SparkFun mbed Starter Kit
KIT-14458 RoHS Open Source Hardware
DESCRIPTION
The SparkFun mbed Starter Kit (mSK) is a great way to get into user-created projects created by
ARM to assist with rapid prototyping on microcontrollers. The mSK, which utilizes the LPC1768 by
ARM, includes everything you need to complete 10 circuits that will teach you how to create a USB
host, draw text and shapes on an LCD, log temperature data and more. We recommend that you do
have some previous programming or electronics experience before using this kit.
The online mSK Experiment Guide (in the Documents tab) contains step-by-step instructions for how
to connect each circuit with the included parts. Full example code is provided and explained and
even includes Fritzing diagrams and the required components.
The kit does not require any soldering and is recommended for anyone with an intermediate to
advanced knowledge of programming. We’ve essentially designed this kit to be the next step up
from the SparkFun Inventor’s Kit (SIK). So if you are looking for a new challenge, check out the
mbed Starter Kit!
INCLUDES
mbed - LPC1768 (Cortex-M3) (with USB cable)
White Solderless Breadboards
Serial Miniature LCD Module – 1.44" (with Hookup cable)
TRRS 3.5mm Jack Breakout (with headers)
Triple-Axis Accelerometer Breakout – MMA8452Q (with headers)
microSD Transflash Breakout (with headers)
USB Type A Female Breakout (with headers)
USB Mini-B Breakout (with headers)
RJ45 Ethernet MagJack Breakout (with headers)
16GB microSD Card with SD Adapter (Class 10)
microSD USB Reader
Speaker – PCB Mount
TMP36 Temp Sensor
Transistor – NPN (2N3904)
Jumper Wires
CAT 6 Cable – 3ft
Tri-color LED
Big 12mm Buttons
330 and 10K Resistors
EXAMPLES
Circuit 1: Blink an LED
Circuit 2: Buttons and PWM
Circuit 3: Graphic LCD
Circuit 4: Accelerometer
Circuit 5: Internet Clock
Circuit 6: USB Host and Threading
Circuit 7: USB Device
Circuit 8: Temperature Logging
Circuit 9: PWM Sounds
Circuit 10: Hardware Soundboard
https://www.sparkfun.com/products/14458 12-4-17
很抱歉,暂时无法提供与“KIT-14458”相匹配的价格&库存,您可以联系我们找货
