heART - Surface Mount Soldering Kit
KIT-14640
Be still my beating heart! With the heART Surface Mount Soldering Kit you will be able to learn the
basics of SMD soldering by being able to assemble a beating heart pendant! Each heART kit takes
about 20-40min to assemble depending on your soldering skill level with basic soldering materials
(not included). This little kit provides a great learning tool to help you practice and improve your
overall soldering skills without proving to be an impossible challenge!
Every heART pendant kit includes one heart-shaped PCB, a CR2032 SMD battery holder, SMD
LEDs, capacitors, switch, and an ATtiny85 (the heart of the heART). All you need to supply (besides
a soldering iron and solder) is a CR2032 coin cell battery since it is not included to make shipping
easier and some way to hang the completed pendant from your neck when you assemble it. The
battery you provide should last over a week if left on continuously and much longer if switched off
when not in use.
Note: Since this product is a kit, assembly and a healthy knowledge of soldering will be required.
The heART pendant kit does not come pre-assembled.
INCLUDES
1x heART PCB
5x SMD Red LEDs
1x SMD Capacitor
1x SMD ATtiny85
1x SMD Switch
1x CR2032 SMD Battery Clip
https://www.sparkfun.com/products/14640 4‐3‐18
很抱歉,暂时无法提供与“KIT-14640”相匹配的价格&库存,您可以联系我们找货
