LL2H6R8MP51020E
LL2H6R8MP51020E
    CHINSAN(金山)
    径向,Can
    6.8 µF 500 V 铝电解电容器 径向,Can 46.8 欧姆 @ 120Hz 105°C 时为 5000 小时
LL2H6R8MP51020E 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 LL Series  High ripple current capability  High stability  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +105℃ Working Voltage Range 160 ~ 500Vdc Capacitance Range 4.7~560 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Endurance Shelf Life Rated Voltage (V) 160 ~ 250 400 ~ 450 500 tanδ(Max) 0.15 ·0.20 0.20 The above values should be increased by 0.02 for every additional 1000μF I≦0.03CV + 10 μA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes Rated voltage (V) 160 ~ 250 400 420 ~ 450 500 Z(-25℃)/Z(+20℃) 3 5 6 8 The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 500 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 10 ФD 12.5 16 18 ФD + 0.5 Max Фd 0.6 0.6 0.8 0.8 F 5.0 5.0 7.5 7.5 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max a  L (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 ~ 5,000 hours at 105°C Size Life time (hours) ≦ ±20% of the initial value Capacitance change ≦ 6.3Ф 2,000 Dissipation factor(tanδ) ≦ 200% of the specified value =8Ф 3,000 Leakage current ≦ specified value ≧ 10Ф 5,000 Others  V : Rated voltage (V) PART NUMBER SYSTEM( Example : 350V 15µF ) L 2 V 1 5 0 M N N 1 2 2 0 Special Request Size code(1220 : 12.5×20) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (15μF) Voltage code (350V) Series code (LL) L + 1.5 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES LL NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 LL2G4R7HCD1012 / 4.7 µF 5%~20% 400 V / -25~+105 / / 50 / / / 5000 10 12 / / 5 FIG-1 2 LL2C560MSD1020R / 56 µF ±20% 160 V / -25~+105 / / / 750 / / 5000 10 20 / / 5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES LL NO.: 2022-03-25 PUBLISH DATE Unit (mm) P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated LL2G100MPH1013S / 10 µF Working Capacitance Voltage (%) 1 H=20.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0+0.2 t=0.7±0.2 ±20% (Vdc) 400 V Surge Voltage (Vdc) / Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category -25~+105 Tanδ / (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 180 / / 8000 100kHz) / Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 5000 10 13 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES LL NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 LL2H6R8MP51020E / 6.8 µF ±20% 500 V / -25~+105 / / 200 / 46800 / 5000 10 20 / / 5 FIG-1 2 LL2H6R8MP51016E / 6.8 µF ±20% 500 V / -25~+105 / / / 230 46800 26610 5000 10 16 / / 5 FIG-1 3 LL2H4R7MP51016R / 4.7 µF ±20% 500 V / -25~+105 / / 105 / / / 5000 10 16 / / 5 FIG-1 4 LL2W4R7MP51016R / 4.7 µF ±20% 450 V / -25~+105 / / 105 / 30000 28000 5000 10 16 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES LL NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=15.0±1.0 H=18.5±0.5 P0=15.0±0.2 W =18.0±0.5 P1=5.0±0.5 W0=12.5MIN P2=7.5±1.0 ΦD0=4.0±0.2 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 LL2H100MP51220ER / 10 µF ±20% 500 V / -25~+105 / / / 315 / 3500 5000 12.5 20 / / 5 FIG-1 2 LL2W100MP51220ER / 10 µF ±20% 450 V / -25~+105 / / 315 / / 3500 5000 12.5 20 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
LL2H6R8MP51020E 价格&库存
很抱歉,暂时无法提供与“LL2H6R8MP51020E”相匹配的价格&库存,您可以联系我们找货
