PA2W680MNN1250
PA2W680MNN1250
    CHINSAN(金山)
    Radial, Can
    ALUMINUM ELECTROLYTIC CAPACITORS
PA2W680MNN1250 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 PA http://www.chinsan.com/products/ Series ● 105℃ Long Life (5,000 hours), Ultra Miniature size  Body diameter of Ф10mm to Ф14.5mm with high ripple current capability SPECIFICATIONS Performance Characteristics Item Category Temperature Range -25 ~ +105℃ Working Voltage Range 400 ~ 450Vdc Capacitance Range 27 ~ 120 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) 400 420 450 tanδ(Max) 0.20 0.20 0.20 I=0.03CV + 10μA I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes Rated voltage (V) 400 420 ~ 450 Z(-25℃)/Z(+20℃) 5 6 V : Rated voltage (V) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 5,000 hours at 105°C. Endurance Shelf Life Capacitance change Dissipation factor(tanδ) ≦ ±20% of the initial value Leakage current ≦specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  ≦ 200% of the specified value Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 10 ФD P 0.6 0.6 0.8 F 5.0 5.0 7.5 L + 1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max L + 2.0 Max PART NUMBER SYSTEM( Example : 450V 39µF ) A 2 W 3 9 0 M N N 1 0 14.5 Фd a  12.5 ФD + 0.5 Max 5 5 Special Request Size code(1055 : 10×55) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (39μF) Voltage code (450V) Series code (PA) Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PA NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 PA2W680MNN1250 / 68 µF ±20% 450 V / -25~+105 / / 550 / / / 5000 12.5 50 / / 5 FIG-1 2 PA2W560MSD1052 / 56 µF ±20% 450 V / -25~+105 / / 450 / / / 5000 10 52 / / 5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
PA2W680MNN1250 价格&库存
很抱歉,暂时无法提供与“PA2W680MNN1250”相匹配的价格&库存,您可以联系我们找货
