ND100A
ND100A
    SUPERIORSENSOR
    SMD11,NoLead,TopPort
    ND ABSOLUTE PRESSURE SENSOR 100
ND100A 数据手册
ND Series Absolute Middle Pressure Sensors Industrial Applications                Highly integrated sensor with ADC and DSP Pressure ranges 15 psia (1034 mbar) to 150 psia (10.3 bar) 16-bit resolution Exceptional Zero Stability Integrated 50/60Hz Notch Filter Selectable Bandwidth Filter from 1.0Hz to 200Hz Output Data Rate at 444Hz Total Error Band less than 0.15% FSS Very High Accuracy +/- 0.1% of Selected Range Long Term Stability +/- 0.1% FSS Silicone gel protection on all models Temperature Compensated -20°C to 85°C Supply Voltage Compensation Fully Integrated Compensation Math Standard I2C and SPI Interface Product Summary Industry leading accuracy ‐ The ND Absolute Middle Pressure Series provides accuracy better than 0.10% FS and Total Error Band is also industry leading, typically better than 0.15% FSS. Based on Superior’s market leading, proprietary NimbleSense™ architecture, the ND Absolute Middle Pressure Series family supports operating temperature from to -20°C up to 85°C. Supporting pressure ranges as low as 15 psia (1.03 Bar) to as high as 150 psia (10.3 Bar), the ND Absolute Middle Pressure Series is ideal for a wide variety of applications where there is a need to measure air and gas pressures against absolute zero pressure. The ND Series has a selectable bandwidth filter from 1Hz to 200Hz, and exceptional zero stability. For added performance, the ND Series has incorporated a 50/60Hz notch filter to minimize the impact of power noise spikes. The ND Series is an excellent choice for applications requiring the utmost reliability, with longterm stability of 0.1% FSS within the first year. Finally, the Middle Pressure ND Sensors incorporate silicone gel to protect the sensor from any mechanical or thermal stress during field use. The ND Series provides a new level of integration combining an advanced piezoresistive sensing element with integrated amplification, ADC, DSP and a digital interface to significantly simplify customer integration efforts. Advanced digital processing enables new functionality thus streamlining system development, adding manufacturing ease and increasing reliability. Constructed with a high reliability plastic enclosure, the ND Series family provides the ideal combination of very high performance and reliability at extended temperature ranges while ensuring customers have a high-volume, cost-effective solution optimized for a wide array of industrial requirements. With true 16-bit output, the ND Absolute Middle Pressure Series measures dry air and non-aggressive gas pressure with very high accuracy. Non-linearity is also outstanding, typically within 0.1% FS. www.SuperiorSensors.com 1 ND Series Industrial Absolute Middle Pressure Sensors Table of Contents 8 9 10 11 12 13 14 15 Maximum Ratings ................................................................ 2 Suggested Operating Conditions ......................................... 2 Environmental ..................................................................... 2 Equivalent Circuit................................................................. 2 Feature List .......................................................................... 3 Performance Characteristics ............................................... 4 Electrical Characteristics ...................................................... 4 7.1 Supply Characteristics................................................. 4 7.2 Reset Characteristics .................................................. 5 7.3 DAV Characteristics .................................................... 5 7.4 I2C Characteristics ....................................................... 