CAB-14988
CAB-14988
    SPARKFUNELECTRONICS
    QWIIC CABLE FEMALE JUMPER 4PIN
CAB-14988 数据手册
        Qwiic Cable - Female Jumper (4-pin) CAB-14988 This is a jumper adapter cable that comes pre-terminated with a female Qwiic JST connector on one end and female connectors on the other. This cable makes it easy to connect components with a Qwiic connector to the male pins on various development platforms. The 28AWG wire’s length is 150mm (about 5.9 inches). The adapter’s wires have been color coded to red, black, blue and yellow. Additionally, the female Qwiic connector features a basic 1mm pitch, while the female hookup pins can easily connect to a standard 0.1" male connector. The SparkFun Qwiic connect system is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized connections mean you can’t hook it up wrong.                                                         https://www.sparkfun.com/products/14988 10‐‐23‐18
CAB-14988 价格&库存
很抱歉,暂时无法提供与“CAB-14988”相匹配的价格&库存,您可以联系我们找货
