PRT-16835
PRT-16835
    SPARKFUNELECTRONICS
    BATT CHARGER SOLAR 5V 1.7A
PRT-16835 数据手册
    Solar Panel Charger - 10W PRT-16835 ROHS Have a project that needs some good power? Do you like free power provided by our friend, Mr. Sun? This solar panel charger is a lightweight, ultra thin (2mm), and affordable power solution. This panel comes with a 5V USB connection port. The panel is capable of 10 watts in the open sun with a peak power output around 6V at 1700mA. This panel features a monocrystalline silicon material to provide a 20% high photoelectric conversion rate. With a frosted surface makes the panel scratch resistant and more durable. This also has a water resistant epoxy resin seal. The panel is slightly flexible making it considerably lighter than equivalent glass based panels. Because it is light weight this panel is designed for temporary installation on windows (that's what the included suction cups are for) but can be permanently installed. If you're considering permanent installation, note that the DC buck on the back of the panel is not fully waterproof. As long as the panel is mounted with the connector pointed down the panel should survive quite well outdoors. The panel weighs 3.3648 ounces and measures 259.60mm x 139.69mm x 2.46mm (9.83mm thickness at the USB port). NOTE: While this product is rated at 10W we found the actual max output to be around 3W (5V at 600mA). INCLUDES    1x Solar Charger 2x Carbiners 4x Suction Feet (useful for mounting to windows) FEATURES        Solar Output: 6V, 1700mA Output: USB 5V, 1200mA Water resistance: IP65 Material: Monocrystalline Silicon Test Output using variable load vs. measure voltage:Load / Measured Voltage o No Load / 5.15V o 100mA / 5.12V o 200mA / 5.09V o 300mA / 5.06V o 400mA / 5.03V o 500mA / 5.00V o 600mA / 4.94V o 700mA / 4.91V o 800mA / 3.13V o 900mA / 2.72V o 1000mA / 2.33V Dimensions: 259.60mm x 139.69mm x 2.46mm (9.83mm thickness at USB port) Weight: 3.3648 ounces.         https://www.sparkfun.com/products/16835/8‐31‐20
PRT-16835 价格&库存
很抱歉,暂时无法提供与“PRT-16835”相匹配的价格&库存,您可以联系我们找货
