Web of Things Kit
KIT-13832 RoHS
This is the Web of Things (WoT) Kit, a comprehensive and hands-on kit that teaches about the
intersection of the Internet of Things (IoT) and modern Web technologies. This kit utilizes the
Raspberry Pi 3 model as its medium to teach with an 16GB SD card and USB cable, a prototyping
board with jumper wires, and all the various sensors (motion, humidity, temperature) and LEDs. In a
few hours, you’ll learn how to use Node.js to build a flexible REST API that allows anyone in the
world to interact with your Pi in real time! You’ll be out of the box and at “Hello, world” in no time!
Also included in each kit is the book Building the Web of Things which provides you with the skills
needed to architect and implement scalable and secure IoT products, applications, and services by
leveraging the scalability and flexibility of Web standards. We have collaborated with the authors of
this book to bring you the WoT kit that contains all the hardware you need to build all the examples
presented in the book.
After a broad introduction to the nuts and bolts of the Internet of Things (devices, sensors,
standards, tools and more), Building the Web of Things quickly moves up the (protocol) stack and
focuses on the Web of Things - the Application Layer protocol for the IoT. By providing the right
balance between theory and practice, you will be rapidly able to navigate the complexity of the Web
of Things and learn about a wide range of tools and techniques to connect IoT devices to the Web
and built interactive applications on top.
Once you’ve configured your Raspberry Pi, you will learn how to wire various sensors to it and
access them from Node.js applications. Afterwards, you will learn in detail the elements of the Web
of Things architecture that you can leverage to REST APIs for physical objects, discover and
describe devices using the latest developments in the semantic Web, sharing and securing data,
and combining these components to rapidly build distributed applications and physical mash-ups.
Each chapter will help you gain the knowledge and skills you’ll need to fully take advantage of a new
generation of real-time, web-connected devices and services and to be able to build scalable,
enterprise-ready applications that merge the physical and digital worlds.
Note: We are still waiting on the status on how the RPi3 may be export restricted due to certain
qualities it possesses. We may just need to verify a small amount of information before processing
your order and hopefully nothing beyond that. Please keep this in mind before placing your order.
Note: Chapter 4 of the book is a step by step guide to installing the Pi and setting up the following
components.
Includes
Raspberry Pi 3
Building the Web of Things Book
MicroSD Card with Adapter - 16GB (Class 10)
Wall Adapter Power Supply - 5.25V DC 2.4A (USB Micro-B)
Humidity and Temperature Sensor - RHT03
PIR Motion Sensor (JST)
Breadboard - Self-Adhesive (White)
LED - Assorted (20 pack)
Resistor 10K Ohm 1/6th Watt PTH - 20 pack
Resistor 330 Ohm 1/6 Watt PTH - 20 pack
Jumper Wires - Connected 6in. (M/M, 20 pack)
Jumper Wires - Connected 6in. (M/F, 20 pack)
https://www.sparkfun.com/products/13832 10‐9‐17
很抱歉,暂时无法提供与“KIT-13832”相匹配的价格&库存,您可以联系我们找货
