WCM 2012F2SV-670T04
WCM 2012F2SV-670T04
    TAI-TECH(台庆)
    2 线路共模扼流圈 表面贴装型 67 Ohms @ 100 MHz 400mA DCR 250 毫欧
WCM 2012F2SV-670T04 数据手册
TAI-TECH P2 Wire Wound Type Common Mode Filter WCM2012F2SV-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent noise Halogen suppression performance. 2. WCM2012F2SV series realizes small size and low profile. 2.0x1.2x1.2 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. High reliability -Reliability tests comply with AEC-Q200 5. Operating temperature-55~+125℃(Including self - temperature rise) 2. Dimension A A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 2012F2SV 2.0±0.2 1.2±0.2 1.2±0.2 0.50±0.1 0.51±0.1 0.15±0.1 E C Series D D B 3. Part Numbering WCM 2012 A B F 2 S V C D E F - 900 T 04 G H I A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Category Code V=Vehicle G: Impedance 900=90Ω H: Packaging I: Rated Current T=Taping and Reel 04=400mA 4. Specification TAI-TECH Part Number DC Common mode Test Frequency Impedance Resistance (MHz) (Ω) (Ω) max. Rated Current (mA)max. Withstand Rated Volt. IR Volt. (Vdc) (Ω) min. (Vdc)max. max. WCM2012F2SV-670T04 67±25% 100 0.25 400 50 125 10M WCM2012F2SV-900T04 90±25% 100 0.30 400 50 125 10M WCM2012F2SV-121T04 120±25% 100 0.30 400 50 125 10M WCM2012F2SV-161T03 160±25% 100 0.35 350 50 125 10M WCM2012F2SV-181T03 180±25% 100 0.35 350 50 125 10M WCM2012F2SV-201T03 200±25% 100 0.40 300 50 125 10M WCM2012F2SV-221T03 220±25% 100 0.40 300 50 125 10M WCM2012F2SV-261T03 260±25% 100 0.40 300 50 125 10M WCM2012F2SV-361T03 360±25% 100 0.50 300 50 125 10M www.tai-tech.com.tw TAI-TECH P3 Typical Impedance v.s. Frequency Curve WCM2012F2SV-670T04 Common Mode 100 10 Normal Mode 1 WCM2012F2SV-900T04 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM2012F2SV-121T04 Common Mode 100 10 Normal Mode 1 0.1 Common Mode 100 10 Normal Mode 1 10 100 1000 10000 1 10 FREQUENCY(MHz) 1000 10000 WCM2012F2SV-201T03 1000 IMPEDANCE(Ohm) 1000 Common Mode 100 100 FREQUENCY(MHz) WCM2012F2SV-181T03 10000 IMPEDANCE(Ohm) 10000 0.1 1 10 Normal Mode 1 0.1 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 1 10 FREQUENCY(MHz) IMPEDANCE(Ohm) 10 Normal Mode 1 1000 10000 WCM2012F2SV-261T03 1000 Common Mode 100 100 FREQUENCY(MHz) WCM2012F2SV-221T03 1000 IMPEDANCE(Ohm) 1000 WCM2012F2SV-161T03 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 10000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P4 WCM2012F2SV-361T03 10000 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 FREQUENCY(MHz) 3. Part Numbering WCM 2012 A B F 2 S V C D E F - 801 - N G H A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Category Code V=Vehicle G: Impedance 801=800Ω H: Category Code N=DR-N45 材&SP-N45 材 4. Specification TAI-TECH Part Number WCM2012F2SV-801-N DC Common mode Test Frequency Impedance Resistance (MHz) (Ω) (Ω) max. 800±25% 100 Rated Current (mA)max. 0.88 Withstand Rated Volt. IR Volt. (Vdc) (Ω) min. (Vdc)max. max. 300 50 Typical Impedance v.s. Frequency Curve WCM2012F2SV-801-N 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 Common Mode 1000 100 10 Normal Mode 1 1 10 100 FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 125 10M TAI-TECH P5 Wire Wound Type Common Mode Filter WCM3216F2SV-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent noise Halogen suppression performance. 2. WCM3216F2SV series realizes small size and low profile. 3.2x1.6x2.0 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. High reliability -Reliability tests comply with AEC-Q200 5. Operating temperature-55~+125℃(Including self - temperature rise) 2. Dimension A C Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 3216F2SV 3.2±0.2 1.6±0.2 2.0±0.2 0.5±0.1 0.5±0.1 0.15±0.1 E Units: mm D D B 3. Part Numbering WCM 3216 A B A: Series B: Dimension C: Material D: Number of Lines E: Type F: Category Code G: Impedance H: Packaging I: Rated Current F 2 S V C D E F - 900 T 04 G H I Ferrite Core 2=2 lines S=Shielded , N=Unshielded V=Vehicle 900=90Ω T=Taping and Reel 04=400mA 4. Specification TAI-TECH Part Number DC Common mode Impedance Test Frequency Resistance (MHz) (Ω) (Ω) max. Rated Current (mA)max. Withstand IR Rated Volt. (Vdc)max. Volt. (Vdc) (Ω) min. Max. WCM3216F2SV-900T04 90±25% 100 0.30 400 50 125 10M WCM3216F2SV-121T03 120±25% 100 0.30 350 50 125 10M WCM3216F2SV-161T03 160±25% 100 0.40 350 50 125 10M WCM3216F2SV-221T03 220±25% 100 0.45 300 50 125 10M WCM3216F2SV-261T03 260±25% 100 0.50 300 50 125 10M WCM3216F2SV-361T03 360±25% 100 0.60 300 50 125 10M WCM3216F2SV-601T03 600±25% 100 0.80 300 50 125 10M WCM3216F2SV-102T02 1000±25% 100 1.00 200 50 125 10M WCM3216F2SV-222T02 2200±25% 100 1.20 200 50 125 10M www.tai-tech.com.tw TAI-TECH P6 Typical Impedance v.s. Frequency Curve WCM3216F2SV-900T04 Common Mode 100 10 Normal Mode 1 WCM3216F2SV-121T03 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM3216F2SV-161T03 Common Mode 100 Normal Mode Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM3216F2SV-261T03 Common Mode 100 1000 10000 WCM3216F2SV-361T03 10000 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) Normal Mode 10 1 Common Mode 100 Normal Mode 10 1 0.1 0.1 1 10 100 1000 10000 1 10 FREQUENCY(MHz) 1000 10000 WCM3216F2SV-102T02 10000 IMPEDANCE(Ohm) Common Mode 1000 100 FREQUENCY(MHz) WCM3216F2SV-601T03 10000 IMPEDANCE(Ohm) 10000 1000 10 1 1000 WCM3216F2SV-221T03 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) 100 10 Normal Mode 1 Common Mode 1000 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P7 WCM3216F2SV-222T02 IMPEDANCE(Ohm) 10000 Common Mode 1000 100 10 Normal Mode 1 1 10 100 1000 10000 FREQUENCY(MHz) www.tai-tech.com.tw TAI-TECH P8 Wire Wound Type Common Mode Filter WCM3225F2SV-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent noise Halogen suppression performance. 