SmartLED Shield V4 for Teensy
DEV-15046
LED matrices are getting more powerful with each passing year requiring you to need a more
powerful board to control them. That’s where this shield comes into play! The SmartLED Shield V4 is
the next iteration of the SmartMatrix Shield and provides you with a bridge for your Teensy 3.1, 3.2,
3.5, or 3.6 to your large LED matrix. The shield makes it easy to connect the 13 signals required to
drive the display, connects an external 5V supply to power the display and Teensy, and brings out
the Teensy’s free signals to a convenient header.
Of course, if using an LED matrix isn’t your cup of tea, that’s just fine since the SmartLED Shield is
also capable of driving individual APA102 LEDs, boards, and strips. The SmartLED Shield comes
fully assembled, allows for your Teensy board to be removed at your leisure, and all the while saving
four GPIO pins from the Teensy itself.
Note: The SmartLED Shield V4 is not compatible with the Teensy LC models.
INCLUDES
SmartLED Shield V4
Male 4-pin JST SM Cable (10cm)
2x8 Extra Long Pin Header
https://www.sparkfun.com/products/15046 11‐12‐18
很抱歉,暂时无法提供与“DEV-15046”相匹配的价格&库存,您可以联系我们找货