5 7.5 SPI Characteristics ...................................................... 6 Materials.............................................................................. 6 8.1 Wetted Materials........................................................ 6 8.2 Material Compliance .................................................. 6 System Overview ................................................................. 7 Interface .............................................................................. 8 10.1 Reset ........................................................................... 8 10.2 Communication Interface Selection ........................... 8 10.3 SPI Interface................................................................ 8 10.4 I2C Interface ................................................................ 9 10.4.1 I2C Address ....................................................... 9 10.4.2 I2C Communications Model ............................. 9 10.4.3 I2C Clock Stretching ........................................ 10 10.4.4 I2C Bus Compatibility ...................................... 10 10.5 Extended Data Acquisition ....................................... 10 10.5.1 Available Extended Data ................................ 10 10.5.2 SPI Extended Data Read ................................. 10 10.5.3 I2C Extended Data Read ................................. 11 10.6 Control Registers ...................................................... 11 10.6.1 Mode Control Register ................................... 11 10.6.2 Rate Control Register ..................................... 12 10.7 Computing Pressure ................................................. 12 Mechanical and Manufacturing......................................... 13 11.1 Package Dimensions ................................................. 13 11.2 Suggested Pad Layout ............................................... 13 11.3 Pinout ....................................................................... 14 11.4 Reflow Soldering and Handling Conditions .............. 14 11.5 Pick and Place Pick-up Zone ..................................... 14 11.6 Packaging Options .................................................... 15 11.6.1 Tray Packaging ............................................... 15 11.6.2 Tape and Reel ................................................ 16 11.7 Part Identification ..................................................... 16 Packaging Labeling............................................................. 17 Ordering Information ........................................................ 17 Revisions ............................................................................ 18 Warranty............................................................................ 18 www.SuperiorSensors.com Sym Min Max Units Supply Voltage VDDM Gnd-0.3 4.0 V Voltage on I/O Pins VDD > 3.3V VDD ≤ 3.3V VIOML VIOMH Gnd-0.3 Gnd-0.3 5.8 VDD+2.5 V V IIOM -25 25 mA Parameter I/O Current 2 Suggested Operating Conditions Sym Min Max Units VDDOP 2.8 3.5 V TA -20 85 °C Parameter Supply Voltage Temperature 3 Environmental Parameter Sym Min Max Units Temperature Range Compensated Operating Storage TCMP TOP TSTG -20 -20 -40 85 85 85 °C °C °C Humidity (Non-condensing) RHOP 0 95 % RH Vibration (10Hz-2kHz) GVIBE - 15 g Shock (6 ms) GSHOCK - 100 g Life CYLIFE 10M - Pressure Cycles 4 Equivalent Circuit DAV DAV Not Used PABS nRST Port A Port B MISO/SDA Sensor (SPI) MOSI/SCL SCK nSS 2 Not Used Port A PABS Port B nRST MISO/SDA Sensor (I2C) MOSI/SCL SCK nSS VDD VDD Gnd Gnd VI2C Address FIG-0124A 1 2 3 4 5 6 7 1 Maximum Ratings ND Series Industrial Absolute Middle Pressure Sensors 5 Feature List Middle Pressure Absolute (psia Ranges) Parameter FS Pressure Range Sym ND015A ND030A ND060A Units PFSR 