2. WCM3225F2SV series realizes small size and low profile. 3.2x2.5x2.2 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. High reliability -Reliability tests comply with AEC-Q200 5. Operating temperature-55~+125℃(Including self - temperature rise) 2. Dimension A C Series A(mm) B(mm) C(mm) D1(mm) D2(mm) E(mm) 3225F2SV 3.2±0.2 2.5±0.2 2.2±0.2 0.8±0.1 0.9±0.1 0.15±0.1 E Units: mm D D B 3. Part Numbering WCM 3225 A B F 2 S F C D E F - 102 T 04 G H I A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Category Code G: Impedance V=Vehicle 102=1000Ω H: Packaging T=Taping and Reel I: Rated Current 04=400mA 4. Specification TAI-TECH Part Number DC Common mode IR Rated Volt. Withstand Volt. (Vdc) Impedance Test Frequency Resistance Rated Current (Ω) min. (Vdc)max. (mA)max. (MHz) max. (Ω) (Ω) max. WCM3225F2SV-900T10 90±25% 100 0.050 1000 50 125 10M WCM3225F2SV-601T10 600±25% 100 0.20 1000 50 125 10M WCM3225F2SV-102T04 1000±25% 100 0.30 400 50 125 10M www.tai-tech.com.tw TAI-TECH WCM3225F2SV-900T10 1000 10 Normal Mode 1 Common Mode 1000 Common Mode 100 WCM3225F2SV-601T10 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P9 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 10000 1 WCM3225F2SV-102T04 Common Mode IMPEDANCE(Ohm) 1000 100 10 Normal Mode 1 0.1 1 10 100 100 FREQUENCY(MHz) FREQUENCY(MHz) 10000 10 1000 10000 FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P10 Wire Wound Type Common Mode Filter WCM4532F2SV-SERIES 1. Features 1. High common mode impedance at high frequency cause excellent noise Halogen suppression performance. 2. WCM4532F2SV series realizes small size and low profile. 4.5x3.2x2.8 mm. Halogen-free 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. 4. High reliability -Reliability tests comply with AEC-Q200 5. Operating temperature-55~+125℃ (Including self - temperature rise) 2. Dimension A A(mm) B(mm) C(mm) D1(mm) D2(mm) 4532F2SV 4.5±0.2 3.2±0.2 2.8±0.2 1.0±0.1 1.2±0.1 C Series B D D Units: mm D D 3. Part Numbering WCM 4532 A B F 2 S V C D E F - 900 T 30 G H I A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Category Code V=Vehicle G: Impedance 900=90Ω H: Packaging I: Rated Current T=Taping and Reel 30=3000mA 4. Specification TAI-TECH Part Number DC Common mode Impedance Test Frequency Resistance (MHz) (Ω) (Ω) max. Rated Current (mA) max. Withstand IR Rated Volt. (Vdc) max. Volt. (Vdc) (Ω) min. max. WCM4532F2SV-800T30 80±25% 100 0.05 3000 50 125 10M WCM4532F2SV-900T30 90±25% 100 0.05 3000 50 125 10M WCM4532F2SV-121T30 120±25% 100 0.05 3000 50 125 10M WCM4532F2SV-201T15 200±25% 100 0.10 1500 50 125 10M WCM4532F2SV-601T15 600±25% 100 0.24 1500 50 125 10M WCM4532F2SV-801T10 800±25% 100 0.24 1000 50 125 10M www.tai-tech.com.tw TAI-TECH WCM4532F2SV-800T30 1000 IMPEDANCE(Ohm) 10 Normal Mode 1 WCM4532F2SV-900T30 1000 Common Mode 100 IMPEDANCE(Ohm) P11 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM4532F2SV-121T30 Common Mode 100 10 Normal Mode 1 10000 Common Mode 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 1 10000 10 WCM4532F2SV-601T15 10000 10000 Common Mode IMPEDANCE(Ohm) 1000 100 10 Normal Mode 1 1000 WCM4532F2SV-801T10 10000 Common Mode 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) IMPEDANCE(Ohm) 1000 WCM4532F2SV-201T15 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) 100 10 Normal Mode 1 0.1 0.1 1 10 100 1000 10000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P12 Reliability and Test Condition (WCM2012, 3216) Item Performance Operating temperature -55~+125℃(Including self - temperature rise) Storage temperature -55~+125℃(on board) Test Condition Electrical Performance Test Z(common mode) Keysight E4991B + Keysight 16197A Refer to standard electrical characteristics list. DCR I.R. Agilent-34420A Agilent-4338B Chroma 19073 Temperature Rise Test 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Rated Current ΔT 40℃Max Reliability Test Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Temperature:125±2℃ High Temperature Exposure(Storage) AEC-Q200 Duration :1000hrs Min. Measured at room temperature after placing for 24±4 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-55±2℃ 30min Min. Temperature Cycling Step2:125±2℃ transition time 1min MAX. Step3:125±2℃ 30min Min. AEC-Q200 Step4:Low temp. Transition time 1min MAX. Number of cycles: 1000 Measured at room temperature after placing for 24±4 hrs. t=24 hours/cycle. Note: Steps 7a & 7b not required. Unpowered. Measurement at 24±2 hours after test conclusion. Moisture Resistance (AEC-Q200) Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Humidity :85±3%R.H, Biased Humidity (AEC-Q200) Temperature:85℃±2℃ Duration: 1000hrs Min. Measured at room temperature after placing for24±4hrs Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Temperature:125±2℃ High Temperature Operational Life (AEC-Q200) External Visual Physical Dimension Resistance to Solvents Duration :1000hrs Min. with 100% rated current. Measured at room temperature after placing for24±4hrs Appearance:No damage. Inspect device construction, marking and workmanship. Electrical Test not required. According to the product specification size measurement According to the product specification size measurement Appearance:No damage. Add aqueous wash chemical - OKEM clean or equivalent. Type Mechanical Shock Appearance:No damage. SMD Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification Lead value Peak value Normal (g’s) duration (D) (ms) Wave form Velocity change (Vi)ft/sec 100 6 Half-sine 12.3 100 6 Half-sine 12.3 3 shocks in each direction along 3 perpendicular axes. (18 shocks). www.tai-tech.com.tw TAI-TECH P13 Item Performance Test Condition IPC/JEDEC J-STD-020E Classification Reflow Profiles Oscillation Frequency:10Hz~2KHz~10Hz for 20 minute Equipment: Vibration checker Total Amplitude:5g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration Test condition : Resistance to Soldering Heat Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Time(s) Temperature ramp/immersion and emersion rate Number of heat cycles 260 ±5 (solder temp) 10 ±1 25mm/s ±6 mm/s 1 Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-55±2℃ 15±1min Thermal shock Step2:125±2℃ within 20Sec. (AEC-Q200) ESD Temperature(℃) Step3:125±2℃ 15±1min Number of cycles: 300 Measured at room temperature after placing fo24±4hrs Appearance:No damage. Direct Contact and Air Discharge PASSIVE COMPONENT HBM ESD Discharge Waveform to a Coaxial Target Test method: AEC-Q200-002 Test mode:Contact Discharge Discharge level:4 KV (Level: 2 ) Solderability Electrical Characterization Flammability a. Method B, 4 hrs @155°C dry heat @235°C±5°C More than 95% of the terminal electrode should be covered Testing Time :5 +0/-0.5 seconds with solder。 b. Method D category 3. (8hours ± 15 min)@ 260°C±5°C Testing Time :30 +0/-0.5 seconds Refer Specification for Approval Summary to show Min, Max, Mean and Standard deviation. Electrical Test not required. V-0 or V-1 are acceptable. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Place the 100mm X 40mm board into a fixture similar to the one shown in below Figure with the component facing down. The apparatus shall consist of mechanical means to apply a force which will bend the board (D) x = 2 mm minimum. The duration of the applied forces shall be 60 (+ 5) sec. The force is to be applied only once to the board. Board Flex Appearance:No damage AEC-Q200,TQI-TECH SPEC V10N 30 SECONDS Terminal Strength(SMD) Appearance:No damage www.tai-tech.com.tw TAI-TECH P14 Reliability and Test Condition (WCM3225, 4532) Item Performance Operating temperature -55~+125℃(Including self - temperature rise) Storage temperature -55~+125℃(on board) Test Condition Electrical Performance Test Z(common mode) Keysight E4991B + Keysight 16197A Refer to standard electrical characteristics list. DCR I.R. Agilent-34420A Agilent-4338B Chroma 19073 Temperature Rise Test Rated Current ΔT 40℃Max 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Temperature:125±2℃ High Temperature Exposure(Storage) AEC-Q200 Duration :1000hrs Min. Measured at room temperature after placing for 24±4 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-55±2℃ 30min Min. Temperature Cycling Step2:125±2℃ transition time 1min MAX. Step3:125±2℃ 30min Min. AEC-Q200 Step4:Low temp. Transition time 1min MAX. Number of cycles: 1000 Measured at room temperature after placing for 24±4 hrs. t=24 hours/cycle. Note: Steps 7a & 7b not required. Unpowered. Measurement at 24±2 hours after test conclusion. Moisture Resistance (AEC-Q200) Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Humidity :85±3% R.H, Biased Humidity (AEC-Q200) Temperature:85℃±2℃ Duration: 1000hrs Min. Measured at room temperature after placing for24±4hrs Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Temperature:125±2℃ High Temperature Operational Life (AEC-Q200) External Visual Physical Dimension Resistance to Solvents Duration :1000hrs Min. with 100% rated current. Measured at room temperature after placing for24±4hrs Appearance:No damage. Inspect device construction, marking and workmanship. Electrical Test not required. According to the product specification size measurement According to the product specification size measurement Appearance:No damage. Add aqueous wash chemical - OKEM clean or equivalent. Type Mechanical Shock Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Peak value Normal (g’s) duration (D) (ms) Wave form Velocity change (Vi)ft/sec SMD 100 6 Half-sine 12.3 Lead 100 6 Half-sine 12.3 3 shocks in each direction along 3 perpendicular axes. (18 shocks). www.tai-tech.com.tw TAI-TECH Item P15 Performance Vibration Resistance to Soldering Heat Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Temperature(℃) Time(s) Temperature