Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
MW
Series
Low ESR
Load life 2,000 hours at 105℃
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-25 ~ +105℃
Working Voltage Range
160 ~ 450Vdc
Capacitance Range
33 ~ 560 μF
Capacitance Tolerance
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Endurance
±20% (at 25℃ and 120Hz)
Rated Voltage (V)
tanδ(Max)
160 ~ 450
0.15
I=0.03CV + 10μA
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 2 minutes
Rated voltage (V)
160~250
400
420 ~450
Z(-25℃)/Z(+20℃)
3
5
6
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for
1,000 hours at 105℃ without voltage applied.
≦ ±20% of the initial value
Capacitance change
Dissipation factor(tanδ)
≦ 200% of the specified value
Leakage current
Others
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with
the rated ripple current is applied for 2,000 hours at 105°C.
Capacitance change
Leakage current
Shelf Life
V : Rated voltage (V)
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
ФD
16
ФD
M W
0.8
0.8
F
7.5
7.5
PART NUMBER SYSTEM( Example : 450V 150µF )
2 W 1 5 1 M N N 1 8
ФD + 0.5 Max
Фd
a
18
5 0
Special Request
Size code(1850 : 18×50)
Lead length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (150μF)
Voltage code(450V)
Series code(MW)
L + 1.5 Max
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
MW
NO.:
2022-03-25
PUBLISH DATE
Unit(mm):
P=30.0±1.0
P0=15.0±0.2
P1=3.75±0.5
P2=7.5±1.0
F=7.5+0.8/-0.2
Original
FIG-1
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
H=18.5±0.5
W =18.0±0.5
W0=12.5MIN
ΦD0=4.0±0.2
t=0.7±0.2
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Rated
Rated
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃ Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(Max)
Category
Tanδ
(uA)
(mA rms) (mA rms) (mΩ max/ (mΩ max/
(2 min.) @ 105℃ @ 105℃ 120Hz)
120Hz
100kHz
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
a
d
F
No
1
MW2E220MNN1016R
22 µF
±20%
250 V
-25~+105
300
2000
10
16
5
Original
2
MW2G121MNN1830A6EF3
120 µF
±20%
400 V
-25~+105
900
400
3000
18
30
7.5
Original
3
MW2G100MNN0816
10 µF
±20%
400 V
-25~+105
100
2000
8
16
3.5
Original
4
MW2G121MNN1635
120 µF
±20%
400 V
-25~+105
800
2000
16
35
7.5
Original
5
MW2G121MNN1825
120 µF
±20%
400 V
-25~+105
650
2000
18
25
7.5
Original
6
MW2G151MNN1835
150 µF
±20%
400 V
-25~+105
750
2000
18
35
7.5
Original
7
MW2G470MNN1225
47 µF
±20%
400 V
-25~+105
510
2000
12.5
25
5
Original
8
MW2G680MNN1623
68 µF
±20%
400 V
-25~+105
430
2000
16
23
7.5
Original
9
MW2G820MNN1625
82 µF
±20%
400 V
-25~+105
500
2000
16
25
7.5
Original
10
MW2G680MNN1625A4E
68 µF
±20%
400 V
-25~+105
550
400
2000
16
25
7.5
Original
11
MW2S680MNN1625A4ER
68 µF
±20%
420 V
-25~+105
700
400
2000
16
25
7.5
Original
12
MW2S101MNN1630A4E
100 µF
±20%
420 V
-25~+105
800
400
2000
16
30
7.5
Original
13
MW2S100MNN1015
10 µF
±20%
420 V
-25~+105
100
2000
10
15
5
Original
14
MW2S151MNN1835
150 µF
±20%
420 V
-25~+105
1250
2000
18
35
7.5
Original
15
MW2S820MNN1825A4EF3
82 µF
±20%
420 V
-25~+105
620
400
3000
18
25
7.5
Original
16
MW2S121MNN1830A4ES
120 µF
±20%
420 V
-25~+105
85
700
400
2000
18
30
7.5
Original
17
MW2W101MNN1630A4EJ
100 µF
±20%
450 V
-25~+105
850
1120
780
300
2000
16.5
30
7.5
Original
18
MW2W820MNN1825A4EF3
82 µF
±20%
450 V
-25~+105
750
400
3000
18
25
7.5
Original
19
MW2W101MNN1830A4E
100 µF
±20%
450 V
-25~+105
900
1120
400
2000
18
30
7.5
Original
MW2W181MNN1840A4EF3
180 µF
±20%
450 V
-40~+105
1100
1640
400
3000
18
40
7.5
Original
21
MW2W820MNN1625A4E
82 µF
±20%
450 V
-25~+105
700
1100
850
430
2000
16
25
7.5
Original
22
MW2W151MNN1840
150 µF
±20%
450 V
-25~+105
750
2000
18
40
7.5
Original
23
MW2W470MNN1230
47 µF
±20%
450 V
-25~+105
350
2000
12.5
30
5
Original
24
MW2W221DNN1850A6E
220 µF
25%~20%
450 V
-25~+105
1450
300
2000
18
50
7.5
Original
25
MW2W121MNN16P1E
120 µF
±20%
450 V
-25~+105
1000
400
2000
16
35.5
7.5
Original
26
MW2W220MPI1620R
22 µF
±20%
450 V
-40~+105
550
6850
2000
16
FIG-1
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
Sleeve Color: Black.
Suffix F3 indicates the life of the capacitor is 3000 hrs.
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
很抱歉,暂时无法提供与“MW2W470MNN1230”相匹配的价格&库存,您可以联系我们找货