0 to 15 0 to 30 0 to 60 psia Notes Number of BW Filter Corners BWNUM 8 Each BW Corner Frequency Extents fBWEXT 1.0 to 200 Hz Proof Pressure PPROOF 35 100 150 psia 1 Burst Pressure PBURST 40 125 175 psia 2 Sym ND100A ND150A Units PFSR 0 to 100 0 to 150 psia Middle Pressure Absolute Cont'd (psia Ranges) Parameter FS Pressure Range Notes Number of BW Filter Corners BWNUM 8 Each BW Corner Frequency Extents fBWEXT 1.0 to 200 Hz Proof Pressure PPROOF 200 250 psia 1 Burst Pressure PBURST 250 300 psia 2 1) Pressure at which the sensor will not suffer permanent damage. 2) Pressure if exceeded could cause permanent damage to the sensor. 3 ND Series Industrial Absolute Middle Pressure Sensors 6 Performance Characteristics Note: Unless otherwise specified, characteristics specified with VDD = 3.3V, TA = 25C All Series Devices Parameter Sym Units Min Typ Max Notes Accuracy PACC - 0.1 0.25 % FS 1 Total Error Band TEB - 0.15 0.5 % FS 2 Long Term Stability LTS - 0.1 0.25 % FS/YR1 6 Thermal Hysteresis THYS - 0.1 - % FS Pressure Hysteresis PHYS - 0.05 - % RNG Supply Rejection PSR - 0.0005 - % FS/mV Resolution RES - 16 - bit 3 System ENOB ENOB - 16.5 - BitRMS 4 Data Update Rate fUPDATE 432 444 456 Hz 5 1 1) Percentage of selected range. 2) Includes errors of offset, span, hysteresis and thermal effects. 3) Each selected range has the specified resolution 4) ENOB stated for fBW set to 1.0 Hz. 5) The internal update rate is fixed and does not change with range or filter settings. Sampling at lower data rates are possible provided the Nyquist frequency is observed. It is suggested to sample at least 3x the set fBW frequency. 6) YR1 is the first year. The most significant drift occurs during the first year and is lessened for each subsequent year. For each subsequent year, use 25% of the prior years' drift figure to estimate the drift for that specific year. 7 Electrical Characteristics 7.1 Supply Characteristics Parameter Sym All Series Devices Min Typ Max Units Supply Current IDD - 5.0 5.5 mA Supply Capacitance CDD - 10 - uF Notes 1 1) Supply capacitance is provided within the part however it is recommended to include a 0.1 uF decoupling cap near the supply pads. www.SuperiorSensors.com 4 ND Series Industrial Absolute Middle Pressure Sensors 7.2 Reset Characteristics Min All Series Devices Typ Max Rising Voltage on VDD Falling Voltage on VDD 0.75 1.4 - 1.36 V V tIOD From POR or External Reset - - 40 ms First Response Settling Time tFRD From POR or External Reset - - 80 ms External Reset Low tRSTL 15 - - us Input High Voltage VIH VDD-0.6 - - 2 Input Low Voltage VIL - - 0.6 2 Internal Pull-Up Current IPU - -20 -30 uA 2 Input Capacitance CIN - 7 - pF 2 Min All Series Devices Typ Max Units Notes Parameter Sym Power-On Reset Threshold VPORR VPORF Interface Detect Delay Condition VIN = 0V Units Notes 1 1) The filter settling time to ensure the first reading is completely settled. 2) Input nRST 7.3 DAV Characteristics Parameter Sym Condition Output High Voltage VOH IO = -3 mA VDD-0.7 - - V Output Low Voltage VOL IO = 8 mA - - 0.6 V Min All Series Devices Typ Max 7.4 I2C Characteristics Parameter Sym SCL Clock Frequency fSCL 100 - 250 kHz Clock Stretch Time tCKSTR - 15 100 us Input High Voltage VIH VDD-0.6 - - Input Low Voltage VIL - - 0.6 Output Low Voltage VOL - - 0.6 V Input Capacitance CIO - 7 - pF www.SuperiorSensors.com Condition IO = 8 mA 5 Units Notes ND Series Industrial Absolute Middle Pressure Sensors 7.5 SPI Characteristics Min All Series Devices Typ Max IO = -3 mA VDD-0.7 - IO = 8 mA - VIH Input Low Voltage VIL Internal Pull-Up Current IPU Time nSS to First SCK Edge Parameter Sym Output High Voltage VOH Output Low Voltage VOL Input High Voltage Condition Units Notes - V 1 - 0.6 V 1 VDD-0.6 - - 2, 3 - - 0.6 2, 3 - -10 -30 uA tSC 100 - - us Clock Cycle Time tCC 6 - - us Byte to Byte Cycle Time tBC 100 - - us Time Last Clock to nSS High tCN 20 - - us Cycle Time nSS tCS 6 - - us Input Capacitance CIN - 7 - pF VIN = 0V 1) Output MOSI 2) Inputs MISO, SCK, nSS 3) Inputs are 5V compliant. 