PF1E471MPN1012
PF1E471MPN1012
    CHINSAN(金山)
    Radial, Can
    ALUMINUM ELECTROLYTIC CAPACITORS
PF1E471MPN1012 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 PF Series   General standard size Load life 2,000 hours at 105℃  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -40 ~ +105℃ -25 ~ +105℃ Working Voltage Range 6.3 ~ 100Vdc 160 ~ 450Vdc Capacitance Range 0.47 ~ 22,000μF 0.47 ~ 560 μF Capacitance Tolerance Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) ±20% (at 25℃ and 120Hz) Rated Voltage (V) 6.3 10 16 25 35 50 63 100 tanδ(Max) 0.26 0.22 0.18 0.16 0.14 0.12 0.10 0.10 160 ~ 250 400 ~ 450 0.15 0.20 The above values should be increased by 0.02 for every additional 1000μF I=0.01CV or 3μA whichever is greater(6.3 ~ 100V) I=0.03CV + 10μA(160 ~ 450V) I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 6.3 10 16 25 35 50 63 100 160 ~ 250 Z(-40℃)/Z(+20℃) 12 10 8 5 4 3 3 3 — — — Z(-25℃)/Z(+20℃) — — — — — — — — 3 6 6 350 400 ~ 450 (at 120Hz) Endurance The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 2,000 hours at 105℃. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value ≦ specified value Leakage current Shelf Life The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 5 6.3 8 ФD P 12.5 16 20 22 ФD +1.0 Max 0.5 0.5 0.6 0.6 0.6 0.8 0.8 1.0 1.0 F 2.0 2.5 3.5 5.0 5.0 7.5 7.5 10 10 L+1.5 Max ≤ 35 L+1.5Max ≥ 40 L+2.0 Max L+1.5 Max PART NUMBER SYSTEM( Example : 200V 330µF ) F 18 ФD +0.5 Max Фd a  10 2 D 3 3 1 M N N 1 8 P 1 Special Request Size code(18P1 : 18×35.5) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code(330μF) Voltage code(200V) Series code(PF) L+2.0 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 PF1H3R3MC60511UP / 3.3 µF ±20% 50 V / -40~+105 / / 29 / / / 2000 5 11 / / 2 FIG-1 2 PF2D330MCE1212F3 / 33 µF ±20% 200 V / -25~+105 / / 500 / / / 3000 12.5 12 / / 5 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) PF NO.: Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) 2022-03-25 PUBLISH DATE (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 PF2C560MSD1020 / 56 µF ±20% 160 V / -25~+105 / / 750 / / / 2000 10 20 / / 5 --- 2 PF2D560MSD1020F4R / 56 µF ±20% 200 V / -25~+105 / / / 760 / / 4000 10 20 / / 5 -- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: 2022-03-25 PUBLISH DATE Unit(mm): Original No. Part No. Customer Capacitance Part No. (uF) On rated PF1H330MPZ0511RU / 33 µF Working Capacitance Voltage (%) 1 P0=12.7±0.2 W =18.0±0.5 W0=12.5MIN P1=3.85±0.5 ΦD0=4.0±0.2 P2=6.35±1.0 F=2.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 FIG-1 Tolerance CHINSAN P=12.7±1.0 ±20% (Vdc) 50 V Surge Voltage (Vdc) / Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category -40~+105 Tanδ / (uA) Dimensions (mm) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) / 120Hz 100kHz 90 / / 100kHz) / Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 2000 5 11 / / 2 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8/-0.2 ΦD0=4.0±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 PF1H220MP20511R / 22 µF ±20% 50 V / -55~+105 / / 75 / / / 2000 5 11 / / 2.5 FIG-1 2 PF1H470MP20511U / 47 µF ±20% 50 V / -40~+105 / / 110 / / / 2000 5 11 / / 2.5 FIG-1 3 PF1H220MP20511RU / 22 µF ±20% 50 V / -40~+105 / / 83 / 8220 / 2000 5 11 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P2=6.35±1.0 F=2.5+0.8/-0.2 ΦD0=4.0±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 P1=3.85±0.5 W =18.0±0.5 W0=12.5MIN t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 PF1V101MP26311U / 100 µF ±20% 35 V / -40~+105 / / 160 320 / 1270 2000 6.3 11 / / 2.5 FIG-1 2 PF1E101MP26311U / 100 µF ±20% 25 V / -40~+105 / / 145 / / / 2000 6.3 11 / / 2.5 FIG-1 3 PF1E221MP26311U / 220 µF ±20% 25 V / -40~+105 / / 210 / / 700 2000 6.3 11 / / 2.5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix U indicates convex rubber cover. