EP1E102MNN1216
EP1E102MNN1216
    CHINSAN(金山)
    Radial, Can
    ALUMINUM ELECTROLYTIC CAPACITORS
EP1E102MNN1216 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 EP Series  Miniaturized, Low ESR and Low impedance  Suitable for use in high ripple current capability  Load life 4,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -40 ~ +105℃ Working Voltage Range 10 ~ 100Vdc Capacitance Range 68 ~1,800 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) 10 16 25 35 100 tanδ(Max) 0.19 0.16 0.14 0.12 0.08 The above values should be increased by 0.02 for every additional 1000μF I=0.01CV or 3μA whichever is greater I : Leakage current (μA) C : Rated capacitance (μF) V : Rated voltage (V) Impress the rated voltage for2 minutes Rated voltage (V) 10 16 25 35 100 Z(-40℃)/Z(+20℃) 6 6 5 4 3 (at 120Hz) The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 4,000 hours at 105℃. Endurance Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 500 hours at 105℃ without voltage applied. Shelf Life Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ ) ≦ 200% of the specified value Leakage current Others  DIMENSIONS (mm)  E ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W ФD 12.5×12 ФD ФD + 0.5 Max Фd 0.6 F 5.0 a L + 1.0 Max PART NUMBER SYSTEM( Example : 35V 470µF ) P 1 V 4 7 1 M N N 1 2 1 2 Special Request Size code(1212 : 12.5×12) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (470μF) Voltage code (35V) Series code (EP) Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES EP NO.: Rated Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) 2022-03-25 PUBLISH DATE Category Tanδ Leakage Ripple ESR Impedance Temp @ 25℃ Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mΩ max/ (mΩ max/ @ 105℃ 120Hz) 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 100kHz 1 EP1C102MNN1212 / 1000 µF ±20% 16 V / -40~+105 / / 1300 / 150 4000 12.5 12 / / 5 --- 2 EP1E102MNN1216 / 1000 µF ±20% 25 V / -40~+105 / / 1450 / 110 4000 12.5 16 / / 5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Brown.
EP1E102MNN1216 价格&库存
很抱歉,暂时无法提供与“EP1E102MNN1216”相匹配的价格&库存,您可以联系我们找货
