Lighthouse Beginner Soldering Kit
KIT-14635
A smooth sea never made a skilled sailor, so start learning how to solder with this kit! With this
Lighthouse soldering kit you will be able to learn the basics and some intermediate skills of soldering
by being able to assemble an Isophase lighthouse! Each Lighthouse kit takes about 10-20min to
assemble with basic soldering materials (not included). Fear not all you lovers of Lovecraft and
occulting lighthouses, by changing the value of the resistors you can change the flashing pattern!
Every Lighthouse Beginner Soldering Kit includes one lighthouse PCB and base, a CR2032 battery
holder, four resistors, two NPN transistors, two capacitors, a power switch and a single white LED
for the lighthouse light!. All you need to supply (besides a soldering iron and solder) is a CR2032
coin cell battery since it is not included to make shipping easier.
Note: Since this product is a kit, assembly and a basic knowledge of soldering will be required. The
Lighthouse soldering kit does not come pre-assembled.
INCLUDES
1x Lighthouse PCB
1x Stand PCB
1x White LED
1x 220 Ohm Resistor
1x 82k Ohm Resistor
2x 220k Ohm Resistors
2x 2N3904 NPN Transistors
2x 10uF Capacitors
1x Power Switch
1x CR2032 Battery Holder
https://www.sparkfun.com/products/14635 4‐3‐18
很抱歉,暂时无法提供与“KIT-14635”相匹配的价格&库存,您可以联系我们找货
