4548HQ/EG50040S1-CG61-S9A 数据手册
SUNON
SPECIFICATION FOR APPROVAL
CUSTOMER
DESCRIPTION
: DC BRUSHLESS Fan
DIMENSIONS
: 61.28X52.75X5.55 mm
MODEL
: EG50040S1-CG61-S9A
SUNON SPEC. NO.
: D05071870F-00
CUSTOMER
APPROVAL NO.
APPROVED BY
CUSTOMER
(AUTHORIZED)
DRAWN
Nancy
01/16
CHECKED
Dolphin
APPROVED
Dolphin
SPEC.NO
ISSUE DATE
EDITION
D05071870F-00
01.16.2020
REVISION DATE
E.SPEC
E11900551
建準電機工業股份有限公司
SUNONWEALTH ELECTRIC MACHINE INDUSTRY CO., LTD.
NO. 30, LN. 296, XINYA RD., QIANZHEN DIST.,
TEL:886-7-8135888
KAOHSIUNG CITY 80673, TAIWAN (R.O.C)
FAX:886-7-8230505/8230606/8231010
URL:http://www.SUNON.com
E-mail: SUNON@email.SUNON.com.tw
建準電機
SUNONWEALTH
Page 1 of 17
D.C.C.
2020.01.20
I. MODEL NUMBERING SYSTEM
50
EG
04
S
Voltage
Series Code
- CG61 -
S9A
Speed
0: 5VDC
X:Super High
1: 12VDC
1: High
2: 24VDC
2: Medium
3: 36VDC
3: Low
4: 48VDC
4: Extra Low
Function Code
Customer Code
Bearing
V: Vapo
B: 2 Ball
O: 1Ball
S: Sleeve
Size
編碼 尺寸(mm)
Thickness
編碼 尺寸(mm)
編碼 尺寸(mm)
編碼 尺寸(mm)
01~09
01~09
A0~A9
100~109
K0~K9
200~209
V0~V9
300~309
10~19
10~19
B0~B9
110~119
L0~L9
210~219
W0~W9
310~319
20~29
20~29
C0~C9
120~129
M0~M9
220~229
X0~X9
320~329
30~39
30~39
D0~D9
130~139
N0~N9
230~239
Y0~Y9
330~339
40~49
40~49
E0~E9
140~149
P0~P9
240~249
Z0~Z9
340~349
50~59
50~59
F0~F9
150~159
Q0~Q9
250~259
60~69
60~69
G0~G9
160~169
R0~R9
260~269
70~79
70~79
H0~H9
170~179
S0~S9
270~279
80~89
80~89
I0~I9
180~189
T0~T9
280~289
90~99
90~99
J0~J9
190~199
U0~U9
290~299
建準電機
SUNONWEALTH
Page 2 of 17
D.C.C.
2020.01.20
II. SPECIFICATION
1. MECHANICAL CHARACTERISTIC
MOTOR DESIGN
3 phases, 4-poles Brushless DC motor
BEARING SYSTEM
Lubricated Sleeve Bearing System
DIMENSIONS
See Page 6
MATERIALS OF COVER
SUS301 3/4H
MATERIALS OF HOUSING
SECC+Thermoplastic PBT of UL 94V-0
MATERIALS OF FAN BLADE Thermoplastic LCP of UL 94V-0
DIRECTION OF ROTATION
Clockwise viewed from front of fan blade
MOUNTING HOLES
Diameter 2.3 mm in 2 holes; 2.5 mm in 1 hole
WEIGHT
17 g
2. ELECTRIC CHARACTERISTIC
RATED VOLTAGE
5 VDC
RATED CURRENT
400 mA / MAX. 440 mA
RATED POWER CONSUMPTION
2.00 WATTS / MAX. 2.20 WATTS
SAFETY POWER CONSUMPTION
2.25 WATTS
OPERATING VOLTAGE RANGE
2.5~5 VDC
STARTING VOLTAGE
2.5 VDC (25 deg. C POWER ON/OFF)
OPERATING TEMPERATURE RANGE
-10 to + 70 deg. C
STORAGE TEMPERATURE RANGE
-40 to + 70 deg. C
建準電機
SUNONWEALTH
Page 3 of 17
D.C.C.
