TG-NSP-60
Ultra conformable silicone-free putty type gap filler
Description
TG-NSP-60 is an ultra conformable silicone-free putty type gap filler. It is designed
for when heat transfer is needed between delicate components where the pressure
must be minimised and silicone contamination cannot be tolerated. TG-NSP-60 is
designed to fill gaps from 0.25 – 8mm with little or n o s tress generated. The nonsilicone formulation will adhere to all surfaces, such as metal housings, ceramic and
plastic IC packages and FR4 boards to give a low thermal resistance path for heat
transfer.
TG-NSP-60 is available in 30cc syringes, 6 and 12oz cartridges and 5 gallon pails.
REACH Compliant
Properties
RoHS Compliant
Thermal Conductivity: 5.9 W/mK
(W/mK - Z Axis)
Property
TG-NSP-60
Unit
Test Method
Colour
Grey
Visual
5.9
W/mK
ASTM D5470
Weight Loss
‹0.5
ASTM E595
Working Temperature
-55 to 200
˚C
Volume Resistivity
2.15 x 10
Ohm-cm
ASTM D-257
PPM
GC / MS
D4-10
15
Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
很抱歉,暂时无法提供与“TG-NSP-60 1LB”相匹配的价格&库存,您可以联系我们找货
