Hookup Guide for the Qwiic Motor Driver
Introduction
The Qwiic Motor Driver takes all the great features of the Serial Controlled Motor Driver and mini-sizes them,
adding Qwiic ports for plug and play functionality. Boasting the same PSOC and 2-channel motor ports, the QWIIC
Motor Driver is designed to communicate over I2C, but UART is also available.
SparkFun Qwiic Motor Driver
ROB-15451
Product Showcase: SparkFun Qwiic Motor Driver
Required Materials
To follow along with this tutorial, you will need the following materials. You may not need everything though
depending on what you have. Add it to your cart, read through the guide, and adjust the cart as necessary.
Qwiic Motor Driver Wish List SparkFun Wish List
USB Mini-B Cable - 6"
CAB-13243
This is a USB 2.0 type B to Mini-B 5-pin black cable. You know, the mini-B connector that usually comes with USB …
SparkFun FTDI Basic Breakout - 3.3V
DEV-09873
This is the newest revision of our [FTDI Basic](http://www.sparkfun.com/commerce/product_info.php?products_id=…
ROB-15451
SparkFun RedBoard Qwiic
DEV-15123
Hobby Gearmotor - 140 RPM (Pair)
ROB-13302
These are a pair of hobby gearmotors from DAGU. These gearmotors are the same ones recommended for use in …
Qwiic Cable - 100mm
PRT-14427
SparkFun Traveler microB Cable - 1m
CAB-14741
Jumper Wires Premium 6" M/M - 20 AWG (10 Pack)
PRT-11709
Jumper wires are awesome. Just a little bit of stranded core wire with a nice solid pin connector on either end. The…
Lithium Ion Battery - 1Ah
PRT-13813
These are very slim, extremely light weight batteries based on Lithium Ion chemistry. Each cell outputs a nominal 3…
Suggested Reading
If you aren’t familiar with the following concepts, we recommend you read over these tutorials before continuing.
Serial Communication
I2C
Asynchronous serial communication concepts: packets,
signal levels, baud rates, UARTs and more!
An introduction to I2C, one of the main embedded
communications protocols in use today.
Motors and Selecting the Right One
Learn all about different kinds of motors and how they
operate.
Logic Levels
Learn the difference between 3.3V and 5V devices and
logic levels.
Serial Controlled Motor Driver Hookup Guide
Hookup guide for the Serial Controlled Motor Driver
Bi-Directional Logic Level Converter Hookup
Guide
An overview of the Bi-Directional Logic Level
Converter, and some example circuits to show how it
works.
Hardware Overview
Let's look at some of the various features of the hardware.
Features:
1.5 A peak drive per channel, 1.2 A steady state
Operates from 3 to 11 volts with 12v absolute max
3.3V default VCC and logic
127 levels of DC drive strength.
Controllable by I2C or TTL UART signals
Direction inversion on a per motor basis
Global Drive enable
Exposed small heat sink shape
Several I2C addresses, default UART bauds available
Power
There are two separate power circuits on this board . Power for the motors is supplied through the VIN
Connectors - you can provide anywhere from 3.3V to 11V to the "MAX 11V" and "GND" connections. Power for
the PSOC and logic circuits is provided by the 3.3V inputs on the Qwiic connectors. Both are needed for proper
functioning.
Motor Power Ports: Ground (Left) - VIN(Right)
Qwiic Connectors
There are two Qwiic connectors on the board such that you can provide power or daisy-chain the boards should
you choose to do so. If you're unfamiliar with our Qwiic system, head on over to our Qwiic page to see the
advantages!
Motor Ports
The screw pin terminals at the top of the board allow for two motor connections. They are labeled on the backside
of the board.
From left to right on the front: B2-B1-A2-A1
Function / Connection
Group
Name
Direction
Description
UART
Motor Port
A1
O
Winding of first addressable location
Motor A winding
A2
O
Motor A winding
B1
O
Winding of second addressable location
Motor B winding
B2
O
Motor B winding
I2C
Jumpers
Jumper Usage Table
There are 2 sets of jumpers to configure on this board. There are pull-up enables for I2C and 4 config bits that
select operational mode.