8 Materials 8.1 Wetted Materials Parameter Wetted Materials All Series Devices PA PB Sym MATWET Not Used Units Notes Units Notes Epoxy Nylon RTV Silicon Gold Sil-Gel 8.2 Material Compliance Sym All Series Devices RoHS REGRoHS RoHS Compliant REACH REGREAC REACH Compliant Parameter www.SuperiorSensors.com 6 2, 3 2 ND Series Industrial Absolute Middle Pressure Sensors 9 System Overview The ND Series pressure sensor is a fully integrated pressure acquisition system in a sensor module. The acquisition system includes anti-alias filters, data acquisition, 50/60Hz notch filter, sensor compensation, bandwidth limiting and I/O functions. Refer to the figure below for the ND Series block diagram. Block Diagram User Control Registers Pressure Sensor Anti-Alias Filter Mode Control Δ-Sigma Modulator 1b Va Anti-Alias Filter 3b BW Control HW Interface Rate Controller Δ-Sigma Modulator Decimation To Enable Rate Control 4 50/60Hz Notch (Sinc1) 4 Compensation FPU with Linearization 4 BW Limit IIR (2nd Order) SPI/I2C Interface DAV nRST MISO/SDA MOSI/SCL SCK nSS SAR ADC 26 Term Compensation Coefficients SAR ADC FIG-0125A Vs MCU There are also two user controlled registers that tune the sensor to the specific user requirements. The first register is the Mode Control register that determines the output pressure range, the corner frequency of the bandwidth limiting filter and enables or disables the 50/60Hz notch filter. www.SuperiorSensors.com Rate Control Register Reload Value Internal Update (fUPDATE) Down Counter Zero Data Read 7 S R Q DAV FIG-0012B The second register is the Rate Control register which controls the rate at which the Data Available (DAV) pin is asserted. The internal sensor data update rate of 444 Hz is often much faster than industrial requirements so the Rate Control register can throttle down the rate at which the Data Available pin (DAV) is asserted. The DAV is reset upon each read of the pressure sensor. An internal model of the Rate Controller is illustrated in the figure to the right. ND Series Industrial Absolute Middle Pressure Sensors 10 Interface 10.1 Reset Reset timing is shown in the diagram below. The communications method (SPI or I2C) is established during the time just after reset. During this time (tIOD), no communications should take place. Also, the internal filters are settling during the time tFRD and data acquired during this time may not be fully settled. Reset Timing Diagram VPORR VDD VPORF Internal Reset tRSTL _RST tIOD Communications Available tIOD tFRD tFRD FIG-0021A Filters Settled 10.2 Communication Interface Selection The communications interface is selected by interrogating the nSS pin after the internal power on reset delay. If nSS is high, the SPI interface will be selected otherwise (if low) the I2C interface will be selected. Grounding the nSS pin is an acceptable method for selecting the I2C interface. NOTE: The I2C interface supports 10 interface addresses. Refer to section 10.4.1 for the details on I2C address selection. 