IPCAPM-1316
IPCAPM-1316
    PEI-GENESIS(倍捷)
    SEALING CAP 13/16 28UN MTL
IPCAPM-1316 数据手册
® L W A E I E V S R E E R V U O S CT U D RO P www .peigenesi s.com II www.peigenesis.cn www.peigenesis.com sales@peigenesis.com INDUSTRIAL INTERCONNECTS The demand for high performance and versatile designs for use in harsh environments and industrial applications requires robust interconnect solutions. Sure-Seal® products are developed specifically to perform reliably and safely, while resisting contamination, moisture and vibration. Sure-Seal® Industrial Connectors and Cable Assemblies are rugged and highly reliable. Standard configurations are available for USB 2.0 & 3.0, RJ45, HDMI, M Series, Sure-Seal, Standard K & Single Pole Power Connectors, all designed for use in extreme conditions. Applications • Industrial Automation • Communication • Marine • Medical • Agriculture • Robotics • Energy • Transportation Custom Capabilities Due to the high demands of modern applications, Sure-Seal products proudly offer the capability to provide bespoke reliable solutions for a wide range of harsh environments. Custom capabilities can range from simple changes to a standard product, such as length and termination combinations, to more complicated requirements including custom cables and connectors. Sure-Seal products are developed in partnership with our customers to deliver robust solutions quickly, designed for the most demanding of applications. USB SERIES • USB 2.0 & 3.0 Standard • IP67 Panel mount receptacles with options: PC tail, flying lead bulkhead in A and B type interfaces RF SERIES • Fully compatible with MIL-STD-348B w/change 2 • Suitable for Flexible, Semi-Flexible and Semi-Rigid Cable • Molded cable assemblies available in standard and customized lengths • Crimp, Clamp, Twist-on, Direct Soldering • Operating Temperature Range: -20°C to 80°C (Wire leads) -40°C to 85°C (Connector) • Pin-in-Pin (Specialized for Mini Coaxial Cable, 1.13, 1.32, 1.37, 0.81) • Housing Material: Composite - Nylon + GF, Black Metal - Zinc Alloy, Nickel Plated • Standard and Bespoke RF Connector RJ45 SERIES • PCB, End Launch Edge Mount, SMT • Tailored for IP68 • BNC, TNC, MMCX, Micro BNC and more for connectors and cable assemblies HDMI SERIES • IP67 Panel mount receptacles with options: PC tail, flying lead bulkhead in A and B type interfaces • IP67 Panel mount receptacles with options: PC tail, flying lead, coupler types • Molded cable assemblies available in standard and customized lengths • Molded cable assemblies available in standard and customized lengths • Meets TIA/EIA-568 Category 5E requirements • Meets HDMI Type A requirements • Operating Temperature Range: -20°C to 80°C (Wire leads) -40°C to 85°C (Connector) • Housing Material: Composite - Nylon + GF, Black Metal - Zinc Alloy, Nickel Plated www.peigenesis.com I www.peigenesis.cn • Operating Temperature Range: -20°C to 80°C (Wire leads) -40°C to 85°C (Connector) • Housing Material: Nylon + GF, Black M5 SERIES M8 SERIES • IP67 Panel mount receptacles with options: solder cup, PC tail, flying lead types • IP67 Panel mount receptacles with options: solder cup, PC tail, flying lead types • Molded cable assemblies in PVC or PUR in standard and customized lengths • Molded cable assemblies in PVC or PUR in standard and customized lengths • Available in 3 and 4 poles • Available in 3 to 8 pole configurations • Meets IEC-61076-2-105 standard • Meets IEC-61076-2-104 standard • Operating Temperature Range: -10°C to 80°C (Wire leads) -25°C to 90°C (Connector) • Operating Temperature Range: -10°C to 80°C (Wire leads) -25°C to 90°C (Connector) • Coding: A • Codings: A, B M12 SERIES M16 SERIES • IP67 Panel mount receptacles with options: solder cup, PC tail, flying lead types • IP67 Panel mount receptacles with front and rear fastening options • Molded cable assemblies in PVC or PUR in standard and customized lengths • Molded cable assemblies in PVC or PUR in standard and customized lengths • Available in 3 to 17 pole configurations • Available in 2 to 19 pole configurations • Meets IEC-61076-2-101 standard • Meets IEC-61076-2-106 standard • Operating Temperature Range: -10°C to 80°C (Wire leads) -25°C to 90°C (Connector) • Operating Temperature Range: -10°C to 70°C (Wire leads) -25°C to 70°C (Connector) • Codings: A, B, C, D, X, S, T, K, L, Y M20 SERIES M23 SERIES • IP67 Power & Signal Connectors Available in Molded Cable, Field Wireable & Panel mount configurations • Molded cable assemblies available in EPDM rubber • Available in a hybrid 3 power + 5 signal pole configuration • Molded cable assemblies in PVC or PUR in standard and customized lengths • Operating Temperature Range: -40°C to 80°C (Fixed) -20°C to 80°C (Flexible) • Available in a variety of insert configurations M-Series Coding Breakdown A = Sensors, dc power B = Profibus C = ac power sales@peigenesis.com D = 100 Mbit Ethernet X = 10 Gbit Ethernet T = dc power S = ac power • Operating Temperature Range: -10°C to 80°C (Wire leads) -25°C to 90°C (Connector) STANDARD K CONNECTOR SURE-SEAL CONNECTOR • 2-110 Pin Insert Configurations • IP67 & DIN 400 50 Environments • Keyway and insert rotations available to prevent mismating • Standard, Mini & Power configurations are available • Straight and 90 Degree offerings for both plug and receptacle styles • Excellent resistance to brake fluids, gasoline, anti-freeze & steam • Operating Temperature Range: -55°C to 125°C • Housing Material: Clear Chromate over Cadmium or Electroless Nickel SINGLE POLE POWER • IP67 Plug and Receptacle connectors available in both Source and Drain configurations • Color coded & mechanically keyed to prevent connection errors • European, UK, Australia & US Single and Three Phase Color codes are available • 800A Maximum Rating 505A UL Rating • Operating Temperature Range: -30°C to 125°C (Connector) • UL & CSA Approved • Operating Temperature Range: -40°C to +105°C • Housing Material: PVC Nitrile standard, also available in silicone & EPDM Corporate Headquarters, Philadelphia, PA European Headquarters & Production Facility, Southampton, UK Production Facility, Zhuhai, China North American Production Facility, South Bend, IN FilConn, Chandler, AZ Production Facility, Nogales, MX PEI-Genesis has sales offices throughout the Americas, Europe and Asia. Visit www.peigenesis.com, call +1 800.675.1214 (North America), +44 (0) 23 8062 1260 (Europe), +86 756 7683 088 (Asia), +1 631.475.5050 (Rest of World), or email: sales@peigenesis.com. www.peigenesis.com | www.peigenesis.cn
IPCAPM-1316 价格&库存
很抱歉,暂时无法提供与“IPCAPM-1316”相匹配的价格&库存,您可以联系我们找货
