GV2E182MND3555
GV2E182MND3555
    CHINSAN(金山)
    Radial, Can - Snap-In
    ALUMINUM ELECTROLYTIC CAPACITORS
GV2E182MND3555 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 GV Series  High ripple current  Load life 5,000 hours at 85℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +85℃ Working Voltage Range 200 ~ 500Vdc Capacitance Range 56 ~ 2200 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) 200 ~ 450 500 tanδ(Max) 0.15 0.20 The above values should be increased by 0.02 for every additional 1000μF I=0.02CV or 3000μA,whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 5 minutes Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated voltage (V) 200 ~250 400 420 ~ 450 500 Z(-25℃)/Z(+20℃) 4 4 8 8 ≦ specified value Leakage current The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000 hours at 85℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Shelf Life ≦ 200% of the specified value Leakage current Others Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) Terminal Code : ND : Standard Terminal Code :K6 (ø35) M a x Negative mark PC board Pin-out D+1 Max 6 * 2- 2 Safety vent A * V 2 S 5 6 1 M N D L±2 3 5 5 0 6 0 C M a x 6 ± . 13 . 0 T e r m i n a l T e r m i n a l PART NUMBER SYSTEM( Example : 420V 560µF ) G b o a r d ° p i n - o u t ° - V e n t 4.0±0.5 L±2 M a x 0 B D + 1 .5 ±0 10 + P C S l e e v e 2 2 . 5 Sleeve  (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 5,000 hours at 85°C ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Endurance  V : Rated voltage (V) Y Special Request Size code(3550 : 35×50) Terminal length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code(560μF) Voltage code(420V) Series code (GV) 4 - 2 B = p o s i t i v e A & C = b l a n k Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) GV NO.: 2022-03-25 PUBLISH DATE Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (2 min.) (mA rms) (mA rms) (mΩ max/ (mΩ max/ @ 85℃ @ 85℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 85℃ Appearance Drawing (Hours) D Φ L a d F No 1 GV2E152MND3551 / 1500 µF ±20% 250 V / -25~+85 / / 4000 / / / 5000 35 51 / / 10 --- 2 GV2E182MND3555 / 1800 µF ±20% 250 V / -25~+85 / / 5000 / / / 5000 35 55 / / 10 --- 3 GV2S102MK63570Y / 1000 µF ±20% 420 V / -25~+85 / / 3720 / / / 5000 35 70 / / 22.5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Dark Blue. Suffix Y represents assembly without gasket. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
GV2E182MND3555 价格&库存
很抱歉,暂时无法提供与“GV2E182MND3555”相匹配的价格&库存,您可以联系我们找货