10.3 SPI Interface The SPI interface uses a 16 bit transfer for all communications. Data is MSB first for both MOSI and MISO data transfers. Refer to the figure below for specific timing requirements. SPI Timing Diagram ts c tcc tbc tcn tcs SCK MOSI Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 MISO Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 FIG-0013A nSS The data communication has been reduced to a simple 16 bit transfer model for reading the pressure output. Each communication cycle consists of master sending the Mode and Rate data to be placed into the sensor Mode Register and Rate Registers respectively. Simultaneously, the sensor sends the pressure data for the master to receive. Refer to the figure below for the data communication model of the ND Series sensor. www.SuperiorSensors.com 8 ND Series Industrial Absolute Middle Pressure Sensors The requirement to send the Mode and Rate bytes on each data read cycle is intentional. The purpose is to force the master to send specific data for each communication and prevent inadvertent data from being sent to the sensor. Since a SPI interface will generally re-circulate data through its shift register, the intention is to prevent the pressure output from the sensor from being re-circulated back to the sensor and potentially causing unintended corruption of the intended mode register. SPI Data Diagram SCK MOSI User Mode Byte User Rate Byte MISO Pressure Output High Byte Pressure Output Low Byte FIG-0014A nSS 10.4 I2C Interface The ND Series is compatible with the I2C protocol. For detailed information regarding the I2C protocol, please refer to the Philips I2C Bus Specification, Version 2. 10.4.1 I2C Address I2C Address Selection Table Address Address (decimal) (hex) 5.6 49 0x31 12 48 0x30 27 47 0x2F 51 46 0x2E 100 45 0x2D 100 44 0x2C 100 43 0x2B 100 42 0x2A 100 41 0x29 NoPop 40 0x28 R1 (kΩ) R2 (kΩ) 120 120 120 120 120 56 30 15 5.6 0 The I2C address is set to 0x28 by grounding the SCK line. Other I2C addresses can be established by applying a voltage to the SCK line by use of a resistor divider across the sensor supply voltage. The suggested resistor values and the respective I2C address are shown in the table to the left. Note: R1 is the lower resister of the divider where R2 is the upper resistor of the divider. 10.4.2 I2C Communications Model The sensor is configured as a slave device and as such, the communicating host must be configured as a master. There are two types of possible data transfers, data transfers from the master transmitter to an addressed sensor (WRITE), and data transfers from an addressed sensor to a master receiver (READ). The master device initiates both types of data transfers and provides the serial clock pulses on SCL. The communications model for I2C is similar to that of SPI however, since I2C is a half-duplex protocol, the transfer of information to and from the sensor is separated into two separate communications. This is in contrast to the SPI interface where the transmitted and received data occurs simultaneously to and from the host. Refer to the figure to the right for the data communication model for the ND Series sensors. www.SuperiorSensors.com 9 ND Series Industrial Absolute Middle Pressure Sensors 10.4.3 I2C Clock Stretching The figure to the right illustrates the I2C clock stretching by the sensor. At times, the sensor requires additional time to respond to the host and utilizes the clock stretching feature of the I2C protocol. This is accomplished by holding the SCL low after the ACK cycle of a data transfer. Refer to Section 7.4 for the clock stretching timing. Note, the maximum clock stretch time will generally only occur once during the three ACK cycles of a two byte transfer. That is, the balance of ACK's during a multi-byte transfer will generally include the typical clock stretching time. 10.4.4 I2C Bus Compatibility The I2C specification allows any recessive voltage between 3.0 and 5.0 V. Different devices on the bus may operate at different voltage levels. However, the maximum voltage on any port pin must conform to the electrical characteristics specifications (See section 1). The bi-directional SCL (serial clock) and SDA (serial data) lines must be connected to a positive power supply voltage through