XL-25 with Li-98
Ceramic Heat Spreader with Thermal Tape
XL-25 Features
Large contact area
Low weight
High breakdown voltage
Excellent heat spreader
Custom shapes possible
Applications
LED / Notebook PC / M/B / Power Transistor / Power Module / CPU / Chip IC
Sizes (mm)
XL-25 30 x 30 x t2.0mm +Li98C
28 x 28 x t0.15mm (With pull tab 5.0mm)
XL-25 20x20xt2.0mm +Li98C
18 x 18 x t0.15mm (With pull tab 5.0mm)
Used examples: Heat sources with XL-25
Property
XL-25
Unit
Test Method
Colour
Grey
Visual
Thermal Conductivity
6.79
W/m.k
Dielectric Breakdown Voltage
›500
Voltage
ASTM D149
Specific Gravity
1.89
g/cm3
CNS 619
Surface Resistance
›10
Ohm
Flexural Strength
47.5
Kgf/cm
CNS 12701
Porosity
30
CNS 619
Working Temperature
›500
˚C
Linear Temperature Expansion Coefficient
4.13
10/06/11
RT~300 ˚C
Main Composition
SiC / Al2O3 / SiO2
Hardness
5~6
Moh’s
DIN EN101-1992
9
ASTMD 257
2
Tel: +44 20 8133 2062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
Li-98 Features
Good adhesion
Very good thermal conductivity
Highly compressible
Easy to assemble
Applications
Electronic components: IC / CPU / MOS
LED / M/B / P/S / Heat Sink / LCD-TV / Notebook PC / PC / Telecom Device /
Wireless Hub etc....
DDR II Module / DVD Applications / Hand-Set applications etc...
Properties
Property
Li-98
Li-98C
Li98CN
Unit
Test Method
Thickness
0.15
0.25
0.2
0.18
ASTM D374
Colour
White
White
White
White
Visual
Density
1.85
1.85
1.9
1.8
g/cm3
ASTM D792
Tensile strength
200
400
200
50
psi
ASTM D412
Reinforcement carrier
Fibreglass mesh
Glass transition temperature
-30
-30
-27
-30
˚C
Short time use temperature (30sec)
200
200
200
200
˚C
Continuous working temperature
-30 to 120
-30 to 120
-30 to 120
-30 to 120
˚C
Thermal conductivity
0.95
0.95
1.8
2
W/mK
ASTM D5470
Thermal impedance @ ‹1psi
1.0
1.8
0.7
0.6
C in 2/W
ASTM D5470
Thermal impedance @ 50psi
0.9
1.5
0.5
0.3
C in 2/W
ASTM D5470
Initial tack
11
10
14
15
cm
PSTC-6
Lap shear strength
61
61
65
55
N/cm2
ASTM D1002
Die shear strength @ 25 ˚C
120
120
118
100
N/cm
2
Die shear strength @ 80 ˚C
69
69
68
55
N/cm
Holding power 1000g @ 25 ˚C using 1 in2
›10000
›10000
›10000
›10000
min
PSTC-7
Holding power 1000g @ 80 ˚C using 1 in2
›10000
›10000
›10000
›10000
min
PSTC-7
180 peeling strength (aluminium)
4
5
4
3
N/cm
ASTM D3330
Dielectric breakdown voltage (Vac)
›2
›3
›3
›5
kV
ASTM D149
Dielectric breakdown voltage (Vdc)
›3
›4
›4
›6
kV
ASTM D149
o
2
很抱歉,暂时无法提供与“XLI98C-20-20-2.15”相匹配的价格&库存,您可以联系我们找货
