PL2G271MND2245Y
PL2G271MND2245Y
    CHINSAN(金山)
    径向,Can-卡入式
    270 µF 400 V 铝电解电容器 径向,Can - 卡入式 105°C 时为 2000 小时
PL2G271MND2245Y 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 PL   Series Load life 2,000 hours at 105℃ Large size for PCB board mounting hole type  SPECIFICATIONS Performance Characteristics Item Category Temperature Range -40 ~ +105℃ -25 ~ +105℃ Working Voltage Range 16 ~ 100Vdc 160 ~ 600Vdc Capacitance Range 560 ~ 47,000μF 39 ~ 2,700μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Rated Voltage (V) 16 25 35 50 63 80 100 ~ 250 350 ~ 450 475~600 tanδ(Max) 0.35 0.35 0.25 0.25 0.25 0.20 0.15 0.15 0.20 The above values should be increased by 0.02 for every additional 1000μF I=0.02CV or 3000μA,whichever is smaller I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 5 minutes Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated voltage (V) 16 25 35 50 63 Z(-40℃)/Z(+20℃) 15 10 8 6 6 Z(-25℃)/Z(+20℃) — — — — — — 160 ~ 250 400 420 ~ 600 — — — 4 4 8 — (at 120Hz) Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 500 hours at 105℃ without voltage applied. ≦ ±20% of the initial value Capacitance change Dissipation factor(tanδ) ≦ 200% of the specified value Shelf Life ≦ 200% of the specified value Leakage current Others Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) Terminal Code : ND : Standard Terminal Code :K6 (ø35) D+1 Max 6 2- 2 L±2 Max 4.0±0.5 0 b o a r d ° 6 0 B * - Safety vent L .5 ±0 10 + P C S l e e v e A * p i n - o u t ° 2 2 . 5 PC board Pin-out M a x Negative mark D + 1 Sleeve  P 80 100 ~100 5 5 The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with the rated ripple current is applied for 2,000 hours at 105°C. ≦ ±20% of the initial value Capacitance change Endurance  V : Rated voltage (V) C - V e n t L±2 M a x 6 ± . 13 . 0 PART NUMBER SYSTEM( Example : 500V 100µF ) 2 H 1 0 1 M N D 2 5 4 5 Special Request Size code(2545 : 25×45) Terminal length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (100μF) Voltage code (500V) Series code (PL) T e r m i n a l T e r m i n a l 4 - 2 B = p o s i t i v e A & C = b l a n k Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 PL2G152MK64575 / 1500 µF Working ±20% (Vdc) 400 V Surge Voltage (Vdc) / PL NO.: Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -25~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @ 105℃ / 2022-03-25 PUBLISH DATE 120Hz 100kHz 3100 / 120Hz) 100kHz) / / Dimensions (mm) Endurance @ 105℃ Appearance Drawing (Hours) D Φ L a d F No 2000 45 75 / / 22.5 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES PL NO.: FIG-2 FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) 2022-03-25 PUBLISH DATE On rated Working Capacitance Voltage (%) (Vdc) Surge Voltage (Vdc) Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ 120Hz 100kHz 120Hz) 100kHz) Dimensions (mm) Endurance @ 105℃ (Hours) Appearance D Φ Drawing L a d F No 1 PL2W181VND2240R / 180 µF 10%~20% 450 V / -25~+105 / / 1200 / 1310 860 2000 22 40 / / 10 FIG-1 2 PL2W151VND2241A / 150 µF 10%~20% 450 V / -25~+105 / / 1300 1859 / / 2000 22 41 / / 10 FIG-1 