a pull-up resistor or similar circuit. Every device connected to the bus must have an open-drain or open-collector output for both the SCL and SDA lines, so that both are pulled high (recessive state) when the bus is free. 10.5 Extended Data Acquisition 10.5.1 Available Extended Data For either the SPI or I2C interface, additional data is available beyond the pressure. The means to access this extended data is to continue reading data (either SPI or I2C) beyond the first 16 bits of pressure information. The following table defines the order of the available data and respective format. Data Bytes Format Interpretation Example Pressure 1-2 2 byte, Unsigned Int See Section 10.7 See Section 10.7 Temperature 3-4 2 byte, Signed Int Fixed Decimal [8.8 bits], Upper 8 bits integer, lower 8 bits fractional. Temperature in °C 1880H (18.80H) = 24.5°C Model 5-12 8 byte, ASCII, null terminated Right reading ASCII with null termination 4EH,44H,30H,31H,35H,41H,00H,xxH = ND015A Serial Number 13-16 4 byte, Hex Unique 4 byte serial for each part 2FD627A4H Build Number 17-22 6 byte, ASCII, null terminated Right reading ASCII with null termination 30H,31H,34H,37H,41H,00H = 0147A 10.5.2 SPI Extended Data Read Reading the extended data while using the SPI interface is the same as shown in Section 10.3 with the exception that the master continues to read during the same nSS sequence to read all 22 bytes of the extended data. Any portion of the 22 bytes can be read during the transfer. That is, for example, 4 bytes could be read to acquire only the pressure and temperature information. When reading the extended data, only the first two bytes sent to the sensor (User Mode and User Rate) are used to set the internal registers. The subsequent bytes (bytes 5 through 22) are ignored. Data read following the first 22 bytes is undefined. www.SuperiorSensors.com 10 ND Series Industrial Absolute Middle Pressure Sensors 10.5.3 I2C Extended Data Read Reading the extended data via the I2C interface is similar to using the SPI interface where the master can simply continue to reading the sensor during the pressure reading transfer. The master continues Ack'ing until the number of desired bytes are read. 10.6 Control Registers 10.6.1 Mode Control Register Mode Control Register Detail Default Value: 0xF7 Mode Register (General) Details of the Mode Control register are illustrated in the figure to the right. b7 b6 b5 b4 b3 b2 b1 b0 Pressure Range Select Bits 0-2 control the output pressure range. I/O Watchdog Enable BW Limit Select Bit 3 is the I/O Watchdog Enable bit. When set, the I/O watchdog is enabled. When enabled, the I/O watchdog will monitor the I/O activity. If I/O activity is not detected for the I/O Watchdog timeout time, the pressure sensor will reset itself. The I/O watchdog timeout time is determined by the currently active bandwidth setting. Notch Enable Mode Register (Detail) b7 b6 b5 b4 b3 b2 b1 b0 Bits 4-6 control the BW Limit Filter. ND015A Bit 7 is the Notch Filter Enable bit. When enabled, the 50/60Hz notch filter is active. It should be noted that upon changing the Mode Control value, there is a one cycle latency before the new Mode Control value becomes valid. That is, the data of the communication cycle following a change to the Mode Control register will not reflect the change. It is not until the second communication cycle that the change in the Mode Control register will be reflected in the output data. 0 0 0 0 0 1 0 1 0 0 1 1 1 0 0 1 0 1 1 1 0 1 1 1 Pressure Range Select (by Model) ND030A ND060A ND100A ND150A Reserved Do NOT Use 15.0 psi 30.0 psi 60.0 psi 100 psi 150 psi I/O Watchdog Enable 0 Disabled 1 Enabled BW Limit Select I/O Watchdog Timeout 0 0 0 1.0 Hz 1 sec 0 0 1 2.0 Hz 500 ms 0 1 0 5.0 Hz 200 ms 0 1 1 10 Hz 200 