2020.01.20
3. PERFORMANCE CHARACTERISTIC
RATED SPEED
7200 RPM ± 7% at rated voltage
AIR FLOW
2.7 CFM / Min. 2.4 CFM
STATIC PRESSURE
0.81 Inch-H2O / MIN. 0.63 Inch-H2O
ACOUSTIC NOISE
39.9 dB(A) / MAX. 43.8 dB(A) @ 0.5M
33.9 dB(A) / MAX. 37.8 dB(A) @ 1M
AIR FLOW V.S. PRESSURE
See Page 5
INSULATION CLASS
UL Class A
INSULATION RESISTANCE
10M ohm at 500 VDC between internal stator and
Lead wire (+)
PLASTIC HOUSING
DIELECTRIC STRENGTH
Applied AC 500 V for one minute or AC 600 V for 2
Seconds between housing and lead wire (+)
LIFE EXPECTANCY
35,000 Hours at 40 deg. C, 65% humidity, 90% CL.
Automatic Restart
PROTECTION
Note: The motor will shut down when rotor was locked, then
auto restart within 10 seconds.
Polarity Protection
4. SAFETY
SAFETY
NO.
UL
CUR
E77551
E77551
建準電機
SUNONWEALTH
Page 4 of 17
TUV
CE
D.C.C.
2020.01.20
MODEL : EG50040S1-CG61-S9A
AIR FLOW & STATIC PRESSURE CURVE
25.40
0.9
1
1.0
20.32
0.8
0.8
0.7
25.4
111.76
0.6
15.24
0.6
10.16
0.4
0.5
0.5
0.4
83.82
55.88
12.7
0.3
5.08
0.2
0.2
27.94
0.1
Inch-H2O
mm-H2O
0.00
0.0
1.2
1.8
2.4
0.034
0.051
0.068
建準電機
SUNONWEALTH
Page 5 of 17
5
CFM
0.085 m3/min
D.C.C.
2020.01.20
DIMENSIONS
UNIT:mm
建準電機
SUNONWEALTH
Page 6 of 17
D.C.C.
2020.01.20
LABEL
建準電機
SUNONWEALTH
Page 7 of 17
D.C.C.
2020.01.20
FAN 3rd WIRE SIGNAL
F Type (Frequency Generator)
建準電機
SUNONWEALTH
Page 8 of 17
D.C.C.
2020.01.20
PWM INPUT SIGNAL
建準電機
SUNONWEALTH
Page 9 of 17
D.C.C.
2020.01.20
【FOR REFERENCE】
DUTY CYCLE & SPEED CURVE
建準電機
SUNONWEALTH
Page 10 of 17
D.C.C.
2020.01.20
III. OTHER SPECIFIED TESTING
The following is a general description of certain tests that are performed on representative
SUNON fans. Nothing in this document is intended to suggest that these tests are
performed on every model of SUNON fan. Moreover, the descriptions that follow each
test are meant only to provide a general explanation of each test. If you would like a more
detailed explanation as to any test identified in this Section, SUNON can provide such an
explanation upon request.
1.
DROP PROOF TEST
Fans are packaged in a standard size shipping box and are dropped to the ground from
certain heights and angles depending on the weight of the particular box.
2.
HUMIDITY PROOF TEST
The fan is operated for 96 continuous hours in an environment with humidity of 90% to
95% RH at 60°C ± 2°C.
3.
VIBRATION PROOF TEST
Vibration with an amplitude 2mm and a frequency of 5-55-5hz is applied in all 3
directions (X,Y,Z), in cycles of 1 hour each, for a total vibration time of 3hours.
4.
THERMAL CYCLING TEST
The fan is operated in a testing chamber for 50 cycles. In each cycle, the temperature is
gradually increased from -10°C to 70°C for 90 minutes, and subsequently operated at
70°C for 120 minutes. The temperature is then gradually decreased from 70°C to -10°C
for 90 minutes, and subsequently operated at -10°C for 120 minutes.
5.
SHOCK PROOF TEST
100G of force is applied in the 3 directions (X,Y, and Z) for 2 milliseconds each.
6.
LIFE EXPECTANCY
The “Life Expectancy” of SUNON fans is determined in SUNON’s reliability test
laboratory by using temperature chambers. The “Life Expectancy” of this fan has not been
evaluated for use in combination with any end application. Therefore, the Life Expectancy
Test Reports (L10 and MTTF Report) that relate to this fan are only for reference.
