Electric Hobby Screwdriver Set
TOL-15548 ROHS
This Electric Hobby Screwdriver Set is great for dealing with small screws in a variety of applications
all enclosed in a handy plastic carrying case with magnetic lid. The real magic of this tool is the
extensive bit collection included! 55 magnetic H4 hex bits (plus an extension rod)! Also included is a
magnetic project mat to keep the screws you remove organized and prevent them from running
away!
The screwdriver has an output torque of approximately 0.25-0.35Nm, a magnetizer/demagnetizer,
and a USB charging cable for recharging the 260mAh lithium ion batt
Includes
Electric screwdriver: 0.25-0.35Nm torque
Rechargeable 240mAh lithium battery
55x H4 bits
o (H28mm): T20, T15, T10, T9, T8, T7, T6, T5, T4, T3, T2, H0.7, H0.9, H1.3, H1.5,
H2.0, H2.5, H3.0, H3.5, H4
o (H40mm): PH0, PH2, FH2.5, H2.5, H2.0
o (H28mm): PH0000, PH000, PH00, PH0, PH1, PH2, ST1.5, ST1.2, ST0.8, Y0.6, Y1.0,
Y2, Y2.5, Y3.0, TRI2.0 TRI, 2.3, TRI3.0, FH1.0, FH1.5, FH2.0, FH2.5, FH3.0, FH3.5,
U2.0, U2.6, U3.0, SQ0, SQ1, SQ2
Extension rod
Plastic storage case with magnetic lid
Magnetic project mat
Magnetizer/demagnetizer
Charging cable: USB micro-B to USB A, 50cm overall length
https://www.sparkfun.com/products/15548/9‐24‐19
