SB1V100MPN0505H
SB1V100MPN0505H
    CHINSAN(金山)
    Radial, Can
    ALUMINUM ELECTROLYTIC CAPACITORS
SB1V100MPN0505H 数据手册
Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 SB & SB-H   Series Standard miniature series with 5mm height at 85 ℃ &105℃ SPECIFICATIONS Performance Characteristics Item Series SB SB-H Category Temperature Range -40 ~ +85℃ -40 ~ +105℃ Working Voltage Range 4 ~ 50 Vdc Capacitance Range 0.1 ~ 470 μF Capacitance Tolerance ±20% (at 25℃ and 120Hz) Dissipation Factor (tanδ) (at 25℃, 120Hz) Leakage Current Low Temperature Characteristics Impedance Ratio(MAX) Rated Voltage (V) 4 6.3 10 16 25 35 50 tanδ(Max) 0.37 0.28 0.22 0.18 0.16 0.14 0.12 I=0.01CV or 3μA whichever is greater I : Leakage current (μA) C : Rated capacitance (μF) Impress the rated voltage for 2 minutes V : Rated voltage (V) Rated voltage (V) 4 6.3 10 16 25 35 50 Z(-40℃)/Z(+20℃) 15 8 8 6 4 4 3 (at 120Hz) The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 1,000 hours at 85℃(SB), or 1,000 hours at 105℃(SB-H). Endurance Capacitance change ≦ ±25% of the initial value (4V:≤ ±30%) Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ specified value The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for 500 hours at 85℃(SB), or 500 hours at 105℃(SB-H) without voltage applied. Shelf Life Capacitance change ≦ ±25% of the initial value Dissipation factor(tanδ) ≦ 200% of the specified value Leakage current ≦ 200% of the specified value Others  Conforms to JIS-C-5101-4 (1998), characteristic W DIMENSIONS (mm) ФD 4 5 ФD 8×5 Фd 0.45 0.45 0.45 0.45 F 1.5 2.0 2.5 3.5 a  S 6.3 ФD + 0.5 Max PART NUMBER SYSTEM( Example : 50V 0.47µF ) B 1 H R 4 7 M N N 0 4 0 5 Special Request Size code(0405 : 4×5) Lead length code Lead forming Type code Capacitance tolerance code(M:±20%) Capacitance code (0.47μF) Voltage code (50V) Series code (SB) L + 1.0 Max Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 SB1A470MNN0505H / 47 µF Working ±20% (Vdc) 10 V Surge Voltage (Vdc) / SB-H NO.: Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -40~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ / 2022-03-25 PUBLISH DATE 120Hz 100kHz 35 / 120Hz) 100kHz) / / Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 1000 Drawing DΦ L 5 5 a d F No / / 2 --- ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black. Taiwan Chinsan Electronic Ind., Co., Ltd. Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan http://www.chinsan.com/products/ TEL: +886 2 2995 0535 Aluminum Electrolytic Capacitor Customer Digi-Key SERIES SB-H NO.: 2022-03-25 PUBLISH DATE Unit(mm): P=12.7±1.0 H0=16.0±0.5 P0=12.7±0.2 W =18.0±0.5 P1=3.85±0.5 W0=12.5MIN P2=6.35±1.0 ΦD0=4.0±0.2 F1=5.0+0.8/-0.2 t=0.7±0.2 H=18.5±0.5 Original FIG-1 Tolerance No. CHINSAN Part No. Customer Capacitance Part No. (uF) On rated Capacitance Voltage (%) 1 SB1V100MPN0505H / 10 µF Working ±20% (Vdc) 35 V Surge Voltage (Vdc) / Rated Rated Category Tanδ Leakage Ripple Ripple ESR Impedance Temp @ 25℃ Current Current Current @25℃ @20℃ Range (120Hz) (uA) (℃) (Max) -40~+105 / (mA rms) (mA rms) (mΩ max/ (mΩ max/ (2 min.) @ 105℃ @105℃ / 120Hz 100kHz 22 / 120Hz) 100kHz) / / Dimensions (mm) Endurance Appearance @ 105℃ (Hours) 1000 Drawing DΦ L 5 5 a d F1 No / / 5 FIG-1 ※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test. REMARKS: APPROVED BY CHECKED BY PREPARED BY 张洪斌 曾爱娥 梁慧妍 Sleeve Color: Black.
SB1V100MPN0505H 价格&库存
很抱歉,暂时无法提供与“SB1V100MPN0505H”相匹配的价格&库存,您可以联系我们找货
