SparkFun Qwiic pHAT for Raspberry Pi
DEV-15351
The SparkFun Qwiic pHAT for Raspberry Pi (based on the original Qwiic Hat) provides you with the
quickest and easiest way to enter into SparkFun’s Qwiic ecosystem while still using that Raspberry
Pi that you’ve come to know and love. The Qwiic pHAT connects the I2C bus (GND, 3.3V, SDA and
SCL) on your Raspberry Pi to an array of Qwiic connectors on the HAT. Since the Qwiic system
allows for daisy chaining boards with different addresses, you can stack as many sensors as you’d
like to create a tower of sensing power!
The Qwiic pHAT has four Qwiic connect ports, all on the same I2C bus. This HAT is compatible with
any Raspberry Pi that utilizes the standard 2x20 GPIO header. It is also compatible with the NVIDIA
Jetson Nano as well as the Google Coral.
The SparkFun Qwiic Connect System is an ecosystem of I2C sensors, actuators, shields and cables
that make prototyping faster and less prone to error. All Qwiic-enabled boards use a common 1mm
pitch, 4-pin JST connector. This reduces the amount of required PCB space, and polarized
connections mean you can’t hook it up wrong.
Note: When placing a Raspberry Pi and the pHat in an enclosure (like the Pi Tin), we noticed that
the pHAT was not fully inserted in Pi's header pins.
FEATURES
4x Qwiic Connection Ports
https://www.sparkfun.com/products/15351 /6‐10‐19
很抱歉,暂时无法提供与“DEV-15351”相匹配的价格&库存,您可以联系我们找货
