KIT-14329
KIT-14329
    SPARKFUNELECTRONICS
    RASPBERRYPI ZERO W CAMERA KIT
KIT-14329 数据手册
        SparkFun Raspberry Pi Zero W Camera Kit KIT-14329 RoHS The SparkFun Raspberry Pi Zero W Camera Kit provides you with a pan/tilt camera controlled via a Raspberry Pi Zero W. This kit consists of parts that are easy to assemble and program, expanding the Raspberry Pi Zero W’s IoT capabilities and highly tailored accessibility to the Pi Camera Module. With the Zero W camera kit, you will be able to create homemade motion-activated security systems, webcam interfaces for streaming, or monitoring stations for any number of projects and adventures. After just a few steps you’ll be set up in no time with your very own remote camera system! Inside this kit is everything you need to assemble your pan/tilt camera, including a Raspberry Pi Zero W, our own Pi Servo HAT, a Raspberry Pi Camera Module V2, a pan/tilt bracket with servos, and all the cables and headers you need to hook them all up. We have also written an in-depth assembly guide that walks you through each step to put together your kit, as well as programming steps utilizing the Raspbian Jesse Image and libraries. This guide can be found below. Note: The Pan/Tilt Bracket in this kit does not come pre-built, so some assembly is required. Check our Documents for a complete Assembly Guide. INCLUDES          1x Raspberry Pi Zero W 1x SparkFun Pi Servo HAT 1x Raspberry Pi Camera Module V2 1x Raspberry Pi Zero Case w/ Short Camera Cable 1x Pan/Tilt Bracket Kit 1x Raspberry Pi Zero Camera Cable 1x Raspberry Pi GPIO Male Header - 2x20 1x Raspberry Pi GPIO Tall Header - 2x20 1x Double-Sided Foam Tap Square - 1in.        https://www.sparkfun.com/products/14328 9‐18‐17
KIT-14329 价格&库存
很抱歉,暂时无法提供与“KIT-14329”相匹配的价格&库存,您可以联系我们找货