ramp/immersion and emersion rate Number of heat cycles 260 ±5 (solder temp) 10 ±1 25mm/s ±6 mm/s 1 Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-55±2℃ 15±1min Thermal shock Step2:125±2℃ within 20Sec. (AEC-Q200) ESD Test Condition IPC/JEDEC J-STD-020E Classification Reflow Profiles Oscillation Frequency:10Hz~2KHz~10Hz for 20 minute Equipment: Vibration checker Total Amplitude:5g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Test condition : Step3:125±2℃ 15±1min Number of cycles: 300 Measured at room temperature after placing fo24±4hrs Appearance:No damage. Direct Contact and Air Discharge PASSIVE COMPONENT HBM ESD Discharge Waveform to a Coaxial Target Test method: AEC-Q200-002 Test mode:Contact Discharge Discharge level:4 KV (Level: 2 ) Solderability Electrical Characterization Flammability a. Method B, 4 hrs @155°C dry heat @235°C±5°C More than 95% of the terminal electrode should be covered Testing Time :5 +0/-0.5 seconds with solder。 b. Method D category 3. (8hours ± 15 min)@ 260°C±5°C Testing Time :30 +0/-0.5 seconds Refer Specification for Approval Summary to show Min, Max, Mean and Standard deviation. Electrical Test not required. V-0 or V-1 are acceptable. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Place the 100mm X 40mm board into a fixture similar to the one shown in below Figure with the component facing down. The apparatus shall consist of mechanical means to apply a force which will bend the board (D) x = 2 mm minimum. The duration of the applied forces shall be 60 (+ 5) sec. The force is to be applied only once to the board. Board Flex Appearance:No damage Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles With the component mounted on a PCB with the device to be tested, apply a 17.7 N (1.8 Kg) force to the side of a device being tested. This force shall be applied for 60 +1 seconds. Also the force shall be applied gradually as not to apply a shock to the component being tested. Terminal Strength(SMD) Appearance:No damage www.tai-tech.com.tw TAI-TECH P16 Wire Wound Type Common Mode Filter WCM4532F2SV-SERIES-HI 1. Features 1. High common mode impedance at high frequency cause excellent noise suppression performance. Halogen 2. WCM4532F2SV series realizes small size and low profile. 4.5x3.2x2.8 mm. 3. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen-free 4. High reliability -Reliability tests comply with AEC-Q200 5. Operating temperature -55~+125℃(Including self - temperature rise) 2. Dimension Series A(mm) B(mm) C(mm) 4532F2SV 4.5±0.2 3.2±0.2 2.8±0.2 D1(mm) D2(mm) 0.90±0.15 1.05±0.15 Units: mm 3. Part Numbering WCM 4532 A B F 2 S V C D E F - 142 T 20 G H I - HI J A: Series B: Dimension C: Material Ferrite Core D: Number of Lines 2=2 lines E: Type S=Shielded , N=Unshielded F: Category Code G: Impedance V=Vehicle 142=1400Ω H: Packaging T=Taping and Reel I: Rated Current 20=2000mA J: Control S/N 4. Specification TAI-TECH Part Number Common mode Impedance (Ω) DC Test Frequency Resistance (MHz) (Ω) max. Rated Current (mA) max. IR Rated Volt. Withstand Volt. (Vdc) (Ω) min. (Vdc) max. max. WCM4532F2SV-900T40-HI 68 min 90 typ. 100 0.050 4000 50 125 10M WCM4532F2SV-231T35-HI 173 min 230 typ. 100 0.050 3500 50 125 10M WCM4532F2SV-421T32-HI 300 min 420 typ. 100 0.055 3200 50 125 10M WCM4532F2SV-601T25-HI 450 min 600 typ. 100 0.060 2500 50 125 10M WCM4532F2SV-901T23-HI 650 min 900 typ. 100 0.070 2300 50 125 10M WCM4532F2SV-142T20-HI 1000 min. 1400 typ. 100 0.100 2000 50 125 10M WCM4532F2SV-282T09-HI 2100 min 2800 typ. 100 0.350 900 50 125 10M Note: When current is applied , the temperature of the part should not exceed 125℃ www.tai-tech.com.tw TAI-TECH WCM4532F2SV-900T40-HI 1000 Common Mode 100 WCM4532F2SV-231T35-HI 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P17 10 Normal Mode 1 0.1 Common Mode 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 1 10 WCM4532F2SV-421T32-HI 1000 10 Normal Mode 100 10 Normal Mode 1 0.1 10 100 1000 1 10000 10 WCM4532F2SV-901T23-HI IMPEDANCE(Ohm) IMPEDANCE(Ohm) 10000 Common Mode 1000 100 10 Normal Mode 1 1000 WCM4532F2SV-142T20-HI 10000 Common Mode 1000 100 FREQUENCY(MHz) FREQUENCY(MHz) 10000 10000 Common Mode 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) Common Mode 1 1000 WCM4532F2SV-601T25-HI 10000 100 1 100 FREQUENCY(MHz) FREQUENCY(MHz) 100 10 Normal Mode 1 0.1 1 10 100 1000 10000 1 FREQUENCY(MHz) Common Mode IMPEDANCE(Ohm) 1000 100 10 Normal Mode 1 0.1 1 10 100 100 FREQUENCY(MHz) WCM4532F2SV-282T09-HI 10000 10 1000 10000 FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P18 5. Schematic Diagram 6. Materials No. Description Specification a. Upper Plate Ferrite b. Core Ferrite Core c Termination Ag/Ni/Sn d Wire Enameled Copper Wire www.tai-tech.com.tw TAI-TECH P19 Reliability and Test Condition (WCM4532-HI) Item Performance Operating temperature -55~+125℃(Including self - temperature rise) Storage temperature -55~+125℃(on board) Test Condition Electrical Performance Test Z(common mode) Keysight E4991B + Keysight 16197A Refer to standard electrical characteristics list. DCR I.R. Agilent-34420A Agilent-4338B Chroma 19073 Temperature Rise Test Rated Current , ΔT :40℃ typ. 