35HDSAU15
35HDSAU15
    SWITCHCRAFT
    3.50mm(0.141",1/8",迷你型插头)- 耳机 电话插头 立体声(3 导体,TRS) 连接器 焊接孔眼
35HDSAU15 数据手册
2.17 55.2 0.50 12.7 1.61 40.8 0.50 12.7 "A" REF CABLE HOLE SEE TABLE 0.14 3.5 OVERMOLDED HANDLE AND TUBULAR INSULATOR SHIPPED UNASSEMBLED CABLE CLAMP SLEEVE TERMINAL 0.53 13.5 O-RING RING TERMINAL 3 5 H D S __ __ TIP TERMINAL NOTES: 1. SPECIFICATIONS: CONTACT RESISTANCE: 20 MILIOHMS MAX. DIELECTRIC WITHSTANDING VOLTAGE - 250 VAC MIN INSULATION RESISTANCE @ 500 VDC - 2,000 MEGAOHMS MIN MAX WORKING VOLTAGE - 250 VAC, 140VDC CURRENT CARRY @ WORKING VOLTAGE - 4 AMPS INSERT / WITHDRAWAL FORCE - TYPICAL 2.5/2 LBS TEMPERATURE RANGE: -20°C TO 85°C (OPERATING) PASSES IP67 & IP68 AFTER: THERMAL SHOCK - MIL-STD-202, METHOD 107G VIBRATION - MIL-STD-202, METHOD 201 LIFE - 5,000 CYCLES 2. MATERIALS: PLUG BODY, TIP ROD & RING - COPPER ALLOY, TIN OR GOLD PLATED PLUG INSULATION - THERMOPLASTIC, BLACK RING TERMINAL - COPPER ALLOY, TIN PLATED CABLE CLAMP - STEEL, TIN PLATED COUPLING RING - COPPER ALLOY, NICKEL PLATED HANDLE - COPPER ALLOY, NICKEL PLATED OVERMOLDED THERMOPLASTIC TUBULAR INSULATOR - MYLAR 3. THESE PRODUCTS ARE RoHS COMPLIANT. SEALED 1.06 27.0 12 15 17 - 1.62 41.2 CABLE OD RANGE 0.125" - 0.150" 0.150" - 0.175" 0.175 - 0.210" PLUG FINISH N - TIN PLATED AU- GOLD PLATED CUSTOMER DRAWING THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY. UNLESS OTHERWISE SPECIFIED 1. ALL DIMENSIONS IN INCHES [mm] SIZE FINISH - TWO PLACE DECIMALS 0.02 [0.5] - THREE PLACE DECIMALS 0.005 [0.13] SPEC No. FIRST USED ON DATE DRAWN * REV * * ECO NUMBER DATE REVISIONS * BY 05/24/18 * APVD WIDTH * DO NOT SCALE DRAWING SolidWorks CAD File NAME B * * * AM LBS/M * TEMPER * * * MATERIAL SPEC No. * SCALE 2:1 * BY MULT CHKD * * APVD * * 3.5MM SEALED, RoHS STEREO PLUG SHEET PART No. 1 OF 35HDS SERIES 1 REV 0A
35HDSAU15 价格&库存
很抱歉,暂时无法提供与“35HDSAU15”相匹配的价格&库存,您可以联系我们找货
35HDSAU15
  • 1+120.637901+14.96508
  • 10+92.8085210+11.51286
  • 25+83.9584225+10.41501
  • 50+77.9745550+9.67271
  • 100+72.92178100+9.04592
库存:381
