DEV-14285
DEV-14285
    SPARKFUNELECTRONICS
    TB6612FNG 电机驱动器,无线 电源管理 Arduino 平台评估扩展板
DEV-14285 数据手册
    SparkFun Wireless Motor Driver Shield DEV-14285 RoHS Open Source Hardware The SparkFun Wireless Motor Driver Shield is designed to make connecting motors, sensors and other components to your Arduino-based project as fast and easy as possible. The heart of the Wireless Motor Driver Shield is the Toshiba TB6612FNG H-Bridge Motor Driver, which allows the shield to control two DC motors at once, both CW and CCW, and to brake electronically. The TB6612FNG H-Bridge is rated up to 1.2A per channel at 13V, which means it will drive a fair variety of hobby motors ranging in power. Each of the GPIO pins is broken out on a “servo-style” header field with PWR and GND to allow you to easily connect devices using a 3-pin servo cable. Using the onboard slide switches, the motor power and servo power rail can be connected to the Arduino’s regulated voltage, VIN, or a completely separate power supply attached to the shield’s barrel jack. This feature makes the SparkFun Wireless Motor Driver Shield ideal if you are connecting multiple servos and need more than 5V to your robotics project! This shield also includes an I2C pin-out and a built-in XBee socket, making it perfect for setting up an XBee-based remote control. Simply plug an XBee module into the socket on the shield, and you have the control system for a simple remote control rover or small autonomous robot! FEATURES     TB6612FNG H-Bridge Motor Driver XBee Socket I2C Header Arduino R3 Layout Notice. This product requires other products in order to function properly. See essential products. Essentials  XBee 1mW Trace Antenna ‐ Series 1 (802.15.4) WRL-11215 XBee Pro 60mW Wire Antenna ‐ Series 1 (802.15.4) WRL-08742 Circular Robotics Chassis Kit (Two‐Layer) ROB-14332 SparkFun RedBoard ‐ Programmed with Arduino DEV-13975 Circular Robotics Chassis Kit (Three‐Layer) ROB-14339                                                  https://www.sparkfun.com/products/14285 10‐23‐17
DEV-14285 价格&库存
很抱歉,暂时无法提供与“DEV-14285”相匹配的价格&库存,您可以联系我们找货
DEV-14285
    • 1+218.44179
