Wireless universal transmitter
RF I/O SW915-4E
Material number: 1432305
Features/Options
No wiring and pipe laying required
Power supply by Lithium battery
Easy programming of receiver
Output signal can be individually configurated at the receiver
Thermoplastic enclosure
sWave® wireless technology
Note
The RF I/O may be used in combination with an wireless inductive
sensor RF IS
Connection of external switching contact (potentialfree contact) with
gold contacts possible.
Delivery does not include protective caps.
Dimensions
Technical Data
Standards
Enclosure
Connection
Degree of protection
Wireless protocol
Ambient temperature
Operation cycles
Switching frequency
Standby current
Voltage supply
Nominal voltage
Capacity
Frequency
Transmission power
Data rate
Channel bandwidth
Sensing range
Battery life
Actuating time
Approvals
Pin-assignment
Note
Colour coding only valid for
Coupling 4-poles mat. no. 1215497 and
Coupling 4-poles mat. no. 1262873
Created: 25.11.2016 Pe
page
1/2
Lithium battery Tadiran SL-760
(Europe); TL-5903 (North America)
system Li/SOCl2; (replaceable)
3.6 V
2.2 Ah
915 MHz (USA, Canada and Australia)
< 10 mW
66 kbps
400 kHz
max. 450 m outside,
max. 40 m inside
depending on the switching frequency
and number and type of sensors
for 1000 transfers/day and one
inductive sensor approx. 300 days;
mechanical switch approx. 1400 days
min. 80 ms
USA: FCC: XK5-RFRXSW915;
Canada: IC: 5158A-RFRXSW915
Transmission of battery voltage;
status signal: individually
adjustable via jumper, no, 10 s,
100 s, 1000 s, 10 000 s
Errors and omissions excepted.
Status:
steute Schaltgeräte
GmbH & Co. KG
EN 60947-5-1; EN 61000-6-2, -6-3,
EN 61000-4-2, -4-20;
EN 301 489-1; EN 301 489-3;
EN 300 220-1; EN 300 220-2
ABS (Acrylnitril-Butadien-Styrol)
4 x Plug-in connector M12 x 1; 4-pole
IP 67 to IEC/EN 60529
sWave®
20 °C +65 °C
approx. 12000 telegrams at
repetitions/h
max. 5 Hz
60 A
Brückenstraße 91
32584 Löhne, Deutschland
Revision: phone +49 (0) 5731 745-0
fax +49 (0) 5731 745-200
info@steute.com
www.steute.com
RF I/O SW915-4E
Features/Options
Note
sensor RF IS
Sensors
External switch contact
page
2/2
Status:
steute Schaltgeräte
GmbH & Co. KG
Brückenstraße 91
info@steute.com
www.steute.com
很抱歉,暂时无法提供与“STE-1432305RFIO”相匹配的价格&库存,您可以联系我们找货