ms 1 0 0 20 Hz 200 ms 1 0 1 50 Hz 200 ms 1 1 0 100 Hz 200 ms 1 1 1 200 Hz 200 ms www.SuperiorSensors.com 11 Notch Filter Disabled 1 Notch Filter Enabled FIG-0126A Notch Enable 0 ND Series Industrial Absolute Middle Pressure Sensors 10.6.2 Rate Control Register Default Value: 0x1C Rate Control Register Detail The Rate Control Register controls the rate at which the DAV pin is asserted indicating new data is available. This register is primarily used to throttle down the actual data transfer rate (when using the DAV as the trigger to sample) since the general industrial requirement is less than the internal 444 Hz update rate. This register functions as the reload value of a data rate counter. The value of the Rate Control Register is the divisor of the 444 Hz internal data rate. Since a divisor of zero is not possible, a zero value will select the auto-select rate mode. In this mode, the rate is selected based on the selected bandwidth limit. The auto rate value is roughly 3x the corner frequency of the selected bandwidth limit in all auto selected rates (where possible). b6 b5 b4 b3 b2 b1 b0 0 0 0 0 0 0 0 0 Auto Select 0 0 0 0 0 0 0 1 444 Hz 0 0 0 0 0 0 1 0 222 Hz 0 0 0 0 0 0 1 1 148 Hz 1 1 1 1 1 1 1 0 1.75 Hz 1 1 1 1 1 1 1 1 1.74 Hz Selected BW Limit Auto Select Rate 1.0 Hz 3.0 Hz 2.0 Hz 6.0 Hz 5.0 Hz 15.3 Hz 10 Hz 31.7 Hz 20 Hz 63.4 Hz 50 Hz 148 Hz 100 Hz 444 Hz 200 Hz 444 Hz Note: Start-up time for the sensor is approximately 80ms for the first sample to be settled. Requesting data during this time will result in invalid information. However, this start-up time can be used for configuring the Mode and Rate registers by performing a transfer with the desired Mode and Rate register values and discarding the received pressure data. After waiting the required start-up time, the sensor will respond with desired data since the Mode and Rate registers have been pre-established. FIG-0084A Rate Control Register b7 10.7 Computing Pressure The pressure data is in the form of 16 bit unsigned integer sent in high byte then low byte order. This is a single ended output by definition and the data range is 0 to 216. There is a 10% margin (5% either end) in the output scaling and the selected full scale will reside in the 5% to 95% of the total available output data range. Refer to Equation 1 (below) for the general model for computing the output pressure. As an example, if the sensor output is 37,646 counts using an ND015A (15 psia) device, then the output pressure is 8.74 psia. 𝐸𝐸𝐸𝐸 1: 𝑃𝑃𝑝𝑝𝑝𝑝𝑝𝑝𝑝𝑝 = (𝑂𝑂𝑂𝑂𝑂𝑂𝐷𝐷𝐷𝐷𝐷𝐷𝐷𝐷𝐷𝐷𝐷𝐷𝐷𝐷 − 5%∗2^16) www.SuperiorSensors.com 90% ∗ 216 ∗ 𝐹𝐹𝐹𝐹 𝐸𝐸𝐸𝐸𝐸𝐸𝐸𝐸𝐸𝐸𝐸𝐸𝐸𝐸 1: 𝑃𝑃𝑝𝑝𝑝𝑝𝑝𝑝𝑝𝑝 = 12 (37,644 − 3,276.8) 90% ∗ 216 ∗ 15 𝑝𝑝𝑝𝑝𝑝𝑝𝑝𝑝 = 8.74 𝑝𝑝𝑝𝑝𝑝𝑝𝑝𝑝 ND Series Industrial Absolute Middle Pressure Sensors 11 Mechanical and Manufacturing 11.1 Package Dimensions 11.2 Suggested Pad Layout The suggested pad layout is shown in the figure below. An Eagle PCB symbol library is available with the shown pad dimensions. Please consult the factory to obtain the library. www.SuperiorSensors.com 13 ND Series Industrial Absolute Middle Pressure Sensors 11.3 Pinout Pin Sym 1 nSS 2 3 4 5 6 7 8 9 10 11 MOSI/SCL MISO/SDA SCK DNC DNC DNC Gnd VDD nRST DAV SPI I 2C Slave Select Tie to Ground (active low) MOSI SCL MISO SDA Serial Clock See Section 10.4.1 Do Not Connect Do Not Connect Do Not Connect Ground Sensor Supply Reset (active low) Data Available 11.4 Reflow Soldering and Handling Conditions Parameter Sym Val Units Soldering Specifications (Max) Preheat Ramp Rate Soak Time Time Above 217C Time Above 230C Time Above 250C Peak Temperature Cooling Ramp Rate tPHRR tSOAK tGT217 tGT230 tGT250 tPT tCRR 3 3 50 40 15 255 -4 °C/s min s s s °C °C/s Weight WPRT 3.5 gm Moisture Sensitivity MSL 3 ESD (Human Body Model) ESD 2 kV 11.5 Pick and