT011412PTB
Free hanging receptacle for pin contacts (UT01- - - -ST) - suitable for cable to cable applications
Part number
Shell
size
UT01104ST
UT01128ST
UT011412ST
UT011619ST
UT011823ST
UT012028ST
UT012235ST
UT012448ST
10
12
14
16
18
24
A
max.
B
±0.25
24.3
1.6
25.9
2.4
C
±0.2
11.3
14.5
15.3
ØD
±0.15
14.9
19.0
22.2
25.3
28.5
31.7
34.9
38.0
ØE
max.
24.1
26.4
28.8
31.2
33.6
36.8
39.9
43.1
For waterprotected version add “H” behind “P” e.g. UT011412SHT
For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT011412STB
15
UT0 - Bantam
Bulk head receptacle for pin contacts (UT07- - - -PT) - suitable for rear panel mounting
Part number
UT07104PT
UT07128PT
UT071412PT
UT071619PT
UT071823PT
UT072028PT
UT072235PT
UT072448PT
Shell
size
10
12
14
16
18
24
A
B
±0.15
±0.2
14.9
19.0
22.2
25.3
28.5
31.7
34.9
38.0
18.0
D
max.
F
max.
31.7
3.2
33.3
6.4
22.7
23.6
G
H
K
L
ØM
±0.25
•0.2
±0.2
±0.12
±0.2
27.0
31.8
34.9
38.1
41.3
46.1
49.2
52.4
22.2
27.0
30.2
33.3
36.5
39.7
42.9
46.0
16.6
20.8
23.9
27.1
30.3
33.4
36.6
39.8
17.0
21.2
24.3
27.5
30.6
33.8
37.0
40.1
17.7
22.5
25.7
28.7
32.0
35.2
38.4
41.5
For waterprotected version add “H” behind “P” e.g. UT071412PHT
For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT071412PTB
Bulk head receptacle for pin contacts (UT07- - - -ST) - suitable for rear panel mounting
Part number
UT07104ST
UT07128ST
UT071412ST
UT071619ST
UT071823ST
UT072028ST
UT072235ST
UT072448ST
Shell
size
10
12
14
16
18
24
A
B
±0.15
±0.2
14.9
19.0
22.2
25.3
28.5
31.7
34.9
38.0
18.0
D
max.
24.3
3.2
25.9
6.4
22.7
23.6
For waterprotected version add “H” behind “P” e.g. UT071412SHT
For bulk packing (qty 100 pcs) add B at the end of cat. Nr. eg. UT071412STB
16
F
max.
G
H
K
L
ØM
±0.25
•0.2
±0.2
±0.12
±0.2
27.0
31.8
34.9
38.1
41.3
46.1
49.2
52.4
22.2
27.0
30.2
33.3
36.5
39.7
42.9
46.0
16.6
20.8
23.9
27.1
30.3
33.4
36.6
39.8
17.0
21.2
24.3
27.5
30.6
33.8
37.0
40.1
17.7
22.5
25.7
28.7
32.0
35.2
38.4
41.5
很抱歉,暂时无法提供与“UT061619ST”相匹配的价格&库存,您可以联系我们找货