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer Reliability Test Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Temperature:125±2℃ High Temperature Exposure(Storage) AEC-Q200 Duration :1000hrs Min. Measured at room temperature after placing for 24±4 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-55±2℃ 30min Min. Temperature Cycling Step2:125±2℃ transition time 1min MAX. Step3:125±2℃ 30min Min. AEC-Q200 Step4:Low temp. Transition time 1min MAX. Number of cycles: 1000 Measured at room temperature after placing for 24±4 hrs. t=24 hours/cycle. Note: Steps 7a & 7b not required. Unpowered. Measurement at 24±2 hours after test conclusion. Moisture Resistance (AEC-Q200) Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Humidity :85±3%R.H, Biased Humidity (AEC-Q200) Temperature:85℃±2℃ Duration: 1000hrs Min. Measured at room temperature after placing for24±4hrs Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Temperature:125±2℃ High Temperature Operational Life (AEC-Q200) External Visual Physical Dimension Resistance to Solvents Duration :1000hrs Min. with 100% rated current. Measured at room temperature after placing for24±4hrs Appearance:No damage. Inspect device construction, marking and workmanship. Electrical Test not required. According to the product specification size measurement According to the product specification size measurement Appearance:No damage. Add aqueous wash chemical - OKEM clean or equivalent. Type Mechanical Shock Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Peak value Normal (g’s) duration (D) (ms) Wave form Velocity change (Vi)ft/sec SMD 100 6 Half-sine 12.3 Lead 100 6 Half-sine 12.3 3 shocks in each direction along 3 perpendicular axes. (18 shocks). www.tai-tech.com.tw TAI-TECH Item P20 Performance Vibration Resistance to Soldering Heat Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Temperature(℃) Time(s) Temperature ramp/immersion and emersion rate Number of heat cycles 260 ±5 (solder temp) 10 ±1 25mm/s ±6 mm/s 1 Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-55±2℃ 15±1min Thermal shock Step2:125±2℃ within 20Sec. (AEC-Q200) ESD Test Condition IPC/JEDEC J-STD-020E Classification Reflow Profiles Oscillation Frequency:10Hz~2KHz~10Hz for 20 minute Equipment: Vibration checker Total Amplitude:5g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Test condition : Step3:125±2℃ 15±1min Number of cycles: 300 Measured at room temperature after placing fo24±4hrs Appearance:No damage. Direct Contact and Air Discharge PASSIVE COMPONENT HBM ESD Discharge Waveform to a Coaxial Target Test method: AEC-Q200-002 Test mode:Contact Discharge Discharge level:4 KV (Level: 2 ) Solderability Electrical Characterization Flammability a. Method B, 4 hrs @155°C dry heat @235°C±5°C More than 95% of the terminal electrode should be covered Testing Time :5 +0/-0.5 seconds with solder。 b. Method D category 3. (8hours ± 15 min)@ 260°C±5°C Testing Time :30 +0/-0.5 seconds Refer Specification for Approval Summary to show Min, Max, Mean and Standard deviation. Electrical Test not required. V-0 or V-1 are acceptable. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Place the 100mm X 40mm board into a fixture similar to the one shown in below Figure with the component facing down. The apparatus shall consist of mechanical means to apply a force which will bend the board (D) x = 2 mm minimum. The duration of the applied forces shall be 60 (+ 5) sec. The force is to be applied only once to the board. Board Flex Appearance:No damage Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles With the component mounted on a PCB with the device to be tested, apply a 17.7 N (1.8 Kg) force to the side of a device being tested. This force shall be applied for 60 +1 seconds. Also the force shall be applied gradually as not to apply a shock to the component being tested. Terminal Strength(SMD) Appearance:No damage www.tai-tech.com.tw TAI-TECH P21 Wire Wound Power Common Mode Filter WCM7060FASV-SERIES-LM 1. Features 1. High reliability -Reliability tests comply with AEC-Q200 Halogen 2. Operating temperature-40~+125℃ (Including self - temperature rise) 2. Dimension C Halogen-free Series A(mm) B(mm) C(mm) D(mm) E(mm) F(mm) G(mm) WCM7060 7.0±0.5 6.0±0.5 3.8 max. 3.5 typ. 1.5±0.5 1.5±0.5 1.7±0.5 - Unit:mm 3. Part Numbering WCM 7060 A B F A S V C D E F 701 - LM G H A: Series B: Dimension C: Material Ferrite Core D: Process Asembled E: Type S=Shielded , N=Unshielded F: Category Code V=Vehicle G: Impedance 701=700Ω H: Laser Marking 4. Specification TAI-TECH Part Number Impedance (Ω) min. typ. Test Frequency (MHz) DC Resistance (mΩ) max. (1 line) Rated Current (A) max. Rated Volt. (Vdc) max. Insulation Resistance (MΩ) min. WCM7060FASV-400-LM 40 70 100 5 15 80 10 WCM7060FASV-101-LM 100 140 100 10 9 80 10 WCM7060FASV-301-LM 225 300 100 10 5 80 10 WCM7060FASV-501-LM 400 500 100 10 5 80 10 WCM7060FASV-701-LM 500 700 100 15 4 80 10 WCM7060FASV-102-LM 800 1020 100 17 3 80 10 WCM7060FASV-132-LM 910 1300 100 20 3 80 10 Note: Measurement board data Material : FR4 Board dimensions : 100 X 50 X 1.6t mm Pattern dimensions: 45 X 30 mm (Double side board) Pattern thickness : 50 μm www.tai-tech.com.tw TAI-TECH WCM7060FASV-400-LM 1000 Common Mode 100 Normal Mode 10 WCM7060FASV-101-LM 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P22 1000 Common Mode 100 Normal Mode 10 1 1 1 10 100 1000 1 10000 10 100 WCM7060FASV-301-LM 1000 Common Mode 100 Normal Mode 10 1 1000 Common Mode 100 Normal Mode 10 1 1 10 100 1000 10000 1 10 FREQUENCY(MHz) 1000 10000 WCM7060FASV-102-LM 10000 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 100 FREQUENCY(MHz) WCM7060FASV-701-LM 10000 Common Mode 100 Normal Mode 10 Common Mode 1000 100 Normal Mode 10 1 1 1 10 100 1000 10000 1 WCM7060FASV-132-LM 10000 Common Mode 1000 100 Normal Mode 10 1 1 10 100 10 100 FREQUENCY(MHz) FREQUENCY(MHz) IMPEDANCE(Ohm) 10000 WCM7060FASV-501-LM 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 10000 1000 FREQUENCY(MHz) FREQUENCY(MHz) 1000 10000 FREQUENCY(MHz) www.tai-tech.com.tw 1000 10000 TAI-TECH P23 5. Schematic Diagram DC Resistance Impedance 6. Materials (WCM7060) No. Description Specification a. Upper Plate Ceramics Core (Black) b. Core Ferrite Core c Wire Enameled Copper d Termination Ag/Ni/Sn + Sn Solder e Mark Laser Marking www.tai-tech.com.tw Insulation Resistance TAI-TECH P24 Wire Wound Power Common Mode Filter WCM5555FASV-SERIES-LM 3. Features 1. High reliability -Reliability tests comply with AEC-Q200 Halogen 2. Operating temperature-40~+125℃ (Including self - temperature rise) 4. Dimension Series Halogen-free A(mm) B(mm) C(mm) D(mm) E(mm) F(mm) G(mm) WCM5555 5.5±0.5 5.5±0.5 3.5 max. 3.3 typ. 1.2±0.5 1.9±0.5 1.1±0.5 - Unit:mm 3. Part Numbering WCM 5555 A B F A S V C D E F 701 - LM G H A: Series B: Dimension C: Material Ferrite Core D: Process Asembled E: Type S=Shielded , N=Unshielded F: Category Code V=Vehicle G: Impedance 701=700Ω H: Laser Marking 4. Specification TAI-TECH Part Number Impedance (Ω) Test Frequency (MHz) DC Resistance (mΩ) max. (1 line) Rated Current (A) max. Rated Volt. (Vdc) max. Insulation Resistance (MΩ) min. min. typ. WCM5555FASV-101-LM 100 140 100 6.0 8.5 80 10 WCM5555FASV-301-LM 150 300 100 7.5 4.8 80 10 WCM5555FASV-501-LM 300 500 100 10.5 4.5 80 10 WCM5555FASV-701-LM 500 700 100 13.0 3.8 80 10 WCM5555FASV-102-LM 750 1000 100 20.0 3.0 80 10 WCM5555FASV-142-LM 1000 1400 100 38.0 2.8 80 10 Note: Measurement board data Material : FR4 Board dimensions : 100 X 50 X 1.6t mm Pattern dimensions: 45 X 30 mm (Double side board) Pattern thickness : 50 μm www.tai-tech.com.tw TAI-TECH WCM5555FASV-101-LM 10000 1000 Common Mode 100 Normal Mode 10 WCM5555FASV-301-LM 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P25 1000 Common Mode 100 Normal Mode 10 1 1 1 10 100 1 1000 10 WCM5555FASV-501-LM 1000 Common Mode 100 Normal Mode 10 1000 Common Mode Normal Mode 100 10 1 1 1 10 100 1 1000 10 WCM5555FASV-102-LM 10000 IMPEDANCE(Ohm) Common Mode Normal Mode 10 1 1 10 100 1000 WCM5555FASV-142-LM 10000 1000 100 100 FREQUENCY(MHz) FREQUENCY(MHz) IMPEDANCE(Ohm) 1000 WCM5555FASV-701-LM 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 10000 100 FREQUENCY(MHz) FREQUENCY(MHz) 1000 1000 Common Mode Normal Mode 100 10 1 1 FREQUENCY(MHz) 10 100 FREQUENCY(MHz) www.tai-tech.com.tw 1000 TAI-TECH P26 Wire Wound Power Common Mode Filter WCM9070FASV-SERIES-LM 5. Features 1. High reliability -Reliability tests comply with AEC-Q200 Halogen 2. Operating temperature-40~+125℃ (Including self - temperature rise) 6. Dimension C Halogen-free Series A(mm) B(mm) C(mm) D(mm) E(mm) F(mm) G(mm) WCM9070 9.0±0.5 7.0±0.2 4.5 max. 5.3 typ. 1.5±0.5 2.1±0.5 1.8±0.5 Unit:mm 3. Part Numbering WCM 9070 A B F A S V C D E F - 701 - LM G H A: Series B: Dimension C: Material Ferrite Core D: Process Asembled E: Type S=Shielded , N=Unshielded F: Category Code V=Vehicle G: Impedance 701=700Ω H: Laser Marking 4. Specification TAI-TECH Part Number Impedance (Ω) Test Frequency (MHz) DC Resistance (mΩ) max. (1 line) Rated Current (A) max. Rated Volt. (Vdc) max. Insulation Resistance (MΩ) min. min. typ. WCM9070FASV-501-LM 300 500 100 6 8.0 80 10 WCM9070FASV-701-LM 500 700 100 9 6.0 80 10 WCM9070FASV-102-LM 750 1000 100 10 5.0 80 10 WCM9070FASV-152-LM 1000 1500 100 15 4.5 80 10 WCM9070FASV-222-LM 1700 2200 100 25 4.0 80 10 WCM9070FASV-272-LM 2000 2700 100 32 3.5 80 10 Note: Measurement board data Material : FR4 Board dimensions : 100 X 50 X 1.6t mm Pattern dimensions: 45 X 30 mm (Double side board) Pattern thickness : 50 μm www.tai-tech.com.tw TAI-TECH WCM9070FASV-501-LM 10000 WCM9070FASV-701-LM 10000 1000 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P27 Common Mode 100 Normal Mode 10 Common Mode 100 Normal Mode 10 1 1 1 10 100 1 1000 10 WCM9070FASV-102-LM Common Mode 1000 1000 1000 WCM9070FASV-152-LM 10000 Common Mode IMPEDANCE(Ohm) IMPEDANCE(Ohm) 10000 100 FREQUENCY(MHz) FREQUENCY(MHz) 100 Normal Mode 10 Normal Mode 100 10 1 1 1 10 100 1000 1 FREQUENCY(MHz) 100 1000 FREQUENCY(MHz) WCM9070FASV-222-LM 10000 10 WCM9070FASV-272-LM 100000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 10000 Common Mode 1000 Normal Mode 100 1000 Common Mode Normal Mode 100 10 1 10 1 10 100 1000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 TAI-TECH P28 Wire Wound Power Common Mode Filter