Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
PV
Series
Downsize and high ripple current
Load life 2,000 ~ 5,000 hours at 105℃
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-25 ~ +105℃
Working Voltage Range
160 ~ 500Vdc
Capacitance Range
33 ~ 560 μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Rated Voltage (V)
160
200
250
400
420
450
500
tanδ(Max)
0.20 0.20 0.20 0.20 0.20 0.20 0.24
The above values should be increased by 0.02 for every additional 1000μF
I=0.02CV or 3000μA whichever is smaller
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 2 minutes
V : Rated voltage (V)
Rated voltage (V)
160~250
400
420 ~ 450
500
Z(-25℃)/Z(+20℃)
3
5
6
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 2,000 ~5,000 hours at 105°C
Endurance
Capacitance change
Dissipation factor(tanδ)
≦ ±20% of the initial value
Leakage current
≦ specified value
Size
ФD≦12.5Ф
ФD≧ 16 Ф
≦ 200% of the specified value
Life time (hours)
2,000
5,000
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 105℃ without voltage applied.
Shelf Life
Capacitance change
Leakage current
Others
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
ФD
10
ФD
V
16
18
Фd
0.6
0.6
0.8
0.8
F
5.0
5.0
7.5
7.5
L + 1.5 Max
≤ 35 L+1.5Max
≥ 40 L+2.0 Max
a
P
12.5
ФD +0.5 Max
PART NUMBER SYSTEM( Example : 420V 68µF )
2 S 6 8 0 M N N 1 6 4 0
Special Request
Size code(1640 : 16×40)
Lead length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (68μF)
Voltage code (420V)
Series code (PV)
L + 1.5 Max
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
PV
NO.:
FIG-1
FIG-2
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
2022-03-25
PUBLISH DATE
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Rated
Rated
Category
Tanδ
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
(mA rms) (mA rms) (mΩ max/ (mΩ max/
(2 min.) @ 105℃ @105℃
120Hz)
100kHz)
Dimensions (mm)
Endurance
@ 105℃
(Hours)
120Hz
100kHz
1
PV2G330ML41225F8R
33 µF
±20%
400 V
-25~+105
310
8000
2
PV2W101MLT1640EZ
100 µF
±20%
450 V
-25~+105
800
1600
1700
5000
Appearance
D
Φ
Drawing
L
a
d
F
No
12.5 25
5
FIG-1
7.5
FIG-2
16
40
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Sleeve Color: Black.
Suffix F8 indicates the life of the capacitor is 8000 hrs.
Customer
Digi-Key
SERIES
PV
NO.:
FIG-1
FIG-2
Tolerance
No.
CHINSAN
Part No.
Part No.
(uF)
2022-03-25
PUBLISH DATE
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Rated
Rated
Category
Tanδ
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
120Hz
100kHz
120Hz)
100kHz)
Dimensions (mm)
Endurance
@ 105℃
(Hours)
Appearance
D
Φ
Drawing
L
a
d
F
No
1
PV2W121MRT1845R
120 µF
±20%
450 V
-25~+105
950
5000
18 45
7.5
FIG-1
2
PV2G101MNN2030R
100 µF
±20%
400 V
-25~+105
800
650
5000
20 30
10
FIG-2
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Customer
Digi-Key
SERIES
PV
NO.:
2022-03-25
PUBLISH DATE
Unit(mm):
P=30.0±1.0
P0=15.0±0.2
P1=3.75±0.5
P2=7.5±1.0
F=7.5+0.8/-0.2
Original
FIG-1
Tolerance
No.
1
2
3
4
5
6
7
8
9
10
11
12
CHINSAN
Part No.
PV2C681MNN1850
PV2E330MNN1220
PV2F270MNN1620
PV2G121MNN1830S
PV2W680MNN1825RA
PV2W820MNN1835
PV2W151MNN1840R
PV2W101MNN1635
PV2W121MNN1640
PV2H330MNN1820E
PV2H470MNN1825
PV2H220MPI1625
Part No.
(uF)
680 µF
33 µF
27 µF
120 µF
68 µF
82 µF
150 µF
100 µF
120 µF
33 µF
47 µF
22 µF
H=18.5±0.5
W =18.0±0.5
W0=12.5MIN
ΦD0=4.0±0.2
t=0.7±0.2
On rated
Working
Capacitance Voltage
(Vdc)
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
±20%
160 V
250 V
315 V
400 V
450 V
450 V
450 V
450 V
450 V
500 V
500 V
500 V
Surge
Voltage
(Vdc)
Rated
Rated
Category
Tanδ
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃
Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(uA)
(Max)
-25~+105
-25~+105
-25~+105
-25~+105
-25~+105
-25~+105
-25~+105
-40~+105
-40~+105
-25~+105
-25~+105
-25~+105
120Hz
100kHz
1520
245
730
800
580
635
970
730
820
320
350
1200
120Hz)
100kHz)
2510
4440
9100
10500
1510
2390
Dimensions (mm)
Endurance
Appearance
@ 105℃
(Hours)
5000
2000
5000
5000
5000
5000
5000
5000
5000
5000
5000
5000
Drawing
DΦ L
a
d
F
No
18
12.5
16
18.5
18.5
18
18
16
16
18
18
16
7.5
5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
Original
Original
Original
Original
Original
Original
Original
Original
Original
Original
Original
FIG-1
50
25
35
40
35
40
25
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
很抱歉,暂时无法提供与“PV2H470MNN1825”相匹配的价格&库存,您可以联系我们找货