建準電機
SUNONWEALTH
Page 11 of 17
D.C.C.
2020.01.20
IV. CHARACTERISTIC DEFINITION
representative SUNON fans in order to determine the specifications of the fan. Nothing
in this document is intended to suggest that these tests are performed on every model of
SUNON fan. Moreover, the descriptions that follow each test are meant only to provide
a general explanation of each test. If you would like a more detailed explanation as to
any test identified in this Section, SUNON can provide such an explanation upon
request.
1. ACOUSTICAL NOISE
Measured in a semi-anechoic chamber with background noise level below 15dB(A).
0.5 METER FROM MICROPHONE TO FAN INTAKE
The fan is running in free air under shaft horizontal condition with the microphone at
distance of 0.5 meter from the fan intake.
2. INPUT POWER
Measured after continuous 10 minute operation at rated voltage in clean air
( STATIC PRESSURE=0), and at ambient temperature of 25 degrees C under shaft
horizontal condition.
3. RATED CURRENT
建準電機
SUNONWEALTH
Page 12 of 17
D.C.C.
2020.01.20
4. RATED SPEED
5. STARTING VOLTAGE
Measured the voltage which enables to start the fan in the clean air (static pressure = 0 )
by switching on at the voltage under shaft horizontal condition. It is not at continuously
increasing voltage adjustment.
6. LOCKED ROTOR CURRENT
Measured immediately after the fan blade is locked.
7. AIR FLOW AND STATIC PRESSURE
The performance specification of air flow and static pressure shown in this specification for
approval is measured using the exhaust method. A double chamber is used in accordance
with AMCA 210 standard or DIN 24163 specification . The values are recorded when the
fan speed has stabilized at rated voltage.
8. INSULATION RESISTANCE
1. PLASTIC HOUSING:
(1) Measured between internal stator and lead wire(+).
(2) Measured between housing and lead wire(+).
2. ALUMINIUM HOUSING:
9. DIELECTRIC STRENGTH
Measure between housing and lead wire(+).
建準電機
SUNONWEALTH
Page 13 of 17
D.C.C.
2020.01.20
V.NOTE
Ⅰ.SAFETY
1. DO NOT use or operate this fan in excess of the limitations set forth in this
specification. SUNON is not responsible for the non-performance of this fan and/or
any damages resulting from its use, if it is not used or operated in accordance with
the specifications.
2. SUNON recommends adding a protection circuit to the product or application in
which this fan is installed, such as a thermo-fuse, or current-fuse or thermo-protector.
The failure to use such a device may result in smoke, fire, electric shock by
insulation degradation in cases of motor lead short circuit, overload, or over voltage,
and/or other failure.
3. SUNON recommends installing a protection device to the product or application in
which this fan is installed if there is a possibility of reverse-connection between
VDC (+) and GND (-). The failure to install such a device may result in smoke, fire,
and/or destruction, although these conditions may not manifest immediately.
4. This fan must be installed and used in compliance with all applicable safety standards
and regulations.
5. Use proper care when handling and/or installing this fan. Improper handling or
installation of this fan may cause damage that could result in unsafe conditions.
6. Use proper care during installation and/or wiring. Failure to use proper care may
cause damage to certain components of the fan including, but not limited to, the coil
and lead wires, which could result in smoke and/or fire.
7. DO NOT use power or ground PWM to control the fan speed. If the fan speed needs
to be adjusted, please contact SUNON to customize the product design for your
application.
8. For critical or extreme environments, including non stop operation, please contact
SUNON and we will gladly provide assistance with your product selection to ensure
an appropriate cooling product for your application.
建準電機
SUNONWEALTH
Page 14 of 17
D.C.C.
2020.01.20
II.
SPECIFICATION MODIFICATION
1. SUNON offers engineering assistance on fan installation and cooling system design.
2. All changes, modifications and/or revisions to the specifications, if any, are
incorporated in the attached specifications.
3. No changes, modifications and/or revisions to these specifications are effective absent
agreement, by both SUNON and the customer, in writing.
4. This fan will be shipped in accordance with the attached specification unless SUNON
and the customer have agreed otherwise, in writing, as specified in Paragraph 3, above.
III.
OTHER
1. When building your device, please examine thoroughly any variation of EMC,
temperature rise, life data, quality, etc. of this product by shock/drop/vibration testing, etc.
