Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
ER
Series
Low impedance, high ripple current and miniature size with 7 to 9 mm height
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-40 ~ +105℃
Working Voltage Range
6.3 ~ 35Vdc
Capacitance Range
33 ~ 470 μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Rated Voltage (V)
6.3
10
16
25
35
tanδ(Max)
0.24
0.20
0.16
0.14
0.14
I=0.01CV or 3 μA, whichever is greater
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 2 minutes
V : Rated voltage (V)
Rated voltage (V)
6.3
10
16
25
35
Z(-40℃)/Z(+20℃)
8
6
6
5
4
(at 120Hz)
The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for
3,000 hours at 105℃.
Endurance
Capacitance change
≦ ±25% of the initial value(6.3V、10V:≦±30%)
Dissipation factor(tanδ)
≦ 200% of the specified value
Leakage current
≦ specified value
500 hours at 105℃ without voltage applied.
Shelf Life
Capacitance change
Leakage current
Others
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
ФD
ФD
dФ
E
8×7
8×9
ФD + 0.5 Max
0.45
0.50
F
3.5
a
L+ 1.0 Max
PART NUMBER SYSTEM( Example : 25V 220µF )
R 1 E 2 2 1 M N N 0 8 0 9
Special Request
Size code(0809 : 8×9)
Lead length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (220μF)
Voltage code (25V)
Series code (ER)
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
ER
NO.:
2022-03-25
PUBLISH DATE
Unit (mm):
P=12.7±1.0
H=18.5±0.5
P0=12.7±0.2
P1=3.85±0.5
P2=6.35±1.0
W =18.0±0.5
F=2.5+0.8 /-0.2
W0=12.5MIN
ΦD0=4.0±0.2
Original
FIG-1
Rated
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
t=0.7±0.2
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Category
Tanδ
Leakage
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
(2 min.)
(mA rms) (mΩ max/ (mΩ max/
@ 105℃
120Hz)
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
a
d
F
No
100kHz
1
ER1C101MP26307RU
100 µF
±20%
16 V
-40~+105
400
980
3000
6.3
7
2.5
FIG-1
2
ER1V470MP26307P9U
47 µF
±20%
35 V
-40~+105
210
3000
6.3
7
2.5
FIG-1
3 ER1H220MP26307EF5U
22 µF
±20%
50 V
-40~+105
230
2200
5000
6.3
7
2.5
FIG-1
4
2.2 µF
±20%
50 V
-40~+105
80
3000
6.3
7
2.5
FIG-1
ER1H2R2MP26307P9U
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
1.Sleeve Color: Brown.
2.Suffix F5 indicates the life of the capacitor is 5000 hrs.
3.Suffix P9 : indicates Black PET sleeve.
4.Suffix U indicates convex rubber cover.
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Customer
Digi-Key
SERIES
ER
NO.:
2022-03-25
PUBLISH DATE
Unit(mm):
P=12.7±1.0
H0=16.0±0.5
P0=12.7±0.2
W =18.0±0.5
P1=3.85±0.5
W0=12.5MIN
P2=6.35±1.0
ΦD0=4.0±0.2
F1=5.0+0.8/-0.2
H=18.5±0.5
t=0.7±0.2
Original
FIG-1
Rated
Tolerance
No.
CHINSAN
Part No.
Part No.
(uF)
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Category
Tanδ
Leakage
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
(2 min.)
@ 105℃
120Hz)
100kHz)
100
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
a
d
F1
No
5000
8
7
5
FIG-1
100kHz
1
ER1C221MP50807EF5R
220 µF
±20%
16 V
-40~+105
1100
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Customer
Digi-Key
SERIES
ER
NO.:
2022-03-25
PUBLISH DATE
Unit (mm):
P=12.7±1.0
H=18.5±0.5
P0=12.7±0.2
W =18.0±0.5
P1=3.85±0.5
W0=12.5MIN
P2=6.35±1.0
ΦD0=4.0+0.2
F=5.0+0.8/-0.2
t=0.7±0.2
H1=9.5±1.0
Original
FIG-1
Rated
Tolerance
No.
CHINSAN
Part No.
Part No.
(uF)
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Category
Tanδ
Leakage
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
(2 min.)
@ 105℃
120Hz)
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
a
d
F
No
100kHz
1
ER1E221MP51007RU
220 µF
±20%
25 V
-40~+105
800
400
3000
10
7
5
FIG-1
2
ER1C331MP51007RU
330 µF
±20%
16 V
-40~+105
1000
400
3000
10
7
5
FIG-1
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
2.Suffix U indicates convex rubber cover.
很抱歉,暂时无法提供与“ER1H2R2MP26307P9U”相匹配的价格&库存,您可以联系我们找货
