SparkFun gator:soil - micro:bit Accessory Board
SEN-15272
If your plants could talk, would they call out "Water me, Seymour?" Unfortunately (or fortunately,
perhaps) plants have yet to develop the ability to speak. But thanks to the SparkFun gator:soil
micro:bit Accessory Board, you can now measure the moisture level in soil without any vocal
clamoring from your leafy lads. And, best of all--it is part of SparkFun's gator:bit series of alligatorclippable accessories, meaning you can easily interface it with the micro:bit or other microcontrollers!
The gator:soil consists of two probes and three pads (PWR, GND, and SIG). The probes are used to
measure the conductivity of the soil. SIG provides an analog voltage out that can be attached to an
ADC pad on the gator:bit (v2). The value read on SIG is dependent on a few variable, including soil
composition, contact on the probes, soil compaction, and other factors. In most cases, it will
behoove you to calibrate your sensor reading for each soil sample and sensor. Once calibrated, for a
fixed sensor, the primary variables to measuring conductivity in the soil will be the power input and
moisture content of the soil.
We recommend powering the gator:soil with between 3.3V - 5V. Again, please note that the analog
value returned will vary depending on what voltage is provided for the sensor. For use with the
gator:bit (v2) and micro:bit, you should provide 3.3V through the PWR and GND pads. We
recommend not powering the sensor constantly to reduce corrosion of the probes; this can be
controlled through one of the digital pins of the gator:bit (v2).
The micro:bit is a pocket-sized computer that lets you get creative with digital technology. Between
the micro:bit and our shield-like bit boards you can do almost anything while coding, customizing and
controlling your micro:bit from almost anywhere! You can use your micro:bit for all sorts of unique
creations, from robots to musical instruments and more. At half the size of a credit card, this versatile
board has vast potential
FEATURES
gator:bit Compatible
Contacts:
o PWR: INPUT: Power to the sensor (3.3V-5V)
o SIG: OUTPUT: Analog voltage representing conductivity between probes
o GND: REFERENCE: Ground reference (0V)
o Probes: Used to sample soil moisture content for sensor
https://www.sparkfun.com/products/15272/6‐24‐19
很抱歉,暂时无法提供与“SEN-15272”相匹配的价格&库存,您可以联系我们找货
