SparkFun Tinker Kit
KIT-14556 ROHS
The SparkFun Tinker Kit (STK) is a great way to get started with programming and hardware
interaction with the Arduino programming language. The STK is our newest version of the former
SparkFun Mini Inventor’s Kit, blended with elements of our educator MESA kit. Each SparkFun
Tinker Kit includes everything you need to complete 11 circuits that will teach you how to blink an
LED, read sensors, drive servos, and more. You don’t need any previous programming or
electronics experience to use this kit.
The online STK Experiment Guide (in the Documents section below) contains step-by-step
instructions of how to connect each circuit with the included parts. Full example code is provided and
explained, and even includes troubleshooting tips in case something goes wrong.
The kit does not require any soldering and is recommended for beginners ages 10 and up. This
miniature version of the SIK will help prove that anyone can (and should) play around with cuttingedge electronics in a fun and playful way while not breaking the bank.
INCLUDES
SparkFun RedBoard
SparkFun Motor Driver (with Headers)
Breadboard - Self-Adhesive (White)
Servo – Sub-Micro Size
Hobby Gearmotor – 200 RPM (Pair)
Temperature Sensor – TMP36
Mini Photocell
SparkFun USB Mini-B Cable – 6 Foot
Jumper Wires – 7" M/M 30 AWG (30 Pack)
LED – RGB Clear Common Cathode
Red, Blue, Yellow, and Green LEDs
Red, Blue, Yellow, and Green Buttons
Mini Power Switch
10K Trimpot
Battery Holder - 4xAA to Barrel Jack Connector
330 and 10K Resistors
EXAMPLES
Circuit 1: Blinking an LED
Circuit 2: Reading a Potentiometer
Circuit 3: Driving an RGB LED
Circuit 4: Driving Multiple LEDs
Circuit 5: Reading a Button Press
Circuit 6: Reading a Photoresistor
Circuit 7: Reading a Temperature Sensor
Circuit 8: Using a Servo Motor
Circuit 9: Driving a Motor with an H-Bridge
Circuit 10: Controlling a Motor with Inputs
Circuit 11: Reading Serial Data
https://www.sparkfun.com/products/14556 4‐3‐18
很抱歉,暂时无法提供与“KIT-14556”相匹配的价格&库存,您可以联系我们找货