Place Pick-up Zone www.SuperiorSensors.com 14 ND Series Industrial Absolute Middle Pressure Sensors 11.6 Packaging Options 11.6.1 Tray Packaging www.SuperiorSensors.com 15 ND Series Industrial Absolute Middle Pressure Sensors 11.6.2 Tape and Reel 11.7 Part Identification www.SuperiorSensors.com 16 ND Series Industrial Absolute Middle Pressure Sensors 12 Packaging Labeling Packaging labels are provided with barcode Code 128 symbology. The provided fields are Company Name, Part Number, Packaging ID and Quantity. The Packaging ID traces back to the Lot Number (or Lot Numbers) contained in the package. The purpose is to eliminate multiple labels (one for each included Lot Number) in the event of multiple Lot Numbers within a single package. This is for ease of customer tracking and maintenance. The Packaging ID is a 24 bit value printed in hexadecimal format. 13 Ordering Information Part Number ND015A-SM02 ND030A-SM02 ND060A-SM02 ND100A-SM02 ND150A-SM02 www.SuperiorSensors.com Part Package SM02 SM02 SM02 SM02 SM02 Packaging Packaging Qty Order Number Tape and Reel Multi-Tray Single Tray Quarter Reel Cut Tape 256 512 64 64 1-63 ND015A-SM02-R ND015A -SM02-M ND015A -SM02-T ND015A -SM02-Q ND015A -SM02-C Tape and Reel Multi-Tray Single Tray Quarter Reel Cut Tape 256 512 64 64 1-63 ND030A-SM02-R ND030A -SM02-M ND030A -SM02-T ND030A -SM02-Q ND030A -SM02-C Tape and Reel Multi-Tray Single Tray Quarter Reel Cut Tape 256 512 64 64 1-63 ND060A-SM02-R ND060A -SM02-M ND060A -SM02-T ND060A -SM02-Q ND060A -SM02-C Tape and Reel Multi-Tray Single Tray Quarter Reel Cut Tape 256 512 64 64 1-63 ND100A-SM02-R ND100A -SM02-M ND100A -SM02-T ND100A -SM02-Q ND100A -SM02-C Tape and Reel Multi-Tray Single Tray Quarter Reel Cut Tape 256 512 64 64 1-63 ND150A-SM02-R ND150A -SM02-M ND150A -SM02-T ND150A -SM02-Q ND150A -SM02-C 17 ND Series Industrial Absolute Middle Pressure Sensors 14 Revisions Rev A Change Description(s) Initial Release Date By 12/26/21 T.S. 15 Warranty Superior Sensor Technology and its subsidiaries warrant goods of its manufacture as being free of defective materials and faulty workmanship during the applicable warranty period. In all cases, Superior Sensor Technology's standard product warranty applies; please refer to your order acknowledgement or consult your local sales office for specific warranty details. If warranted goods are returned to Superior Sensor Technology during the period of coverage, Superior Sensor Technology will repair or replace, at its option, without charge those items that Superior Sensor Technology, in its sole discretion, finds defective. The foregoing is buyer’s sole remedy and is in lieu of all other warranties, expressed or implied. In no event shall Superior Sensor Technology be liable for consequential, special, or indirect damages. While Superior Sensor Technology may provide application assistance personally, through literature or the Superior Sensor Technology web site, it is buyer's sole responsibility to determine the suitability of the product in their application. Superior Sensor Technology assumes no liability for applications assistance or customer product design. Superior Sensor Technology reserves the right to make corrections, modifications, enhancements, improvements and other changes to its products and services at any time and to discontinue any product or service without notice. Customers should obtain the latest relevant information before placing orders and should verify that such information is current and complete. Superior SENSOR TECHNOLOGY 103 Cooper Court Los Gatos, CA 95032 www.SuperiorSensors.com info@SuperiorSensors.com +1.408.703.2950 NimbleSense is a trademark of Superior Sensor Technology www.SuperiorSensors.com 18
ND100A 价格&库存
很抱歉,暂时无法提供与“ND100A”相匹配的价格&库存,您可以联系我们找货