3 PL2W471MN63540E / 470 µF 450 V / -25~+105 / / 2010 / 282 / 2000 35 40 / / 10 FIG-1 4 PL2W221VND2245R / 220 µF 10%~20% 450 V / -25~+105 / / / 3250 / / 2000 22 45 / / 10 FIG-1 5 PL1H332MND2235 / 3300 µF ±20% 50 V / -40~+105 / / 2235 / / / 2000 22 35 / / 10 FIG-1 6 PL2C122MND3041 / 1200 µF ±20% 160 V / -25~+105 / / 2315 / / / 2000 30 41 / / 10 FIG-1 7 PL2D561MND2241 / 560 µF ±20% 200 V / -25~+105 / / 1450 / / / 2000 22 41 / / 10 FIG-1 8 PL2D681MND2245 / 680 µF ±20% 200 V / -25~+105 / / 1630 / / / 2000 22 45 / / 10 FIG-1 9 PL2E182MND3561 / 1800 µF ±20% 250 V / -25~+105 / / 2700 / / / 2000 35 61 / / 10 FIG-1 10 PL2G101MND2225 / 100 µF ±20% 400 V / -25~+105 / / 580 / / / 2000 22 25 / / 10 FIG-1 11 PL2G102MND3570 / 1000 µF ±20% 400 V / -25~+105 / / 2400 / / / 2000 35 70 / / 10 FIG-1 ±20% Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 12 PL2G681MND3545 / 680 µF ±20% 400 V / -25~+105 / / 1900 / / / 2000 35 45 / / 10 FIG-1 13 PL2S151MND2240 / 150 µF ±20% 420 V / -25~+105 / / 740 / / / 2000 22 40 / / 10 FIG-1 14 PL2S181MND2245 / 180 µF ±20% 420 V / -25~+105 / / 900 / / / 2000 22 45 / / 10 FIG-1 15 PL2S221MND2245 / 220 µF ±20% 420 V / -25~+105 / / 880 / / / 2000 22 45 / / 10 FIG-1 16 PL2S331MND3041 / 330 µF ±20% 420 V / -25~+105 / / 1250 / / / 2000 30 41 / / 10 FIG-1 17 PL2W181MND2245 / 180 µF ±20% 450 V / -25~+105 / / 750 / / / 2000 22 45 / / 10 FIG-1 18 PL2W271MND3030 / 270 µF ±20% 450 V / -25~+105 / / 1300 / / / 2000 30 30 / / 10 FIG-1 19 PL2W271MND3031 / 270 µF ±20% 450 V / -25~+105 / / 850 / / / 2000 30 31 / / 10 FIG-1 20 PL2W331MND3051 / 330 µF ±20% 450 V / -25~+105 / / 1310 / / / 2000 30 51 / / 10 FIG-1 21 PL2W681MND3550 / 680 µF ±20% 450 V / -25~+105 / / 1850 / / / 2000 35 50 / / 10 FIG-1 22 PL2W391MND2553 / 390 µF ±20% 450 V / -25~+105 / / 2110 / / / 2000 25 53 / / 10 FIG-1 23 PL2W121MND2230R / 120 µF ±20% 450 V / -25~+105 / / 820 / 1200 1000 2000 22 30 / / 10 FIG-1 24 PL2G331MND2545Y / 330 µF ±20% 400 V / -25~+105 / / 1280 / / / 2000 25 45 / / 10 FIG-2 25 PL2W151MND2235R / 150 µF ±20% 450 V / -25~+105 / / 1020 / / / 2000 22 35 / / 10 FIG-1 26 PL2W181MND2241AR / 180 µF ±20% 450 V / -25~+105 / / 2250 1350 / / 2000 22 41 / / 10 FIG-1 27 PL2D221MND2225R / 220 µF ±20% 200 V / -25~+105 / / 820 / / / 2000 22 25 / / 10 FIG-1 28 PL2D152MND3050E / 1500 µF ±20% 200 V / -25~+105 / / 2770 / 133 / 2000 30 50 / / 10 FIG-1 29 PL2W151MND2530R / 150 µF ±20% 450 V / -25~+105 / / 900 / / 1210 2000 25 30 / / 10 FIG-1 30 PL2G680MND2220R / 68 µF ±20% 400 V / -25~+105 / / 450 / / / 2000 22 20 / / 10 FIG-1 31 PL2W391MND2548Y / 390 µF ±20% 450 V / -25~+105 / / 1600 / 400 / 2000 25 48 / / 10 FIG-2 32 PL2W271MND2250 / 270 µF ±20% 450 V / -25~+105 / / 1300 / 840 / 2000 22 50 / / 10 FIG-1 33 PL2W331MND2551 / 330 µF ±20% 450 V / -25~+105 / / 1310 / 700 / 2000 25 51 / / 10 FIG-1 34 PL2W391MND3040 / 390 µF ±20% 450 V / -25~+105 / / 1500 / 580 360 2000 30 40 / / 10 FIG-1 35 PL2W101MND2225RP / 100 µF ±20% 450 V / -25~+105 / / 700 / 2400 1360 2000 22 25 / / 10 FIG-1 36 PL2W391MND2550Y / 390 µF ±20% 450 V / -25~+105 / / 1670 / 610 400 2000 25 