HSF 2012F2SF-600T03-H
    TAI-TECH(台庆)
    水平式,4 PC 板
    2 线路共模扼流圈 表面贴装型 67 Ohms @ 100 MHz 400mA DCR 300 毫欧
HSF 2012F2SF-600T03-H 数据手册
TAI-TECH P2 Wire Wound Type Common Mode Filter HSF1210F2SF-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent Halogen noise suppression performance. 2. HSF1210F2SF series realizes small size and low profile. 1.2x1.0x0.9 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. Excellent for USB3.0 5. Operating temperature -40~+125℃ (Including self - temperature rise) 2. Dimension E C A D D B Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 1210F2SF 1.2±0.2 1.0±0.2 0.9 max. 0.35±0.1 0.35±0.1 0.03 min. 3. Part Numbering HSF 1210 A B F 2 S F C D E F - 900 T 02 G H I A: Series B: Dimension C: Material Ferrite D: Number of Lines 2=2 lines E: Type S=Shielded, N=Unshielded F: Lead free G: Impedance H: Packaging I: Rated Current 900=90Ω T=Taping and Reel, B=Bulk 02=200mA 4. Specification TAI-TECH Part Number DC Common mode Impedance Test Frequency Resistance (MHz) (Ω) (Ω) max. Rated Current (mA) max. Withstand IR Rated Volt. (Vdc) max. Volt. (Vdc) (Ω) min. max. HSF1210F2SF-350T02 35±25% 100 0.30 200 50 125 10M HSF1210F2SF-500T02 50±25% 100 0.30 250 50 125 10M HSF1210F2SF-600T02 60±25% 100 0.30 250 50 125 10M HSF1210F2SF-900T02 90±25% 100 0.40 200 50 125 10M www.tai-tech.com.tw TAI-TECH HSF1210F2SF-350T02 1000 100 Common Mode 10 Normal Mode 1 HSF1210F2SF-500T02 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P3 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 HSF1210F2SF-600T02 Common Mode 100 10 Normal Mode 1 1000 10000 HSF1210F2SF-900T02 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) 0.1 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 1 FREQUENCY(MHz) 10 100 FREQUENCY(MHz) Sdd21&Scc21 www.tai-tech.com.tw 1000 10000 TAI-TECH P4 www.tai-tech.com.tw TAI-TECH P5 www.tai-tech.com.tw TAI-TECH P6 Wire Wound Type Common Mode Filter HSF1210F2SF-SERIES-U4 1. Features 1. High common mode impedance at high frequency cause excellent Halogen noise suppression performance. 2. HSF1210F2SF series realizes small size and low profile. 1.2x1.0x0.9 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. For USB3.1G1/2、HDMI2.0/2.1、USB4.0、Thunderbolt. 5. Operating temperature -40~+125℃ (Including self - temperature rise) 2. Dimension E C A D D B Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 1210F2SF 1.2±0.2 1.0±0.2 0.9 max. 0.35±0.1 0.35±0.1 0.03 min. 3. Part Numbering HSF 1210 A B F 2 S F C D E F - 900 T 03 G H I - U4 J A: Series B: Dimension Ferrite C: Material D: Number of Lines 2=2 lines E: Type S=Shielded, N=Unshielded F: Lead free G: Impedance 900=90Ω H: Packaging T=Taping and Reel, B=Bulk I: Rated Current 03=300mA J: Control S/N 4. Specification TAI-TECH Part Number HSF1210F2SF-1R9T04-U4 Common mode Impedance (Ω) Typ. Test Frequency (MHz) 1.9 100 DC Cut-off Frequency Resistance (Ω) max. (GHz)Typ. 18 Rated Current (mA)max. 0.20 400 Withstand Rated Volt. IR Volt. (Vdc) (Ω) min. (Vdc)max. max. 50 125 10M HSF1210F2SF-5R3T03-U4 5.3 100 18 0.30 300 50 125 10M HSF1210F2SF-300T04-U4 30.0 100 18 0.20 400 50 125 10M HSF1210F2SF-900T03-U4 90.0 100 18 0.30 300 50 125 10M www.tai-tech.com.tw TAI-TECH P7 HSF1210F2SF-1R9T04-U4 10 Common Mode Normal Mode 1 HSF1210F2SF-5R3T03-U4 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 100 0.1 100 Common Mode 10 Normal Mode 1 0.1 0.01 1 10 100 1000 1 10000 10 HSF1210F2SF-300T04-U4 IMPEDANCE(Ohm) 10 Normal Mode 1 1000 10000 HSF1210F2SF-900T03-U4 1000 Common Mode 100 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 10000 1 10 100 1000 FREQUENCY(MHz) FREQUENCY(MHz) Sdd21&Scc21 HSF1210F2SF-1R9T04-U4 0 -5 -10 -15 dB IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) -20 -25 -30 -35 -40 Sdd21 -45 Scc21 -50 1 10 100 1000 Frequency (MHz) www.tai-tech.com.tw 10000 100000 10000 TAI-TECH P8 HSF1210F2SF-5R3T03-U4 0 -5 -10 dB -15 -20 -25 -30 -35 -40 Sdd21 Scc21 Sdd21 -45 -50 1 10 100 1000 10000 100000 Frequency (MHz) HSF1210F2SF-300T04-U4 0 -5 -10 dB -15 -20 -25 -30 -35 -40 Sdd21 -45 Scc21 -50 1 10 100 1000 Frequency (MHz) www.tai-tech.com.tw 10000 100000 TAI-TECH P9 HSF1210F2SF-900T03-U4 0 -5 -10 dB -15 -20 -25 -30 -35 -40 Sdd21 -45 Scc21 -50 1 10 100 1000 Frequency (MHz) www.tai-tech.com.tw 10000 100000 TAI-TECH P10 Wire Wound Type Common Mode Filter HSF2012F2SF-SERIES-H 1. Features 1. High common mode impedance at high frequency cause excellent noise Halogen suppression performance. 