Neutis Quad-Core Module
DEV-14971 ROHS
Ever since the Edison left us we’ve been looking for an equal or greater replacement to fill the hole
in our hearts. Introducing the Neutis N5 Module from Emlid! This Quad Core System on a Module is
perfect for makers and developers.
The Neutis N5 Module is loaded with features. Utilizing Neutis’ BSP based on Yocto, the system
arrives with an up to date Linux kernel. The module is powered by a 64-bit ARM Cortex-A53 and a
ARM Mali450 MPR GPU. It has 512MB of RAM and 8GB eMMC storage. For connectivity, there are
a plethora of wired and wireless options at your disposal. For wireless needs, the system rocks
802.11 b/g/n and Bluetooth 4.0 Dual-mode BLE all with the built-in antenna. For your wired needs,
the module’s two connectors give you access to an incredible peripheral set including over 50 GPIO
and a multitude of interfaces. Checkout the features tab for a full listing.
In today’s environment, we can’t forget about security. The Neutis N5 comes with the ATECC508A
Secure Element for storing cryptographic keys, unique IDs, and supports the creation of FIPS
random numbers.
This module can do a lot but is really meant to be embedded into a system. If you’re looking to kick
the tires quickly be sure to checkout the Neutis Development Kit which breaks out the Neutis N5 to a
variety of easy to use connectors and headers.
FEATURES
Processor: Quad Core 64 bit Arm Cortex-A53 with a max frequency of 1.3 GHz
GPU: Mali 450 MP4
RAM: 512MB DDR3
Storage Memory: 8GB
Wi-Fi: 802.11 b/g/n
Bluetooth: 4.0 Dual-Mode BLE
Operating Temperature: -20 C to +70C
Storage Temperature: -40C to +85C
Board Connectors: 2x DF40 80-pin
Antenna: Onboard Ceramic
https://www.sparkfun.com/products/14971 10-4-18
很抱歉,暂时无法提供与“DEV-14971”相匹配的价格&库存,您可以联系我们找货