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 H=18.5±0.5 t=0.7±0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 1 PF1H101MPN0812 / 100 µF ±20% 50 V / -40~+105 / / 210 / / 1090 2000 8 12 / / 5 FIG-1 2 PF1V221MP50812 / 220 µF ±20% 35 V / -40~+105 / / 270 / / / 2000 8 12 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 PF2W4R7MP51011S / 4.7 µF ±20% 450 V / -25~+105 / / 34 / / / 2000 10 11 / / 5 FIG-1 2 PF2W4R7MP51016R / 4.7 µF ±20% 450 V / -25~+105 / / 60 / / / 2000 10 16 / / 5 FIG-1 3 PF2W6R8MP51020 / 6.8 µF ±20% 450 V / -25~+105 / / / 280 22000 26610 2000 10 20 / / 5 FIG-1 4 PF1V471MP51016 / 470 µf ±20% 35 V / -55~+105 / / 521 / / / 2000 10 16 / / 5 FIG-1 5 PF1V102MP51020R / 1000 µF ±20% 35 V / -40~+105 / / 1049 / / 120 2000 10 20 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: 2022-03-25 PUBLISH DATE Unit (mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F1=5.0+0.8/-0.2 H=18.5±0.5 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H0=16.0±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 1 PF1E470MPN0511U / 47 µF ±20% 25 V / -40~+105 / / 90 / / 3080 2000 5 11 / / 5 FIG-1 2 PF1H100MPN0511U / 10 µF ±20% 50 V / -40~+105 / / 54 / / 10860 2000 5 11 / / 5 FIG-1 3 PF1H220MPN0511U / 22 µF ±20% 50 V / -40~+105 / / 83 / / 4930 2000 5 11 / / 5 FIG-1 4 PF1V470MPN0511U / 47 µF ±20% 35 V / -40~+105 / / 100 / / / 2000 5 11 / / 5 FIG-1 5 PF1H2R2MPN0511U / 2.2 µF ±20% 50 V / -40~+105 / / 23 / / / 2000 5 11 / / 5 FIG-1 6 PF1H4R7MPN0511U / 4.7 µF ±20% 50 V / -40~+105 / / 34 / / / 2000 5 11 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. Suffix U indicates convex rubber cover. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated PF1E221MPN0812P / 220 µF Working Capacitance Voltage (%) 1 H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 ±20% (Vdc) 25 V Surge Voltage (Vdc) / Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category -40~+105 Tanδ / (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) / 120Hz 100kHz 250 / / 100kHz) / Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F1 No 2000 8 12 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 P0=12.7±0.2 P1=3.85±0.5 P2=6.35±1.0 F=5.0+0.8/-0.2 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) H=18.5±0.5 W =18.0±0.5 W0=12.5MIN ΦD0=4.0±0.2 t=0.7±0.2 On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 PF0J102MPN1009 / 1000 µF ±20% 6.3 V / -40~+105 / / 400 / / / 2000 10 9 / / 5 FIG-1 2 PF1V331MPN1012 / 330 µF ±20% 35 V / -40~+105 / / 100 / / / 2000 10 12 / / 5 FIG-1 3 PF1E471MPN1012 / 470 µF ±20% 25 V / -40~+105 / / 380 / / / 2000 10 12 / / 5 FIG-1 4 PF1V221MPN1012 / 220 µF ±20% 35 V / -40~+105 / / 320 / / / 2000 10 12 / / 5 FIG-1 5 PF2U100MPN1013P / 10 µF ±20% 300 V / -25~+105 / / 110 / / / 2000 10 13 / / 5 FIG-1 6 PF1E102MPN1020R / 1000 µF ±20% 25 V / -40~+105 / / 960 / / / 2000 10 20 / / 5 FIG-1 7 PF0J222MPN1020 / 2200 µF ±20% 6.3 V / -40~+105 / / 830 / / / 2000 10 20 / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PF NO.: FIG-1 FIG-2 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (℃) (Max) Category Tanδ (uA) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ 120Hz) 120Hz 100kHz 100kHz) Dimensions (mm) Endurance Appearance @ 105℃ Drawing (Hours) DΦ L a d F No 1 PF2D100MNN1012R / 10 µF ±20% 200 V / -25~+105 / / 95 / / / 2000 10 12 / / 5 FIG-1 2 PF1C101MNN0511U / 100 µF ±20% 16 V / -40~+105 / / 100 / / / 2000 5 11 / / 2 FIG-2 3 PF1C222MNN1020 / 2200 µF ±20% 16 V / -40~+105 / / 1050 / / / 2000 10 20 / / 5 FIG-1 4 PF1H220MNN0511 / 22 µF ±20% 50 V / -40~+105 / / 83 / / / 2000 5 11 / / 2 FIG-1 5 PF1H220MNN0511U / 22 µF ±20% 50 V / -40~+105 / / 83 / / / 2000 5 11 / / 2 FIG-2 6 PF1H332MNN1832 / 3300 µF ±20% 50 V / -40~+105 / / 1456 / / / 2000 18 32 / / 7.5 FIG-1 7 PF1HR47MNN0511U / 0.47 µF ±20% 50 V / -40~+105 / / 11 / / 100000 2000 5 11 / / 2 FIG-2 8 PF1J222MNN1832 / 2200 µF ±20% 63 V / -40~+105 / / 1600 / / / 2000 18 32 / / 7.5 FIG-1 9 PF1V470MNN6311U / 47 µF ±20% 35 V / -40~+105 / / 115 / / 3000 2000 6.3 11 / / 2.5 FIG-2 10 PF2A101MNN0825 / 100 µF ±20% 100 V / -40~+105 / / 250 / / / 2000 8 25 / / 3.5 FIG-1 11 PF2A102MNN1836 / 1000 µF ±20% 100 V / -40~+105 / / 1300 / / 60 2000 18 36 / / 7.5 FIG-1 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 12 PF2W100MNN1020 / 10 µF ±20% 450 V / -25~+105 / / 85 / / / 2000 10 20 / / 5 FIG-1 13 PF2W6R8MNN1013 / 6.8 µF ±20% 450 V / -25~+105 / / 48 / / / 2000 10 13 / / 5 FIG-1 14 PF1V471MNN1012 / 470 µF ±20% 35 V / -40~+105 / / 440 / / / 2000 10 12 / / 5 FIG-1 15 PF2W100MNN1020 / 10 µF ±20% 450 V / -25~+105 / / 85 / / / 2000 10 20 / / 5 FIG-1 16 PF1J100MNN0511U / 10 µF ±20% 63 V / -40~+105 / / 50 / / / 2000 5 11 / / 2 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Suffix U indicates convex rubber cover.
PF1E471MPN1012 价格&库存
很抱歉,暂时无法提供与“PF1E471MPN1012”相匹配的价格&库存,您可以联系我们找货
