Page 1 of 2
Export Restrictions
This product has some level of export control/restriction, so may be delayed by
2-3 business days when shipping outside the United States. Contact us with
questions, or we will contact you after you place your order.
Wixel
W R L- 106 65
images are CC BY-NC-SA 3.0
Description: The Wixel is a great general-purpose module from Pololu. By taking
advantage of the feature-rich CC2511F32 microcontroller from Texas Instruments, the
Wixel provides integrated 2.4 GHz wireless communication, 32 KB of flash memory, 4
KB of RAM, full-speed USB interface and 15 general-purpose I/O lines (including 6
analog inputs). A single Wixel can be used as a computer-interface device, such as a
USB-to-serial adapter, and it can even serve as the main controller for your system.
With two or more modules you can take advantage of the Wixel’s wireless capabilities
to build wireless networks.
The Wixel features a built-in USB bootloader that can be used in conjunction with
Pololu’s free Wixel Configuration Utility software to upload custom programs or
precompiled, open-source apps to the Wixel (no external programmer is required). A
growing selection of free apps lets you turn the Wixel into whatever you need for your
current project. No programming experience or compiler software is required to use
these apps: simply download a different app to reuse the Wixel in your next project!
See the GitHub page below for the current selection of apps as well as the
configuration tool. They plan to release additional apps in the future for wireless
AVR/Arduino programming, wireless sensing, wireless motor driver interfaces, and
more.
Page 2 of 2
Note: The Wixel comes with break-away headers that can be soldered to the board.
Features:
Full-speed USB
2.4 GHz Radio with 256 available channels that can be configured dynamically
Programmable through USB bootloader (no external programmer required)
Pre-compiled, open-source apps available
Wixel SDK for developing your own applications in C using open source tools
and libraries
0.1" pin spacing (compatible with standard breadboards and 0.1" perfboards)
3 indicator LEDs
15 user I/O lines, featuring 6 analog inputs, 2 USARTs (for serial or SPI), and 7
timer channels (capable of PWM)
4 KB of RAM and 29 KB of application program memory (flash)
Dimensions: 0.7" × 1.5" (17.78mm x 38.1mm)
https://www.sparkfun.com/products/10665
11/12/2015
很抱歉,暂时无法提供与“WRL-10665”相匹配的价格&库存,您可以联系我们找货
