KIT-15418
KIT-15418
    SPARKFUNELECTRONICS
    SPARKFUN LED STARTER KIT
KIT-15418 数据手册
    SparkFun LED Starter Kit KIT-15418 This is the SparkFun LED Starter Kit, an ultimate assortment of LEDs packed into a single red box! Now, this isn't a box filled with only one type of LED, oh no. Inside each kit you will find over 70 multi-colored and multi-functional LEDs and even more resistors to help hook everything up. All colors of the spectrum, super-bright and diffused, 3mm to 10mm, you will find plenty of options suited for almost any situation in the SparkFun LED Starter Kit. INCLUDES          1x LED Mixed Bag - 10mm 2x LED Rainbow Pack - 5mm 1x LED Super Bright White Pack - 5mm 1x Ultraviolet LED - 5mm 2x Fast Cycling RGB LED - 3mm 2x Slow Cycling RGB LED - 3mm 5x Clear Common Cathode RGB LED - 5mm 1x Infrared Emitter and Detector 4x Resistor 330 Ohm 1/4 Watt PTH - 20 pack https://www.sparkfun.com/products/15418/12‐12‐19
KIT-15418 价格&库存
很抱歉,暂时无法提供与“KIT-15418”相匹配的价格&库存,您可以联系我们找货
