DEV-15443
DEV-15443
    SPARKFUNELECTRONICS
    - Apollo3 收发器; Bluetooth® 5 2.4GHz 评估板
DEV-15443 数据手册
Name: SparkFun RedBoard Artemis Nano Single Line Description: The RedBoard Artemis Nano is a miniature extremely versatile implementation of the Artemis module. SKU: DEV-15443 Description: We like to joke the Artemis Nano is a party on the front and business on the back. And that's by design! All the important LEDs, connectors, labels, and buttons are presented on the front for the best user experience with all the supporting circuitry on the rear of the board. The RedBoard Artemis Nano is a minimal but extremely handy implementation of the Artemis module. A lightweight, 0.8mm thick PCB, with onboard lipo-battery charging and a Qwiic connector, this board is easy to implement into very small projects. A dual row of ground connections makes it easy to add lots of buttons, LEDs, and anything that requires its own GND connection. At the same time, the board is breadboard compatible if you solder the inner rows of pins. A modern USB-C connector makes programming easy. The Nano is fully compatible with the SparkFun's Arduino core and can be programmed easily under the Arduino IDE. We've also exposed the JTAG connector for more advanced users who prefer to use the power and speed of professional tools. If you're looking for a simple, cost-effective board to replace your aging Arduino Uno or Arduino Nano, look no further. We've even added a digital MEMS microphone f or folks wanting to experiment with always-on voice commands with TensorFlow and machine learning. With 1M flash and 384k RAM you'll have plenty of room for your sketches. The Artemis module runs at 48MHz with a 96MHz turbo mode available and with Bluetooth to boot! The SparkFun Artemis Nano is an incredibly flexible device for a small footprint but if you're looking for all the bells and whistles, be sure to check out our RedBoard and ATP footprints for even more I/O and capabilities. Features: ● ● ● ● ● ● ● ● 19 GPIO - all interrupt capable 8 ADC channels with 14-bit precision 17 PWM channels 2 UARTs 4 I2C buses 2 SPI buses PDM Digital Microphone Qwiic Connector Documents: ● Schematic ● Eagle Files ● Hookup Guide ● Designing with the SparkFun Artemis ● Artemis Development with Arduino ● Arduino Core ● Artemis Info Page ● GitHub Hardware Repo
DEV-15443 价格&库存
很抱歉,暂时无法提供与“DEV-15443”相匹配的价格&库存,您可以联系我们找货
DEV-15443
    • 1+144.24133