2. HSF2012F2SF series realizes small size and low profile. 2.0x1.2x1.2 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. For USB3.1G2 & HDMI2.0 5. Operating temperature -40~+125℃ (Including self - temperature rise) 2. Dimension E C A D B A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 2012F2SF 2.0±0.2 1.2±0.2 1.2±0.2 0.50±0.1 0.51±0.1 0.15±0.1 - 600 T 03 - G H I D Series 3. Part Numbering HSF 2012 A B F 2 S F C D E F H J A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shieded , N=Unshielded F: Lead free G: Impedance 600=60Ω H: Packaging T=Taping and Reel I: Rated Current 03=300mA J: Control S/N 4. Specification TAI-TECH Part Number Common mode Impedance (Ω) Test Frequency (MHz) DC Resistance (Ω) max. Rated Current (mA) max. Rated Volt. (Vdc) max. HSF2012F2SF-300T04-H 30±25% 100 0.20 400 50 125 10M HSF2012F2SF-600T03-H 60±25% 100 0.30 300 50 125 10M HSF2012F2SF-900T03-H 90±25% 100 0.30 300 50 125 10M HSF2012F2SF-121T03-H 120±25% 100 0.35 330 50 125 10M www.tai-tech.com.tw Withstand Volt. IR (Ω) min. (Vdc) max. TAI-TECH HSF2012F2SF-300T04-H 1000 100 Common Mode 10 Normal Mode 1 HSF2012F2SF-600T03-H 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P11 0.1 100 Common Mode 10 Normal Mode 1 0.1 1 10 100 1000 10000 1 10 FREQUENCY(MHz) 100 1000 10000 FREQUENCY(MHz) -H HSF2012F2SF-900T03-H Common Mode 100 HSF2012F2SF-121T03-H 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 10 Normal Mode 1 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 10000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P12 HSF2012F2SF-300T04-H www.tai-tech.com.tw TAI-TECH P13 www.tai-tech.com.tw TAI-TECH P14 HSF2012F2SF-600T03-H www.tai-tech.com.tw TAI-TECH P15 www.tai-tech.com.tw TAI-TECH P16 HSF2012F2SF-900T03-H www.tai-tech.com.tw TAI-TECH P17 www.tai-tech.com.tw TAI-TECH P18 HSF2012F2SF-121T03-H www.tai-tech.com.tw TAI-TECH P19 www.tai-tech.com.tw TAI-TECH P20 5. Schematic Diagram 6. Materials No. Description Specification a. Upper Plate Ferrite b. Core Ferrite Core c Termination Ag/Ni/Sn d Wire Enameled Copper Wire www.tai-tech.com.tw TAI-TECH P21 7. Reliability and Test Condition (HSF1210, HSF2012) Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test Z(common mode) DCR Keysight E4991B + Keysight 16197A Refer to standard electrical characteristics list. I.R. Temperature Rise Test Agilent-34420A Agilent-4338B Chroma 19073 Rated Current ΔT 40℃Max 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles) Temperature:125±2℃ Life Test Applied current:rated current Duration:1000±12hrs Measured at room temperature after placing for 24 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Humidity:85±3% R.H, Load Humidity Temperature:85℃±2℃ Duration : 1000hrs Min. Bead : with 100% rated current , Inductance: with 10% rated current Measured at room temperature after placing for 24 hrs. Moisture Resistance Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles 1. Baked at50℃ for 25hrs, measured at room temperature after placing for 4 hrs. 2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs. 3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and keep 3 hours, cool down to 25℃ in 2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs 4. Keep at 25℃ 80-100%RH for 15min and vibrate at the frequency of 10 to 55 Hz to 10 Hz, measure at room temperature after placing for 1~2 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30±5min Thermal shock Step2:125±2℃ ≦0.5min Step3:125±2℃ 30±5min Number of cycles: 500 Measured at room temperature after placing for 24 hrs. Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minute Equipment: Vibration checker Total Amplitude:10g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration www.tai-tech.com.tw TAI-TECH Item P22 Performance Bending Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Shock Test Condition Shall be mounted on a FR4 substrate of the following dimensions: >=0805 inch(2012mm):40x100x1.2mm =0805 inch(2012mm):1.2mm 0805:1kg ,
HSF 2012F2SF-600T03-H 价格&库存
很抱歉,暂时无法提供与“HSF 2012F2SF-600T03-H”相匹配的价格&库存,您可以联系我们找货