Name
Description
Usage
I2C Jumpers
I2C pull-up
enable
Opening these disables theI2C pull-up resistors used for I2C communication. If
multiple I2C devices are being used, these pull-ups should be disabled on all but
one device. If UART is being used, the pull-up resistors should be disabled.
Address
Jumpers
Serial and
function
selection
The config bits are 4 bits that form a configuration nybble. A closed jumper is a
'1' and an open jumper is a '0'. See config table for more information.
I2C Pull-Up Jumpers
Address Bits
The configuration is set by encoding a number into the 4 config bits on the bottom of the board. Close a jumper to
indicate a 1, or leave it open to indicate a 0.
Use this table to see what the user port, address, and expansion port will become in each configuration:
Pattern
Mode
User Port
User Address
Expansion Port
0000
UART at 9600
UART
N/A
Master
0011
I2C
I2C
0x58
Master
0100
I2C
I2C
0x59
Master
0101
I2C
I2C
0x5A
Master
0110
I2C
I2C
0x5B
Master
0111
I2C
I2C
0x5C
Master
1000
I2C
I2C
0x5D
Master
1001
I2C
I2C
0x5E
Master
1010
I2C
I2C
0x5F
Master
1011
I2C
I2C
0x60
Master
1100
I2C
I2C
0x61
Master
1101
UART at 57600
UART
N/A
Master
1110
UART at 115200
UART
N/A
Master
1111
N/A
Reserved
N/A
N/A
Bold text is the default setting for the Qwiic Motor Driver
Thermal Conduction Area
The Qwiic Motor Driver is designed to operate small robot drive motors without a heatsink; we were able to run up
to about 1.1A continuous current without going above 100°C. If you find that you need a heatsink, you can use our
Theragrip Thermal Tape to attach three Small Heat Sinks across the thermal conduction area on the back of the
board.
If you need more information on how to determine whether or not you need a heat sink, kick on over to the Serial
Controlled Motor Driver Hookup Guide and scroll down to Typical Application Motors and Heat Sinking.
Small Heatsinks on the back of the Qwiic Motor Driver
Board Dimensions
All measurements are in inches. The Qwiic Motor Driver PCB measures 1x1 inch, with slight overhangs for the
power and motor screw terminals.
Software Setup
Note: This code/library has been written and tested on Arduino IDE version 1.8.5. Otherwise, make sure you
are using the latest stable version of the Arduino IDE on your desktop. If this is your first time using Arduino,
please review our tutorial on installing the Arduino IDE. If you have not previously installed an Arduino library,
please check out our installation guide.
Installing Arduino
If you haven't used the Arduino IDE before, head on over to our Installing the Arduino IDE tutorial to get set up:
Installing Arduino IDE
MARCH 26, 2013
A step-by-step guide to installing and testing the Arduino software on Windows,
Mac, and Linux.
Getting the Arduino Library
The Qwiic Motor Driver uses the same Arduino Library as the Serial Controlled Motor Driver (hereafter referred to
as SCMD). To get the Arduino library, either download and install it from Github or use the Arduino Library
Manager.
Download the Github repository
Visit the GitHub repository to download the most recent version of the library, or click the link below:
DOWNLOAD THE ARDUINO LIBRARY
Use the library manager or install in the Arduino IDE
In the Library Manager, search for Serial Controlled Motor Driver. For help installing the library, check out our
How To Install An Arduino Library tutorial.
Installing an Arduino Library
JANUARY 11, 2013
How do I install a custom Arduino library? It's easy! This tutorial will go over how
to install an Arduino library using the Arduino Library Manager. For libraries not
linked with the Arduino IDE, we will also go over manually installing an Arduino
library.
