SparkFun Real Time Clock Module - RV-1805 (Qwiic)
BOB-14558 O p en S o u r c e H a r d w a r e
Get with the times, already! This SparkFun Real Time Clock (RTC) Module is a Qwiic-enabled
breakout board for the RV-1805 chipset. The RTC is ultra-low power (running at only about 22nA in
its lowest power setting) so it can use a supercapacitor for backup power instead of a normal
battery. This means you get plenty of charge and discharge cycles without any degradation to the
“battery.“ To make it even easier to get your readings, all communication is enacted exclusively via
I2C, utilizing our handy Qwiic system so no soldering is required to connect it to the rest of your
system. However, we still have broken out 0.1”-spaced pins in case you prefer to use a breadboard.
This RTC module’s built in RV-1805 has not one, but two internal oscillators: a 32.768kHz tuning
fork crystal and a low power RC based oscillator and can automatically switch between the two
using the more precise crystal to correct the RC oscillator every few minutes. This feature allows the
module to maintain a very accurate date and time with the worst case being +/- about three minutes
over a year. The RV-1805 also has a built in trickle charger so as soon as the RTC is connected to
power the it will be fully charged in under 10 minutes and has the ability to switch power to other
systems allowing it to directly turn on or off a power hungry device such as a microcontroller or RF
engine.
There is also the option to add a battery to the board if the supercapacitor just isn’t going keep your
project powered long enough (keep in mind, the supercap can hypothetically make the board keep
time for around 35 days), you can solder on an external battery. That means you can let board sit
with no power or connection to the outside world and the current hour/minute/second/date will be
maintained.
The SparkFun Qwiic connect system is an ecosystem of I2C sensors, actuators, shields and cables
that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm
pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized
connections mean you can’t hook it up wrong.
FEATURES
Operating Voltage (Startup): 1.6V - 3.6V
Operating Voltage (Timekeeping): 1.5V - 3.6V
Operating Temperature: -40°C - 85°C
Time Accuracy: ±2.0 ppm
Current Consumption: 22nA (Typ.)
I2C Address: 0xD2
Supercapacitor for Backup Power
2x Internal Oscillators
2x Qwiic Connectors
https://www.sparkfun.com/products/14558 6‐4‐18
很抱歉,暂时无法提供与“BOB-14558”相匹配的价格&库存,您可以联系我们找货
