SparkFun Basic Flashlight Soldering Kit
KIT-14877
Are you new to soldering and want to learn the basics with one easy kit? This Flashlight Soldering
Kit is an easy to assemble soldering kit designed to help teach the basics of through hole soldering
and circuit design. This kit requires you to only solder four unique parts onto a PCB and then insert a
CR2032 battery, once completed you will be provided with a simple flashlight that will light up dark
areas and keep the monsters away!
Inside each Basic Flashlight Soldering Kit bag is a PCB, a small coin cell battery, a battery holder,
an LED, a resistor, and a switch. On the front of the kit’s PCB, you can see markings and outlines for
the four different components to make sure everything is assembled correctly, while on the back is a
schematic of the flashlight circuit showing all four components and how they interact with each other.
All you need to supply is a soldering iron and solder to put your kit together!
INCLUDES
1x Basic Flashlight PCB
1x Super Bright White LED
1x Mini Power Switch - SPDT
1x Coin Cell Battery Holder - 20mm
1x Coin Cell Battery - CR2032
1x Resistor - 10 Ohm, ¼ Watt
https://www.sparkfun.com/products/14877 10‐24‐18
很抱歉,暂时无法提供与“KIT-14877”相匹配的价格&库存,您可以联系我们找货