Experiment 1: Testing the Motors
Let's start by hooking up some motors and making sure they're running. Since the Qwiic Motor Driver uses the
same PSOC as the Serial Controlled Motor Driver, the same examples will work with minor modifications.
⚡ Note: In lieu of using the external LiPo battery, it is also possible to use the 5V and GND pins from the
RedBoard Qwiic.
Hardware Hookup
Click the image for a closer look
Testing the Motors
The following test is essentially the TwoMotorRobot.ino example from the SCMD library, but with a few minor
changes to account for the defaults of the Qwiic Motor Driver.
Copy and paste the following code into your Arduino browser and upload.
//This example drives a robot in left and right arcs, driving in an overall wiggly course.
// It demonstrates the variable control abilities. When used with a RedBot chassis,
// each turn is about 90 degrees per drive.
// Pin 8 can be grounded to disable motor movement, for debugging.
#include
#include
#include
#include
#include
"SCMD.h"
"SCMD_config.h" //Contains #defines for common SCMD register names and values
"Wire.h"
SCMD myMotorDriver; //This creates the main object of one motor driver and connected slaves.
void setup()
pinMode(8, INPUT_PULLUP); //Use to halt motor movement (ground)
Serial.begin(9600);
Serial.println("Starting sketch.");
//***** Configure the Motor Driver's Settings *****//
// .commInter face is I2C_MODE
myMotorDriver.settings.commInterface = I2C_MODE;
// set address if I2C configuration selected with the config jumpers
myMotorDriver.settings.I2CAddress = 0x5D; //config pattern is "1000" (default) on board for ad
dress 0x5D
// set chip select if SPI selected with the config jumpers
myMotorDriver.settings.chipSelectPin = 10;
//*****initialize the driver get wait for idle*****//
while ( myMotorDriver.begin() != 0xA9 ) //Wait until a valid ID word is returned
Serial.println( "ID mismatch, trying again" );
delay(500);
Serial.println( "ID matches 0xA9" );
// Check to make sure the driver is done looking for slaves before beginning
Serial.print("Waiting for enumeration...");
while ( myMotorDriver.ready() == false );
Serial.println("Done.");
Serial.println();
//*****Set application settings and enable driver*****//
//Uncomment code for motor 0 inversion
//while( myMotorDriver.busy() );
//myMotorDriver.inversionMode(0, 1); //invert motor 0
//Uncomment code for motor 1 inversion
while ( myMotorDriver.busy() ); //Waits until the SCMD is available.
myMotorDriver.inversionMode(1, 1); //invert motor 1
myMotorDriver.enable(); //Enables the output driver hardware
#define LEFT_MOTOR 0
#define RIGHT_MOTOR 1
void loop()
//pass setDrive() a motor number, direction as 0(call 0 forward) or 1, and level from 0 to 255
myMotorDriver.setDrive( LEFT_MOTOR, 0, 0); //Stop motor
myMotorDriver.setDrive( RIGHT_MOTOR, 0, 0); //Stop motor
while (digitalRead(8) == 0); //Hold if jumper is placed between pin 8 and ground
//***** Operate the Motor Driver *****//
// This walks through all 34 motor positions driving them forward and back.
// It uses .setDrive( motorNum, direction, level ) to drive the motors.
//Smoothly move one motor up to speed and back (drive level 0 to 255)
for (int i = 0; i < 256; i++)
myMotorDriver.setDrive( LEFT_MOTOR, 0, i);
myMotorDriver.setDrive( RIGHT_MOTOR, 0, 20 + (i / 2));
delay(5);
for (int i = 255; i >= 0; i--)
delay(5);
//Smoothly move the other motor up to speed and back
myMotorDriver.setDrive( LEFT_MOTOR, 0, 20 + (i / 2));
myMotorDriver.setDrive( RIGHT_MOTOR, 0, i);
delay(5);
delay(5);
What You Should See
The code goes through and establishes communication with the motor driver and then runs each motor in arcs,
resulting in a "wiggly pattern".