If there are any problems or accidents in connection with this product, it should be
mutually discussed and examined.
2. Use proper care when handling this fan. Components such as fan holders or bearings
may be damaged, if touched with fingers or other objects. Additionally, static electricity
(ESD) may damage the internal circuits of the fan.
3. DO NOT operate this fan in proximity to hazardous materials such as organic silicon,
cyanogens, formalin, phenol, or corrosive gas environments including, but not limited to,
H2S, SO2, NO2, or Cl2.
4.
SUNON recommends that you protect this fan from exposure to outside elements such as
dust, condensation, humidity or insects. Exposure of this fan to outside elements such as
dust, condensation, humidity or insects may affect its performance and may cause safety
hazards. SUNON does not warrant against damage to the product caused by outside
elements.
Re: The term can be excluded, if the fan has been with IP design and meets customer's
IP requirement.
建準電機
SUNONWEALTH
Page 15 of 17
D.C.C.
2020.01.20
5. This fan must be installed properly and securely. Improper mounting may cause harsh
resonance, vibration, and noise.
6. Fan guards may prevent injury during handling or installation of the fan and are
available for sale with this fan.
7. Unless otherwise noted, all testing of this fan is conducted at 25°C ambient temperature
and sixty-five percent (65%) relative humidity.
8. DO NOT store this fan in an environment with high humidity. This fan must be stored
in accordance with the attached specifications regarding storage temperature. If this
fan is stored for more than 6 months, SUNON recommends functional testing before
using.
9. SUNON reserves the right to use components from multiple sources at its discretion.
The use of components from other sources will not affect the specifications as
described herein.
10. The “Life Expectancy” of this fan has not been evaluated for use in combination with
any end application. Therefore, the Life Expectancy Test Reports (L10 and MTTF
VI. WARRANTY
This fan is warranted against all defects which are proved to be fault in our
workmanship and material for one year from the date of our delivery. The sole
responsibility under the warranty shall be limited to the repair of the fan or the
replacement thereof, at SUNON’s sole discretion. SUNON will not be responsible for
the failures of its fans due to improper handing, misuse or the failure to follow
specifications or instructions for use. In the event of warranty claim, the customer shall
immediately notify SUNON for verification. SUNON will not be responsible for any
consequential damage to the customer’s equipment as a result of any fans proven to be
defective.
建準電機
SUNONWEALTH
Page 16 of 17
D.C.C.
2020.01.20
Declaration of Restricted Materials
Control declaration of environment- related substances/ materials
1. In accordance with the Restriction of Hazardous Substances (RoHS) Directive
2011/65/EU and specific market requirements, SUNON Halogen-Free Product
have complied with law and discipline not to employ the forbidden substances,
and restrict the allowable concentration of some limited substances
deliberately in our components.
No Substance
CFCs & HCFCs (ozone depleting substances)
1
Chlorinated Organic Solvent
2
Plastic (Frame, Impeller, wire harness, etc.)
Solder
Lead and its compounds Steel alloy
3
Aluminium alloy
Copper alloy
Solder
Cadmium and its
Parts composed of metals containing zinc
4
compounds
(e.g. brass, zinc for die casting)
Plastic
PBBs
and
PBDEs
5
PCB and PCT
6
CP, Short-chain Chlorinated paraffins C10-13, Cl ≥48 wt%
7
Mirex
8
PCN
9
10 Hexavalent Chromium compounds
11 Mercury and its compounds
12 Asbestos
13 Organic Tin compounds
14 Azo compounds
15 TBBP-A in external case plastic parts of products (PCB is exempted)
16 Nickel in external case parts, which are likely to result in prolonged skin exposure
17
18
19
22
Hexabromocyclododecane (HBCDD)
Di-butyl Phthalate (DBP)
Benzyl butyl Phthalate (BBP)
Di-ethylhexyl Phthalate (DEHP)
Di-isobutyl Phthalate (DIBP)
Brominated/chlorinated flame retardants (other than PBBs or PBDEs),
applicatable item: frame, bobbin, impeller, lear wire, connector, mylar
insulator.
23
PAHs and its 16 compounds in unusual contact material
24
PCB and electroplating material, PFOS content complianced with
2006/122/EC
建準電機
SUNONWEALTH
Page 17 of 17
Criteria
Forbidden
Forbidden
