RF1C471MP308B5E
RF1C471MP308B5E
    CHINSAN(金山)
    径向,Can
    470 µF 16 V 铝电解电容器 径向,Can 105°C 时为 8000 小时
RF1C471MP308B5E 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 RF http://www.chinsan.com/products/ Series  Miniaturized, Low E.S.R and Low impedance  Suitable for use in high ripple current capability  Load life 6,000~12,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -55~ +105℃ Working Voltage Range 6.3 ~ 100Vdc Capacitance Range 6.8 ~18,000μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Endurance Rated Voltage (V) 6.3 10 16 25 35 50 63 100 tanδ(Max) 0.22 0.19 0.16 0.14 0.12 0.10 0.09 0.08 The above values should be increased by 0.02 for every additional 1000μF I=0.01CV or 3μA whichever is greater I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V) \Thethe above should increased by 0.02 for every additional 1000μF Impress ratedvalues voltage for 2 be minutes Rated voltage (V) 6.3 10 16 25 35 50 63 100 Z(-55℃)/Z(+20℃) 4 3 3 3 3 3 3 3 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 6,000~12,000 hours at 105°C Size Life time (hours) ≦ ±25% of the initial value Capacitance change ≦6.3Ф 6,000 8Ф 8,000 Dissipation factor(tanδ) ≦200% of the specified value 10 Ф 10,000 Leakage current ≦ specified value ≧12.5Ф 12,000 The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 5 6.3 8 ФD R 12.5 1 H 2 7 2 M N N 1 8 18 0.5 0.5 0.6 0.6 0.6 0.8 0.8 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max PART NUMBER SYSTEM( Example : 50V 2700µF ) F 16 ФD + 0.5 Max Фd a  10 4 0 Special Request Size code(1840 : 18×40) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (2700μF) Voltage code (50V) Series code (RF) L + 1.5Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES RF NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ (Hours) Drawing DΦ L a d F No 1 RF1H220MRE0511U / 22 µF ±20% 50 V / -55~+105 / / / 195 / 700 6000 5 11 / / 2 FIG-1 2 RF2A330MS31016ER / 33 µF ±20% 100 V / -55~+105 / / / 630 / 320 10000 10 16 / / 5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES RF NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8/-0.2 ΦD0=4.0±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ (Hours) Drawing DΦ L a d F No 1 RF2A8R2MP20511EU / 8.2 µF ±20% 100 V / -55~+105 / / / 90 / 8000 6000 5 11 / / 2.5 FIG-1 2 RF1V470MP20511EU / 47 µF ±20% 35 V / -40~+105 / / / 345 / 220 6000 5 11 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES RF NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8 /-0.2 ΦD0=4.0±0.2 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN Φd=0.5±0.05 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ (Hours) Drawing DΦ L a d F No 1 RF1E151MP26311EF7U / 150 µF ±20% 25 V / -40~+105 / / / 700 / 170 7000 6.3 11 / / 2.5 FIG-1 2 RF1H470MP26311ERU / 47 µF ±20% 50 V / -55~+105 / / / 450 / 380 6000 6.3 11 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix U indicates convex rubber cover. Suffix F7 indicates the life of the capacitor is 7000 hrs. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES RF NO.: 2022-03-25 PUBLISH DATE Unit (mm): Original CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 W =18.0±0.5 F=3.5+0.8/-0.2 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 FIG-1 Tolerance No. P=12.7±1.0 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ (Hours) Drawing DΦ L 1 RF1C681MP30815EF10 / 680 µF ±20% 16 V / -40~+105 / / / 1600 / 59 10000 8 2 RF1C471MP308B5E / 470 µF ±20% 16 V / -40~+105 / / / 945 / 56 8000 8 3 RF1V391MP30820E / 390 µF ±20% 35 V / -40~+105 / / 1500 / / 29 8000 8 a d F No / / 3.5 FIG-1 11.5 / / 3.5 FIG-1 / 3.5 FIG-1 15 20 / ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix F10 indicates the life of the capacitor is 10000 hrs. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES RF NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 RF2A330MP508B5ERU / 33 µF Working ±20% (Vdc) 100 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -55~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ / 120Hz 100kHz / 724 120Hz) 100kHz) / 700 Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 8000 Drawing DΦ L 8 a d F1 No 11.5 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES RF NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F1=5.0+0.8/-0.2 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated RF1E331MP508B5E / 330 µF Working Capacitance Voltage (%) 1 H0=16.0±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 H=18.5±0.5 ±20% (Vdc) 25 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -40~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ / 120Hz 100kHz / 945 120Hz) 100kHz) / 56 Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 8000 Drawing DΦ L 8 a d F1 No 11.5 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES RF NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated RF1K470MNN0812 RF1K221MNN1025E RF1C102MP51016E RF1C152MP51020ER RF1C222MP51025E RF1E102MP51020E RF1V681MP51020E RF1H221MP51016E RF1K181MP51020 / / / / / / / / / 47 µF 220 µF 1000 µF 1500 µF 2200 µF 1000 µF 680 µF 220 µF 180 µF Working Capacitance Voltage (%) 1 2 3 4 5 6 7 8 9 H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% ±20% (Vdc) 80 V 80 V 16 V 16 V 16 V 25 V 35 V 50 V 80 V Surge Voltage (Vdc) / / / / / / / / / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -55~+105 -55~+105 -40~+105 -40~+105 -40~+105 -40~+105 -40~+105 -55~+105 -55~+105 / / / / / / / / / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ / / / / / / / / / 120Hz 100kHz 620 / / / 2480 / / / / / 1620 2000 2180 / 3000 2500 1370 1040 120Hz) 100kHz) / / / / / / / / / 290 55 23 20 / 28 28 60 150 Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 8000 10000 10000 10000 10000 10000 10000 10000 10000 Drawing DΦ L 8 10 10 10 10 10 10 10 10 12 25 16 20 25 20 20 16 20 a d F No / / / / / / / / / / / / / / / / / / 3.5 5 5 5 5 5 5 5 5 Original Original FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES RF NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 H=18.5±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0+0.2 F=5.0+0.8/-0.2 t=0.7±0.2 H1=9.5±1.0 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 2 3 4 5 6 RF1E471MP51012ERU RF1E681MP51016U RF1E821MP51016EU RF1V331MP51012EU RF1V471MP51016EU RF2A470MP51013EU / / / / / / 470 µF 680 µF 820 µF 330 µF 470 µF 47 µF Working ±20% ±20% ±20% ±20% ±20% ±20% (Vdc) 25 V 25 V 25 V 35 V 35 V 100 V Surge Voltage (Vdc) / / / / / / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -40~+105 -40~+105 -40~+105 -40~+105 -40~+105 -55~+105 / / / / / / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ / / / / / / 120Hz 100kHz / / / / / / 1330 1760 2150 1400 1760 730 120Hz) 100kHz) / / / / / / 39 28 40 39 30 180 Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 10000 10000 10000 10000 10000 10000 Drawing DΦ L 10 10 10 10 10 10 12 16 16 12 16 13 a d F No / / / / / / / / / / / / 5 5 5 5 5 5 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Brown. Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
RF1C471MP308B5E 价格&库存
很抱歉,暂时无法提供与“RF1C471MP308B5E”相匹配的价格&库存,您可以联系我们找货