WCM1211FASV-SERIES-LM 7. Features 1. High reliability -Reliability tests comply with AEC-Q200 Halogen 2. Operating temperature-40~+125℃ (Including self - temperature rise) 8. Dimension C Halogen-free Series A(mm) WCM1211 12.0±0.5 B(mm) C(mm) D(mm) E(mm) F(mm) G(mm) 11.0±0.3 6.0 max. 6.7 typ. 2.7±0.5 2.6±0.5 2.6±0.5 Unit:mm 3. Part Numbering WCM 1211 A B F A S V C D E F - 701 - LM G H A: Series B: Dimension C: Material Ferrite Core D: Process Asembled E: Type S=Shielded , N=Unshielded F: Category Code V=Vehicle G: Impedance 701=700Ω H: Laser Marking 4. Specification TAI-TECH Part Number Impedance (Ω) Test Frequency (MHz) DC Resistance (mΩ) max. (1 line) Rated Current (A) max. Rated Volt. (Vdc) max. Insulation Resistance (MΩ) min. min. typ. WCM1211FASV-501-LM 300 500 100 4 11 80 10 WCM1211FASV-701-LM 500 700 100 5 9 80 10 WCM1211FASV-102-LM 750 1000 100 8 7 80 10 WCM1211FASV-172-LM 1200 1700 100 12 5.5 80 10 Note: Measurement board data Material : FR4 Board dimensions : 100 X 50 X 1.6t mm Pattern dimensions: 45 X 30 mm (Double side board) Pattern thickness : 50 μm www.tai-tech.com.tw TAI-TECH WCM1211FASV-501-LM 10000 WCM1211FASV-701-LM 10000 1000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P29 Common Mode 100 Normal Mode 10 Common Mode 1000 100 Normal Mode 10 1 1 1 10 100 1 1000 10 WCM1211FASV-102-LM Common Mode 1000 1000 WCM1211FASV-172-LM 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 10000 100 FREQUENCY(MHz) FREQUENCY(MHz) 100 Normal Mode 10 Common Mode 1000 Normal Mode 100 10 1 1 10 100 1000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) www.tai-tech.com.tw 1000 TAI-TECH P30 Wire Wound Power Common Mode Filter WCM1513FASV-SERIES-LM 9. Features 1. High reliability -Reliability tests comply with AEC-Q200 Halogen 2. Operating temperature-40~+125℃ (Including self - temperature rise) 10. Dimension C Halogen-free Series A(mm) WCM1513 15.0±0.5 B(mm) C(mm) D(mm) E(mm) F(mm) G(mm) 13.0±0.4 6.0 max. 9.3 Typ. 2.7±0.5 3.6±0.5 2.8±0.5 Unit:mm 3. Part Numbering WCM 1513 A F A S V C D E F B - 551 - LM G H A: Series B: Dimension C: Material Ferrite Core D: Process Asembled E: Type S=Shielded , N=Unshielded F: Category Code V=Vehicle G: Impedance 551=550Ω H: Laser Marking 4. Specification TAI-TECH Part Number Impedance (Ω) min. typ. DC Resistance Test (mΩ) max. Frequency (MHz) (1 line) Rated Current (A) max. Rated Volt. (Vdc) max. Insulation Resistance (MΩ) min. WCM1513FASV-101-LM 60 100 100 2.0 20 125 10 WCM1513FASV-301-LM 200 300 100 3.5 14 125 10 WCM1513FASV-551-LM 450 550 100 4.0 10 125 10 WCM1513FASV-701-LM 500 700 100 5.0 10 125 10 Note: Measurement board data Material : FR4 Board dimensions : 100 X 50 X 1.6t mm Pattern dimensions: 45 X 30 mm (Double side board) Pattern thickness : 50 μm www.tai-tech.com.tw TAI-TECH WCM1513FASV-101-LM 10000 1000 Normal Mode 100 WCM1513FASV-301-LM 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) P31 Common Mode 10 1000 Normal Mode 100 Common Mode 10 1 1 1 10 100 1 1000 10 WCM1513FASV-551-LM 10000 IMPEDANCE(Ohm) IMPEDANCE(Ohm) 1000 WCM1513FASV-701-LM 10000 1000 Normal Mode 100 100 FREQUENCY(MHz) FREQUENCY(MHz) Common Mode 10 1000 Normal Mode 100 Common Mode 10 1 1 1 10 100 1000 1 10 100 FREQUENCY(MHz) FREQUENCY(MHz) 5. Schematic Diagram DC Resistance Impedance 6. Materials (WCM5555, 7060, 9070, 1211, 1513) No. Description Specification a. Upper Plate Plastic b. Core Ferrite Core c Wire Enameled Copper d Termination Ag/Ni/Sn + Sn Solder e Mark Laser Marking www.tai-tech.com.tw Insulation Resistance 1000 TAI-TECH P32 7. Reliability and Test Condition (WCM5555, 7060, 9070, 1211, 1513) Item Performance Operating temperature -40~+125℃ (Including self - temperature rise) Storage temperature -40~+125℃ (on board) Test Condition Electrical Performance Test Z(common mode) Agilent E4991A + Keysight 16092A Refer to standard electrical characteristics list. Agilent-34420A I.R. Chroma 19073 Temperature Rise Test Rated Current ≧ 1A ΔT 40℃Max 1.Applied the allowed DC current. 2.Temperature measured by digital surface thermometer DCR Reliability Test Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Temperature:125±2℃ High Temperature Exposure(Storage) AEC-Q200 Duration :1000hrs Min. Measured at room temperature after placing for 24±4 hrs. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 30min Min. Temperature Cycling Step2:125±2℃ transition time 1min MAX. Step3:125±2℃ 30min Min. AEC-Q200 Step4:Low temp. Transition time 1min MAX. Number of cycles: 1000 Measured at room temperature after placing for 24±4 hrs. t=24 hours/cycle. Note: Steps 7a & 7b not required. Unpowered. Measurement at 24±2 hours after test conclusion. Moisture Resistance (AEC-Q200) Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Humidity :85±3% R.H, Biased Humidity (AEC-Q200) Temperature:85℃±2℃ Duration: 1000hrs Min. Measured at room temperature after placing for24±4hrs Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Temperature:125±2℃ High Temperature Operational Life (AEC-Q200) External Visual Physical Dimension Resistance to Solvents Duration :1000hrs Min. with 100% rated current. Measured at room temperature after placing for24±4hrs Appearance:No