RC1KB68K0
RC1KB68K0
    SEI
    轴向
    68 kOhms ±10% 1W 轴向 通孔电阻器 非电感,脉冲耐受 炭化物
RC1KB68K0 数据手册
RC Series Stackpole Electronics, Inc. Carbon Composition Resistor • • • • • Features: Resistive Product Solutions Non-inductive design Molded body for package uniformity Ideal for pulse-load handling characteristics 1W now available RoHS compliant / lead-free Electrical Specifications Type / Code Power Rating (Watts) @ 70ºC Maximum Continuous Working Voltage (1) RC14 0.25W 250V 400V 500V 2.2 - 5.6M 1 - 5.6M RC12 0.5W 350V 700V 700V 1 - 22M 1 - 22M RC1 1W 500V 1,000V 1,000V Maximum Pulse Voltage Dielectric Withstanding Voltage Ohmic Range (Ω) and Tolerance 5% 10% - 2.2 - 1M (1) Lesser of √PR or maximum working voltage. Mechanical Specifications Type / Code A B C D Body Length Body Diameter Lead Length (Bulk) Lead Diameter Unit 0.248 ± 0.028 6.30 ± 0.70 0.094 ± 0.004 2.40 ± 0.10 1.181 ± 0.118 30.00 ± 3.00 0.024 ± 0.002 0.60 ± 0.05 RC12 0.374 + 0.031 / -0.028 9.50 + 0.80 / -0.70 0.142 ± 0.008 3.60 ± 0.20 1.102 ± 0.118 28.00 ± 3.00 0.028 + 0.003 / -0.002 inches 0.70 + 0.07 / -0.05 mm 0.563 ± 0.028 14.30 ± 0.70 0.224 ± 0.012 5.70 ± 0.30 1.024 ± 0.118 26.00 ± 3.00 0.035 ± 0.002 0.90 ± 0.05 RC1 Power Derating Curve: Percentage of the Rated Dissipation (%) RC14 inches mm inches mm 100 80 60 40 Area of Recommended Operation 20 0 -55 70 125 Ambient Temperature (ºC) Rev Date: 07/15/2014 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Resistance Temperature Characteristics Resistance Range -55ºC +105ºC Under 1K +2 to + 5 -4 to -2 1K to 9.1K +5 to +9 -5 to -3 10K to 91K +8 to +11 -7 to -5 100K to 910K +10 to +14 -9 to -7 1M to 10M +13 to +20 -14 to -9 Maximum % resistance change from room temperature (+25ºC) value Performance Characteristics (JISC 5201 - 1:1998) Test Test Results Test Method Voltage Proof No breakdown or flashover V-block method RC 1/4 100 VAC, 60 seconds RC 1/2 500 VAC, 60 seconds 2.5 times the rated voltage or twice the limiting element voltage, whichever is less. Severe, 5 seconds. ±2% +0.05Ω No visible damage, legible markings Tensile: ±2% +0.05Ω. No visible damage 10N for 5 - 10 seconds Termination Strength Bending: ±2% +0.05Ω. No visible damage 5N, twice Torsion: ±2% +0.05Ω. No visible damage 180ºC, two rotations Solderability In accordance with Clause 4.17.4.5 235ºC, 5 seconds After immersion into flux, the immersion into solder shall be carried ±3% +0.05Ω Resistance to Soldering Heat out 4mm from the body at 350ºC for 3.5 seconds No visible damage, legible markings ±2% +0.05Ω Temperature Shock 5 cycles between -55ºC to 125ºC No visible damage. Dry/Damp heat: 12 +12 hour cycle, first cycle Climatic Sequence ±10% +0.5Ω Cold/Damp heat: 12 + 12 hour cycle, remaining cycle D.C. load ±10% +0.5Ω 40ºC 95% relative humidity for 56 days, Damp Test, Steady State Insulation resistance: R ≥100M ohm. test a, b and c of Clause 4.24.2.1 No visible damage, legible markings ±10% +0.5Ω Endurance @ 70ºC Rated voltage, 1.5 hours ON, 0.5 hours OFF at 70ºC, 1,000 hours Insulation resistance: R ≥1G ohm. No visible damage. ±10% +0.5Ω Endurance @ 125ºC 125ºC, no load, 1,000 hours Insulation resistance: R ≥1G ohm. No visible damage. Operating Temperature Range: -55ºC to +125ºC Overload Reliability Test – Load Life in Moisture Criteria (%) ∆ R/R Load Ratio P/Pn (%) Total Testing Time (Hrs) Number of Fractures (pcs) ƛ 0 2.984 x 106 6 0.201 0.244 4.098 x 105 20 6 2.990 x 10 4 0.134 0.176 5.682 x 105 60 2.997 x 106 2 0.067 0.104 9.615 x 105 100 2.992 x 106 3 0.1 0.139 7.194 x 105 ±5 ±10 7 Failure Ratio ƛCL (60%) Average Lifetime (60% reliability level) (Hrs) Total 1.196 x 10 15 0.125 0.138 7.209 x 105 Total 1.2 x 107 0 0.0055 0.0077 1.299 x 107 Rev Date: 07/15/2014 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions Technical Guide: 1. Storage Conditions: Temperature: 5 to 35ºC (40 to 95ºF) Humidity: 25 – 60% relative humidity Term: One year in poly-bag with desiccant. If parts are removed from the poly-bag, they should be used immediately or resealed in the bag. Environment: Clean, dry environment, free of corrosive gases 2. Application precautions: Lead forming: Forming is recommended at least 2mm of farther from the base of the lead Soldering: Soldering is recommended at least 4mm or farther from the base of the lead 3. Washing: Carbon composition resistors are highly hygroscopic and changes in resistance value can occur if too much moisture is absorbed. For this reason it is recommended not to use water or water-soluble solvents to clean these components. Alcohol or hydrocarbon solvents are recommended for rinsing. 4. Soldering Recommendations: Note: The conditions shown below are for reference. Please perform a mounting evaluation to assure compatibility. a. Flow soldering (recommended profile for Sn and Sn/Pb solders) b. Soldering iron (recommended for Sn and Sn/Pb solders) Temperature of soldering tip: 300ºC, duration: 10 sec. max. Temperature of soldering tip: 350ºC, duration: 3 sec. max. Other: 1. Evaluate and confirm the compatibility of your assembly process with this product. 2. Refer to the catalog, the product news, and the specifications for details on the RC series resistors. 3. If you have any questions, please contact our sales staff. Rev Date: 07/15/2014 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com RC Series Stackpole Electronics, Inc. Carbon Composition Resistor Resistive Product Solutions How to Order RC 1 2 3 4 5 6 7 8 9 10 R C 1 2 J T 5 M 6 0 Product Series Carbon Comp Size Power Rating 0.25W 14 0.5W 12 1W 1 Code J K Tolerance Tol Value 5% E24 10% Code T B Packaging Description Size 14, 12 Tape and Reel Bulk All Sizes Resistance Value Quantity 5,000 1,000 Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 10 Kohm = 10K0 1 Mohm = 1M00 Rev Date: 07/15/2014 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com
RC1KB68K0 价格&库存
很抱歉,暂时无法提供与“RC1KB68K0”相匹配的价格&库存,您可以联系我们找货
