Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
TEL: +886 2 2995 0535
http://www.chinsan.com/products/
ALUMINUM ELECTROLYTIC CAPACITORS
CEE Series
Extra Low impedance
Load life 2,000~5,000 hours at 105℃
SPECIFICATIONS
Item
Performance Characteristics
Category Temperature Range
-55 ~ +105℃
Working Voltage Range
50 ~ 100Vdc
Capacitance Range
3.3 ~ 470 μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Rated Voltage (V)
tanδ(Max)
50
63
80
100
∅4~∅10
0.10
0.08
0.08
0.07
∅12.5
0.10
0.08
0.08
0.07
(∅6.3~∅10) I=0.01CV or 3μA whichever is greater impress the rated voltage for 2 minutes.
(∅12.5) I=0.03CV or 4μA whichever is greater impress the rated voltage for 1 minutes.
I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V)
Rated voltage (V)
50
63
80
100
Z(-25℃)/Z(+20℃)
2
2
2
2
Z(-55℃)/Z(+20℃)
3
3
3
3
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC
voltage with the rated voltage is applied for 5,000 hours (∅4~6.3x5.8, ∅6.3x7.7, ∅8x6.2 for 2,000 hours) at 105°C
Endurance
Capacitance change
≦ ±30% of the initial value
Dissipation factor(tanδ)
≦ 300% of the specified value
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 105℃ without voltage applied.
Shelf Life
Capacitance change
Leakage current
≦ 200% of the specified value
Others
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
Safety Vent (≧8×10.5)
Code
Size
ФD
L
α
A
B
C
W
P
0458
4×5.8
4
5.8
+0.4
-0.1
4.3
4.3
4.8
0.5~0.8
1
0558
5×5.8
5
5.8
+0.4
-0.1
5.3
5.3
5.8
0.5~0.8 1.3
6358
6.3×5.8
6.3
5.8
+0.4
-0.1
6.6
6.6
7.3
0.5~0.8 2.1
6377
6.3×7.7
6.3
7.7
±0.3
6.6
6.6
7.3
0.5~0.8 2.1
0862
8×6.2
8
6.2
+0.4
-0.1
8.3
8.3
8.8
0.5~0.8 2.2
8
10.5 0.5
8.3
8.3
9.1
0.8~1.2 3.1
08A5
8×10.5
10A5
10C5
12D5
10×10.5
10×12.5
12.5×13.5
1216
12.5×16
10 10.5 0.5
10 12.5 0.5
12.5 13.5 1.0
10.3 10.3 11 0.8~1.2 4.6
12.8 12.8 13.8 0.8~1.2 4.6
12.5
16
1.0
≦6.3Ф
≧8Ф
Marking
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
CEE
NO.:
1、Tape & Reel (TR)\ Cut Tape (CT)\ Digi-Reel。
2、Diagram of Dimensions (unit : mm.),and Recommended soldering pad dimensions。
Size Code
ΦD
L
A
B
C
W
P
α
a
b
0862
8
6.2
8.3
8.3
8.8
0.5~0.8
2.2
0.4/-0.1
08A5
8
10.5
8.3
8.3
9.1
0.8~1.2
3.1
1010
10
10.0
10.3
10.3
11.0
0.8~1.2
10A5
10
10.5
10.3
10.3
11.0
12D5
12.5
13.5
12.8
12.8
13.8
PUBLISH DATE
2022-03-28
c
0.5
2.1
3.0
10.1
11.0
1.6
2.5
4.6
0.5
4.0
12.0
2.5
0.8~1.2
4.6
0.5
4.0
12.0
2.5
0.8~1.2
4.6
1.0
4.0
15.4
3.0
Safety Vent (≥ 8x10.5)
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
On rated
Capacitance Voltage
1
CEE1A102MCB10A5
1000
Working
±20%
(Vdc)
10
Surge
Voltage
(Vdc)
Category
Tanδ
Leakage
Temp
@ 25℃
Current
Range
(120Hz)
(uA)
(Max)
(2 min.)
-55°C ~
105°C
0.19
100
Rated Ripple Rated Ripple
Current
Current
(mA rms)
(mA rms)
@ 105℃
@ 105℃
120Hz
100kHz
850mA
@ 100 kHz
Impedance
@20℃
(Ω max/
100kHz)
0.09Ω
Dimensions (mm)
Endurance
Appearance
@ 105℃
(Hours)
5000 Hrs
@ 105°C
Drawing
DΦ
L
10.0mm 10.5mm
a
d
P
4.6mm
No
2
CEE1C471MCB08A5
470
±20%
16
3
CEE1C681MCB1010F2M9
680
±20%
16
4
CEE1E221MCB08A5F2
220
±20%
25
5
CEE1E471MCB10A5
470
±20%
25
6
CEE1E471MCB10A5F2
470
±20%
25
7
CEE1H221MCB10A5
220
±20%
50
8
CEE1J220MCB0862
22
±20%
63
9
CEE1J221MCB12D5
220
±20%
63
10 CEE1V331MCB10A5
330
±20%
35
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
-55°C ~
105°C
0.16
75.2
0.16
108.8
0.14
55
0.14
117.5
0.14
117.5
0.10
110
0.08
13.86
0.08
415.8
0.12
115.5
600mA
@ 100 kHz
850mA
@ 100 kHz
600mA
@ 100 kHz
850mA
@ 100 kHz
850mA
@ 100 kHz
670mA
@ 100 kHz
120mA
@ 100 kHz
800mA
@ 100 kHz
850mA
@ 100 kHz
0.17Ω
0.09Ω
0.17Ω
0.09Ω
0.09Ω
0.18Ω
1.2Ω
0.16Ω
0.16Ω
5000 Hrs
@ 105°C
2000 Hrs
@ 105°C
2000 Hrs
@ 105°C
5000 Hrs
@ 105°C
2000 Hrs
@ 105°C
5000 Hrs
@ 105°C
2000 Hrs
@ 105°C
5000 Hrs
@ 105°C
5000 Hrs
@ 105°C
8.0mm 10.5mm
3.1mm
10.0mm 10.0mm
4.6mm
8.0mm 10.5mm
3.1mm
10.0mm 10.5mm
4.6mm
10.0mm 10.5mm
4.6mm
10.0mm 10.5mm
4.6mm
8.0mm
6.2mm
2.2mm
12.5mm 13.5mm
4.6mm
10.0mm 10.5mm
4.6mm
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
李科高
张铭仁
聂婷
很抱歉,暂时无法提供与“CEE1H221MCB10A5”相匹配的价格&库存,您可以联系我们找货