damage. Inspect device construction, marking and workmanship. Electrical Test not required. According to the product specification size measurement According to the product specification size measurement Appearance:No damage. Add aqueous wash chemical - OKEM clean or equivalent. Type Mechanical Shock Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Peak value Normal (g’s) duration (D) (ms) Wave form Velocity change (Vi)ft/sec SMD 100 6 Half-sine 12.3 Lead 100 6 Half-sine 12.3 3 shocks in each direction along 3 perpendicular axes. (18 shocks). www.tai-tech.com.tw TAI-TECH Item P33 Performance Test Condition IPC/JEDEC J-STD-020E Classification Reflow Profiles Oscillation Frequency:10Hz~2KHz~10Hz for 20 minute Equipment: Vibration checker Total Amplitude:5g Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Vibration Test condition : Resistance to Soldering Heat Appearance:No damage. Impedance:within±15% of initial value RDC:within ±15% of initial value and shall not exceed the specification value Electrical Characterization Flammability Temperature ramp/immersion and emersion rate Number of heat cycles 260 ±5 (solder temp) 10 ±1 25mm/s ±6 mm/s 1 Step2:125±2℃ within 20Sec. (AEC-Q200) Solderability Time(s) Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Condition for 1 cycle Step1:-40±2℃ 15±1min Thermal shock ESD Temperature(℃) Step3:125±2℃ 15±1min Number of cycles: 300 Measured at room temperature after placing fo24±4hrs Appearance:No damage. Direct Contact and Air Discharge PASSIVE COMPONENT HBM ESD Discharge Waveform to a Coaxial Target Test method: AEC-Q200-002 Test mode:Contact Discharge Discharge level:4 KV (Level: 2 ) a. Method B, 4 hrs @155°C dry heat @235°C±5°C More than 95% of the terminal electrode should be covered with Testing Time :5 +0/-0.5 seconds solder。 b. Method D category 3. (8hours ± 15 min)@ 260°C±5°C Testing Time :30 +0/-0.5 seconds Refer Specification for Approval Electrical Test not required. Summary to show Min, Max, Mean and Standard deviation. V-0 or V-1 are acceptable. Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles Place the 100mm X 40mm board into a fixture similar to the one shown in below Figure with the component facing down. The apparatus shall consist of mechanical means to apply a force which will bend the board (D) x = 2 mm minimum. The duration of the applied forces shall be 60 (+ 5) sec. The force is to be applied only once to the board. Board Flex Appearance:No damage Preconditioning: Run through reflow for 3 times.( IPC/JEDEC J-STD-020E Classification Reflow Profiles With the component mounted on a PCB with the device to be tested, apply a 17.7 N (1.8 Kg) force to the side of a device being tested. This force shall be applied for 60 +1 seconds. Also the force shall be applied gradually as not to apply a shock to the component being tested. Terminal Strength(SMD) Appearance:No damage www.tai-tech.com.tw TAI-TECH P34 8. Soldering and Mounting 8-1. Recommended PC Board Pattern WCM2012F2S WCM3216F2S WCM3225F2S WCM4532F2S L(mm) 2.60 3.70 4.40 4.80 H(mm) 1.40 1.60 3.50 3.80 G1(mm 1.25 1.90 1.60 2.50 G2(mm 0.45 0.40 0.60 0.70 WCM4532F2S-HI WCM5555 FAS L(mm) 5.00 5.9 WCM7060FAS WCM9070FAS WCM1211FAS WCM1513FAS 8.0 11.0 14.0 17.0 H(mm) 3.60 4.3 4.5 5.0 7.9 9.2 G1(mm 3.00 3.3 3.5 6.0 7.4 10.4 G2(mm 1.20 1.9 1.5 2.0 2.5 3.8 8-2. Soldering Mildly activated rosin fluxes are preferred. TAI-TECH terminations are suitable for re-flow soldering systems. If hand soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools. 8-2.1 Soldering Reflow: Recommended temperature profiles for lead free re-flow soldering in Figure 1. Table 1.1&1.2 (J-STD-020E) 8-2.2 Soldering Iron: Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that a soldering iron must be employed the following precautions are recommended. (Figure 2.) ‧Preheat circuit and products to 150℃ ‧350℃ tip temperature (max) ‧Never contact the ceramic with the iron tip ‧1.0mm tip diameter (max) ‧Use a 20 watt soldering iron with tip diameter of 1.0mm ‧Limit soldering time to 4~5sec. Fig.1 Soldering Reflow Fig.2 Iron soldering temperature profiles Iron Soldering PRE-HEATING SOLDERING TEMPERATURE(°C) within 4~5s NATURAL COO LING 350 150 Over 60s Gradual cooling TIM E(sec.) Iron Soldering times:1 times max Reflow times: 3 times max www.tai-tech.com.tw TAI-TECH P35 Table (1.1): Reflow Profiles Profile Type: Pb-Free Assembly Preheat -Temperature Min(Tsmin) -Temperature Max(Tsmax) -Time(ts)from(Tsmin to Tsmax) 150℃ 200℃ 60-120seconds Ramp-up rate(TLto Tp) 3℃/second max. Liquidus temperature(TL) Time(tL)maintained above TL 217℃ 60-150 seconds Classification temperature(Tc) See Table (1.2) Time(tp) at Tc- 5℃ (Tp should be equal to or less than Tc.) < 30 seconds Ramp-down rate(Tp to TL) 6℃ /second max. Time 25℃ to peak temperature 8 minutes max. Tp: maximum peak package body temperature, Tc: the classification temperature. For user (customer) Tp should be equal to or less than Tc. Table (1.2) Package Thickness/Volume and Classification Temperature (Tc) PB-Free Assembly Package Thickness Volume mm3 2000
WCM 2012F2SV-670T04 价格&库存
很抱歉,暂时无法提供与“WCM 2012F2SV-670T04”相匹配的价格&库存,您可以联系我们找货
