SparkFun Inventor's Kit Bridge Pack for micro:bit
KIT-14719 O p e n S o u rc e H a r d w ar e
Do you own a micro:bit or micro:bit Go Bundle and want to expand your skills with the new
microcontroller? You are in luck! The SparkFun Inventor’s Kit Bridge Pack for micro:bit was designed
to provide you with an easy way to transform your m:b into a full fledged learning kit! Each Bridge
Pack includes all of the parts found in the SIK for micro:bit that aren’t included with the Go Bundle.
With the SIK Bridge Pack for micro:bit you will be able to complete circuits that will teach you how to
read sensors, move motors, build Bluetooth® devices and more.
The micro:bit is a pocket-sized computer that lets you get creative with digital technology. Between
the micro:bit and our shield-like bit boards you can do almost anything while coding, customizing and
controlling your micro:bit from almost anywhere! You can use your micro:bit for all sorts of unique
creations, from robots to musical instruments and more. At half the size of a credit card, this versatile
board has vast potential!
Note: The Bridge Pack is NOT a full SparkFun Inventor’s Kit and only includes the parts to
complement a micro:bit Go Bundle or standalone board. That also means that this kit
does not include a micro:bit, which will need to be purchased separately.
INCLUDES
SparkFun micro:bit Breakout (with Headers)
Full-Size Breadboard
Small Servo
TMP36 Temperature Sensor
Photocell
USB Micro-B Cable — 6 Foot
Jumper Wires
Alligator Clips with Pigtails
RGB Diffused LED
Red, Blue, Yellow and Green LEDs
10K Trimpot
Multicolor Button — 4-pack
SPDT Mini Power Switch
Mini Speaker
100 Ohm Resistors (Thick Leads)
10K Ohm Resistors (Thick Leads)
EXAMPLES
Circuit 0: Hello, micro:bit!
Circuit 1: Blinking an LED
Circuit 2: Reading a Potentiometer
Circuit 3: Reading a Photoresistor
Circuit 4: Driving an RGB LED
Circuit 5: Reading an SPDT Switch
Circuit 6: Reading a Button Press
Circuit 7: Reading the Temperature Sensor
Circuit 8: Using a Servo Motor
Circuit 9: Using a Buzzer
Circuit 10: Using the Accelerometer
Circuit 11: Using the Compass
https://www.sparkfun.com/products/14719 6‐20‐18
很抱歉,暂时无法提供与“KIT-14719”相匹配的价格&库存,您可以联系我们找货