Things to note:
Serial.begin is periodically run until the returned ID word is valid.
Setup waits for isReady() to become true before going on to the drive section
One motor is inverted by command at setup. Do it here so you don't have to mess with it later.
enable() is called to connect the drivers to the PWM generators.
LEFT_MOTOR and RIGHT_MOTOR are defined to ease use of the setDrive( ... ) function.
See the Arduino Library Reference section of the Serial Controlled Motor Driver Hookup Guide for more
information on the functions defined in the Arduino library.
Experiment 2: Interactive Commands with UART
This example demonstrates the basic commands, plus some direct register access possible with only a UART
available. This type of program could be easily run from a script from a more classic PC where I2C isn't available.
Interactive UART
Requirements
Computer serial terminal set to 9600 baud.
Terminal set to send CR and LF (Carriage return and line feed).
Config jumpers set to '0000', or all open.
I2C PU jumper fully open
FTDI Basic or Serial Basic - either will work but ensure you have the 3.3V version
Make sure the Address Jumper 3 and I2C Pullup Jumpers are cut as you see here.
Connect the FTDI to the Qwiic Motor Driver as you see in the Fritzing diagram below. Attach two motors to the
driver, one between A1 and A2, and the other between B1 and B2.
Example Commands
When you're ready, make sure you have the correct COM port selected in your Arduino IDE, open a Serial Monitor,
and send the following commands:
"R01"
This will read the ID register and return 0xA9
"M0F50"
This will tell motor 0 to drive at half speed, forward -- But nothing will happen yet!
"E"
This will enable all drivers. Motor 0 should begin spinning at half speed.
"M1R100"
This will tell motor 1 to drive at full speed in reverse. Now both should be spinning opposite directions.
"D"
D will disable both motors, which will stop spinning.
See the section UART Commands in the Serial Controlled Motor Driver Hookup Guide for a full command listing.
Troubleshooting
Need help?
If your product is not working as you expected or you need technical assistance or information, head on over
to the SparkFun Technical Assistance page for some initial troubleshooting.
If you don't find what you need there, the SparkFun Forums are a great place to find and ask for help. If this
is your first visit, you'll need to create a Forum Account to search product forums and post questions.
Resources and Going Further
Schematic (PDF)
Eagle Files (ZIP)
Github (Hardware)
Github (Arduino Library)
Serial Controlled Motor Driver DataSheet (PDF)
Python Library GitHub
Qwiic Motor Driver Board Dimensions
Need inspiration? Check out some of the Qwiic or motor related tutorials!
SparkFun LoRa Gateway 1-Channel Hookup
Guide
Using SparkFun Edge Board with Ambiq Apollo3
SDK
How to setup and use the LoRa Gateway 1-Channel in
Arduino.
We will demonstrate how to get started with your
SparkFun Edge Board by setting up the toolchain on
your computer, examining an example program, and
using the serial uploader tool to flash the chip.
Build a Qwiic Jukebox that is Toddler Approved!
Follow this tutorial to build your own custom jukebox.
Note, this is designed simple and tough for use
primarily with toddlers. It's also a great introduction to
SparkFun's Qwiic products!
SparkFun Inventor's Kit for micro:bit Experiment
Guide
This guide contains all the information you will need to
explore the twelve circuits of the SparkFun Inventors
Kit for micro:bit.
Capacitive Touch Slider (CAP1203) Hookup
Guide
An easy and Qwiic way to add capacitive touch to any
of your projects using the CAP1203! In this guide, we
go over how to connect and set up your Capacitive
Touch Slider so you can start playing with it right away.
How to Build a Remote Kill Switch
Learn how to build a wireless controller to kill power
when things go... sentient.
ReconBot with the Tessel 2
Activity Guide for SparkFun Tinker Kit
Build a robot with the Tessel 2 that you can control from
a browser on your phone or laptop.
This activity guide will take you through the basics of
building 11 different circuits with the SparkFun Tinker
Kit and how to program them using the Arduino IDE.
