SparkFun Inventor's Kit Bridge Pack - v4.1
KIT-15476
DESCRIPTION
Own the fourth iteration of our popular SparkFun Inventor's Kit and not ready to buy version 4.1?
You are in luck! The SparkFun Inventor's Kit Bridge Pack was designed to provide you with an easy
way to move into the next SIK edition without buying a whole new kit. Each Bridge Pack includes all
of the new parts found in the SIK v4.1 that aren't in V4.0, as well as the most up-to-date, spiralbound guidebook so you can get started right away!
v4.0 => v4.1
o RedBoard (w/ FTDI, mini-B) => RedBoard Qwiic (w/ CH340 micro-B connector, Qwiic
connector w/ logic level conversion)
o USB mini-B cable => USB micro-B cable
o Red Ultrasonic Sensor => Blue Ultrasonic Sensor w/ crystal - increased reliability
The SIK V4.1 includes the Redboard Qwiic which allows you to expand into the SparkFun Qwiic
ecosystem after you have become proficient with the SIK circuits. The SparkFun Qwiic Connect
System is an ecosystem of I2C sensors, actuators, shields and cables that make prototyping faster
and less prone to error. All Qwiic-enabled boards use a common 1mm pitch, 4-pin JST connector.
This reduces the amount of required PCB space, and polarized connections mean you can’t hook it
up wrong. Please be aware that with the new Redboard Qwiic addition to the SIK that you will
needto install new drivers for the CH340 USB-to-Serial Converter.
Note: The Bridge Pack is NOT a full SparkFun Inventor's Kit and only includes the parts to
complement an older version of the SIK to make it compatible with the version 4.0 projects.
INCLUDES
1x SparkFun RedBoard Qwiic
1x Ultrasonic Distance Sensor - Blue HC-SR04
1x SparkFun Inventor's Kit Guidebook v4.1
1x USB micro-B Cable - 6 Foot
EXAMPLES
Combining this Bridge Pack with an older SIK will allow you to create the following projects:
Project 1: Light
o Circuit 1A: Blinking an LED
o Circuit 1B: Potentiometer
o Circuit 1C: Photoresistor
o Circuit 1D: RGB Night-Light
Project 2: Sound
o Circuit 2A: Buzzer
o Circuit 2B: Digital Trumpet
o Circuit 2C: "Simon Says" Game
Project 3: Motion
o Circuit 3A: Servo Motors
o Circuit 3B: Distance Sensor
o Circuit 3C: Motion Alarm
Project 4: Display
o Circuit 4A: LCD "Hello, World!"
o Circuit 4B: Temperature Sensor
o Circuit 4C: "DIY Who Am I?" Game
Project 5: Robot
o Circuit 5A: Motor Basics
o Circuit 5B: Remote-Controlled Robot
o Circuit 5C: Autonomous Robot
https://www.sparkfun.com/products/15476/8‐13‐19
很抱歉,暂时无法提供与“KIT-15476”相匹配的价格&库存,您可以联系我们找货