50 / / 10 FIG-2 37 PL2G561MND3045Y / 560 µF ±20% 400 V / -25~+105 / / 1700 / / / 2000 30 45 / / 10 FIG-2 38 PL2G221MND2235Y / 220 µF ±20% 400 V / -25~+105 / / 1180 / / / 2000 22 35 / / 10 FIG-2 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 http://www.chinsan.com/products/ 39 PL2W561MND3045Y / 560 µF ±20% 450 V / -25~+105 / / 2030 5800 @75℃ / 280 2000 30 45 / / 10 FIG-2 40 PL2G271MND2245Y / 270 µF ±20% 400 V / -25~+105 / / 1250 / / / 2000 22 45 / / 10 FIG-2 41 PL2W331MND2545Y / 330 µF ±20% 450 V / -25~+105 / / 1390 / 500 / 2000 25 45 / / 10 FIG-2 42 PL2S271MND2541 / 270 µF ±20% 420 V / -25~+105 / / 1130 / / / 2000 25 41 / / 10 FIG-1 43 PL2W221MND2530 / 220 µF ±20% 450 V / -25~+105 / / 1340 / 800 / 2000 25 30 / / 10 FIG-1 44 PL2W181MND2530R / 180 µF ±20% 450 V / -25~+105 / / 1000 / / / 2000 25 30 / / 10 FIG-1 45 PL2G821MN63560R / 820 µF ±20% 400 V / -25~+105 / / 2300 / / / 2000 35 60 / / 10 FIG-1 46 PL2H471MND3550RY / 470 µF ±20% 500 V / -25~+105 / / 2190 / / / 2000 35 50 / / 10 FIG-2 47 PL2G471MND2550 / 470 µF ±20% 400 V / -25~+105 / / 1940 / / 330 2000 25 50 / / 10 FIG-1 48 PL2G681MND3050RY / 680 µF ±20% 400 V / -25~+105 / / 2150 / / 220 2000 30 50 / / 10 FIG-2 49 PL2W271MND3030RSY / 270 µF ±20% 450 V / -25~+105 / / 1200 / / / 2000 30 30 / / 10 FIG-2 50 PL2W101MND2531 / 100 µF ±20% 450 V / -25~+105 / / 600 / / / 2000 25 31 / / 10 FIG-1 51 PL2W911MND4045AER / 910 µF ±20% 450 V / -25~+105 / / 2700 / / 200 2000 40 45 / / 10 FIG-1 52 PL2G471MND3043Y / 470 µF ±20% 400 V / -25~+105 / / 1940 / / / 2000 30 43 / / 10 FIG-2 53 PL2D332MND3560 / 3300 µF ±20% 200 V / -25~+105 / / 5000 / / / 2000 35 60 / / 10 FIG-1 54 PL2G331MND3030Y / 330 µF ±20% 400 V / -25~+105 / / 1490 / / 310 2000 30 30 / / 10 FIG-2 55 PL2G471MN63545 / 470 µF ±20% 400 V / -25~+105 / / 1900 / / / 2000 35 45 / / 10 FIG-1 56 PL2W391MND2550AY / 390 µF ±20% 450 V / -25~+105 / / 1600 / / / 2000 25 50 / / 10 FIG-2 57 PL2W221MND2240Y / 220 µF ±20% 450 V / -25~+105 / / 1150 / / / 2000 22 40 / / 10 FIG-2 58 PL2W221MND2545RP / 220 µF ±20% 450 V / -25~+105 / / 1000 / 1060 / 2000 25 45 / / 10 FIG-1 59 PL2W281MND3025Y / 280 µF ±20% 450 V / -25~+105 / / 1350 / / / 2000 30 25 / / 10 FIG-2 60 PL2S181MND2535 / 180 µF ±20% 420 V / -25~+105 / / 970 / / / 2000 25 35 / / 10 FIG-1 61 PL2G181MND2530 / 180 µF ±20% 400 V / -25~+105 / / 1050 / / / 2000 25 30 / / 10 FIG-1 62 PL2W871MND3060Y / 870 µF ±20% 450 V / -25~+105 / / 2840 / / / 2000 30 60 / / 10 FIG-2 63 PL2W821MND3060B1RY / 820 µF ±20% 450 V / -25~+105 / / 2900 / / / 2000 30 60 / / 10 FIG-2 64 / 470 µF ±20% 450 V / -25~+105 / / 1750 / 435 / 2000 30 40 / / 10 FIG-1 PL2W471MND3040 Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan TEL: +886 2 2995 0535 65 PL2G391MND2545Y / 390 µF ±20% 400 V / http://www.chinsan.com/products/ -25~+105 / / 1320 / / / 2000 25 45 / / 10 FIG-2 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: Sleeve Color: Black. Suffix Y represents assembly without gasket. APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍
PL2G271MND2245Y 价格&库存
很抱歉,暂时无法提供与“PL2G271MND2245Y”相匹配的价格&库存,您可以联系我们找货
