Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
PK
Series
Long life and high temperature, down size and high ripple current
Load life 3,000 hours at 105℃
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
Working Voltage Range
-25 ~ +105℃
200 ~ 500Vdc
Capacitance Range
56 ~ 2,200μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Rated Voltage (V)
200
220
250
350
400
420
450
500
tanδ(Max)
0.15
0.15
0.15
0.15
0.15
0.15
0.15
0.20
The above values should be increased by 0.02 for every additional 1000μF
I=0.02CV or 3000μA,whichever is smaller
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 5 minutes
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Rated voltage (V)
200~250
350
400
420 ~ 450
500
Z(-25℃)/Z(+20℃)
4
4
4
8
8
Dissipation factor(tanδ)
≦ 200% of the specified value
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 105℃ without voltage applied.
≦ ±20% of the initial value
Capacitance change
Shelf Life
Leakage current
Others
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
Terminal Code : ND : Standard
Terminal Code :K6 (ø35)
D+1 Max
.5
±0
10
P C
S l e e v e
6
2- 2
L±2 Max
4.0±0.5
b o a r d
6
B
Safety vent
A
p i n - o u t
2 2 . 5
PC board Pin-out
M a x
Negative mark
D + 1
Sleeve
P
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 3,000 hours at 105°C
Capacitance change
Endurance
V : Rated voltage (V)
C
V e n t
L±2
M a x
6 ±
. 13 . 0
PART NUMBER SYSTEM( Example : 420V 470µF )
K 2 S 4 7 1 M N D 3 5 4 5
Special Request
Size code(3545 : 35×45)
Terminal length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (470μF)
Voltage code (420V)
Series code (PK)
T e r m i n a l
T e r m i n a l
4 -
2
B = p o s i t i v e
A & C = b l a n k
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
On rated
Capacitance Voltage
1
PK2G121MW42230RY
120 µF
Working
±20%
(Vdc)
400 V
Surge
Voltage
(Vdc)
PK
NO.:
Rated
Rated
Category
Tanδ
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
-25~+105
(mA rms) (mA rms) (mΩ max/ (mΩ max/
(2 min.) @ 105℃ @ 105℃
2022-03-25
PUBLISH DATE
120Hz
100kHz
770
120Hz)
100kHz)
Dimensions (mm)
Endurance
@ 105℃
Appearance
Drawing
(Hours)
D
Φ
L
a
d
F
No
3000
22
30
10
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Sleeve Color: Black.
Suffix Y represents assembly without gasket.
Customer
Digi-Key
SERIES
PK
NO.:
FIG-2
FIG-1
Tolerance
No.
CHINSAN
Part No.
Part No.
(uF)
2022-03-25
PUBLISH DATE
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Rated
Rated
Category
Tanδ
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
(2 min.) @ 105℃ @105℃
120Hz
100kHz
120Hz)
100kHz)
Dimensions (mm)
Endurance
@ 105℃
(Hours)
Appearance
D
Φ
Drawing
L
a
d
F
No
1
PK2W221MND2535E
220 µF
±20%
450 V
-25~+105
1520
1210
3000
25 35
10
FIG-1
2
PK2S221MND2545
220 µF
±20%
420 V
-25~+105
1200
3000
25 45
10
FIG-2
3
PK2D152MND3540
1500 µF
±20%
200 V
-25~+105
3340
3000
35 40
10
FIG-1
4
PK2D471MND2530
470 µF
±20%
200 V
-25~+105
1500
3000
25 30
10
FIG-1
5
PK2F471MND2551
470 µF
±20%
315 V
-25~+105
2000
3000
25 51
10
FIG-1
6
PK2G101MND2230
100 µF
±20%
400 V
-25~+105
700
3000
22 30
10
FIG-1
7
PK2W121MND2230
120 µF
±20%
450 V
-25~+105
720
3000
22 30
10
FIG-1
8
PK2W101MND2230RY
100 µF
±20%
450 V
-25~+105
1300
3000
22 30
10
FIG-2
9
PK2W680MND2225R
68 µF
±20%
450 V
-25~+105
600
2230
3000
22 25
10
FIG-1
10
PK2E471MND2535
470 µF
±20%
250 V
-25~+105
1650
430
3000
25 35
10
FIG-1
11
PK2E102MND3040R
1000 µF
±20%
250 V
-40~+105
3060
156
3000
30 40
10
FIG-1
12
PK2W121MND2230R
120 µF
±20%
450 V
-25~+105
820
3000
22 30
10
FIG-1
13
PK2D102MND3035
1000 µF
±20%
200 V
-25~+105
1975
3000
30 35
10
FIG-1
14
PK2W561MND3045Y
560 µF
±20%
450 V
-25~+105
2240
420
290
3000
30 45
10
FIG-2
15
PK2W331MND2545RY
330 µF
±20%
450 V
-25~+105
1700
460
3000
25 45
10
FIG-2
16
PK2G221MND3025
220 µF
±20%
400 V
-25~+105
1100
3000
30 25
10
FIG-1
17
PK2W331MND3040ER
330 µF
±20%
450 V
-25~+105
1600
250
3000
30 40
10
FIG-1
18
PK2H101MND2230Y
100 µF
±20%
500 V
-25~+105
650
3000
22 30
10
FIG-2
19
PK2F681MND3050
680 µF
±20%
315 V
-25~+105
2170
3000
30 50
10
FIG-1
PK2H680MND2225RY
68 µF
±20%
500 V
-25~+105
600
3000
22 25
10
FIG-2
21
PK2W391MND2553
390 µF
±20%
450 V
-25~+105
2300
480
3000
25 53
10
FIG-1
22
PK2W681MND3050RY
680 µF
±20%
450 V
-25~+105
2500
400
3000
30 50
10
FIG-2
23
PK2W221MND3030R
220 µF
±20%
450 V
-25~+105
1360
900
550
3000
30 30
10
FIG-1
24
PK2E152MND3551RP
1500 µF
±20%
250 V
-25~+105
3000
160
3000
35 51
10
FIG-1
25
PK2W151MND2530RY
150 µF
±20%
450 V
-25~+105
1100
3000
25 30
10
FIG-2
26
PK2W151MND2235Y
150 µF
±20%
450 V
-25~+105
920
1770
3000
22 35
10
FIG-2
27
PK1K332MND3035
3300 µF
±20%
80 V
-25~+105
2780
3000
30 35
10
FIG-1
28
PK2G471MND2550
470 µF
±20%
400 V
-25~+105
1450
3000
25 50
10
FIG-1
29
PK2S271MND2540Y
270 µF
±20%
420 V
-40~+105
1250
3000
25 40
10
FIG-2
30
PK2W181MND2245
180 µF
±20%
450 V
-25~+105
850
3000
22 45
10
FIG-1
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
很抱歉,暂时无法提供与“PK2D102MND3035”相匹配的价格&库存,您可以联系我们找货
